I'm still getting the IPS error when I go to www.skylinesaustralia.com in Firefox 3.6.8. I got around it by going through my history & selecting a previous SAU page & then login from there. Just an idea if people are getting the same problem as me.
https://www.sau.com.au/forums/topic/334863-ips-error/#findComment-5422734
Yeah same here Hanso, it looks like it redirects to http://www.skylinesaustralia.com/forums/home.html then errors. My bookmark for http://www.skylinesaustralia.com/forums/forums.html works fine though thankfully!
I'm sure the C-bomb will fix it in due course :)
https://www.sau.com.au/forums/topic/334863-ips-error/#findComment-5422826
