I currently have a GT3040R .82 on my rb20 which i believe is a GT3082R?
I’m currently running 21psi and plan to screw in another 4-5psi, is this still in the efficiency map for this turbo?
at the moment the engine is making 10hp/psi and has made 371rwhp @ 7300rpm
at what point would you go a 1.06 rear housing or would you go a GT35R with a .82 rear. what is the difference from the obvious?
what are these turbos rated hp wise with the 3 different rear housing options?
what would the response/lag difference be between each combo
for a reference im making 5psi @ 4300rpm and ramps hard to 5500rpm making 17psi
what would be the next step with the turbo, my goal is another 50-70hp
Thanks Luke
https://www.sau.com.au/forums/topic/334874-gt30r-vs-gt35r/
On a RB25 i made 270rwkw @ 17psi with a GT3040 (600hp) in a .82
If you get a GT35, it'll be laggier, simple as that. Its a larger comp wheel so its going to be slower.
Given then 600hp GT30 should do 330rwkw, you need more boost.
https://www.sau.com.au/forums/topic/334874-gt30r-vs-gt35r/#findComment-5422243
yes will have more lag but just how much, 500rpm, 1000rpm for same boost.
330rwkw on a 25 or 20 and at what psi
https://www.sau.com.au/forums/topic/334874-gt30r-vs-gt35r/#findComment-5422279
How do you know its not coming into another area of efficiecny and so on where the power gains are more than 10hp/psi?
IMO much below 24-25psi and the turbo isn't really in its happiest place given i should have been running closer to 20-21psi on a 2.5ltr
https://www.sau.com.au/forums/topic/334874-gt30r-vs-gt35r/#findComment-5422362
the next step up is the GT35, in 0.82 form it will do 350-380rwkw.
that is going to be very laggy on a little RB20, you will have ~1000-2000rpm of full boost before you have to change gear again. if its just to get the number is it really worth it?
https://www.sau.com.au/forums/topic/334874-gt30r-vs-gt35r/#findComment-5422364
Nitrous, E85 - two much better ways to get that little bit more power
Or just alter the dyno setting, for 40hp I'm not sure the need for the hair splitting...
https://www.sau.com.au/forums/topic/334874-gt30r-vs-gt35r/#findComment-5422370
but will it do another 100hp.
Probably, if your motor can.
Whats done to your motor? Your coming in fairly late with only 5psi by 4300, I know the gibson RB20 had powerband between 6 and 8 yet a 1:1 bump on the static CR and a 3 psi drop in boost saw it with usable power between 4 and 8... MASSIVE difference.
Tell us more about your motor.
https://www.sau.com.au/forums/topic/334874-gt30r-vs-gt35r/#findComment-5422443
40thou over size arias pistons, spool rods, ported head, 264 cams 8.5mm lift, 8.7cr. high mount 3040, rb26 intake and throttles,
changing intake to 80mm tb and new plenum on half standard runners to make a little more torque. cam gears set at odeg atm.
720cc injectors, toda light weight flywheel,
https://www.sau.com.au/forums/topic/334874-gt30r-vs-gt35r/#findComment-5422464
Leave the throttle, try get the gears dialed up. For interest sake I would also try dialing them with the stock intake cam.
Your motor sounds like it can make the power, just need to push the turbo into efficiency along with the tune to match. 25PSI and a good dial on the gears should get you the power Ash is talking about (30rwkw) if not more IMO.
https://www.sau.com.au/forums/topic/334874-gt30r-vs-gt35r/#findComment-5422601
Nismoid the Garret turbine maps actually show the flow rates of the 0.82 GT30 and the 0.63 GT35 as having similar maximums though IMO the GT30 0.82 is the better map , these are with the T3 flanged GT30 turbine housings BTW because the 30 and 35 both use them .
Not my project and don't think I'd build such a top endy RB20 but to each their own .
Now there is another option in the GT3082R family and its what used to be called GT3040 in HKS speak .
What it is is same deal as the Garrett GT3082R/GT3040 but with a 50 trim rather than 56 trim GT40 compressor wheel in it .
My old HKS list shows its good for 20 more PS/Hp than a GT3037S/GT3076R 56 trim .
I have a compressor map of a Garret large frame plain bearing GT4082 which uses this same compressor wheel and it shows the the maximum airflow rate at the bleeding edge of about 57 lbs so potentially 570 Hp if you go by maximums .
This is in a 0.58 A/R GT40 compressor housing which is crudely speaking of a similar size externally to a T04S o.70 A/R one , maybe a smidge smaller but port shrouded .
It may even pay the OP to look into Mitsubishi turbos because they tend to use reasonably big wheels in smaller trims than Garrett does sometimes and that could pay off when you want power over as broad a range as possible .
BTW what does the OP want to do with this RB20 ?
A .
https://www.sau.com.au/forums/topic/334874-gt30r-vs-gt35r/#findComment-5422747
    • 3 Kids are starting to hit that ages. I wanted to get them something special to learn on, put down the screens and have some fun. 4Door 2001 R34DE Black Pearl GV1 Jap Import, AU 2nd owner. Pre Work done. Suspension - Wheels Pedders SportsRyder Coilovers   Wheels TSG Spokey Boi 18'x9.5"+15 Body JASI Aero 4 door Type R Full Kit LED Conversion - Parker, Blinkers, & Reverse Exhaust Hurricane Headers 100 CPI high flow cat 2.5" Piping Cannon muffler Internal Bride low max stradia ii - front seats  Bride RO seat base and Rails (R/H) Cube short shifter LED Conversion - Interior
    • Why are you so adamant on going M12? Why not follow Brad (GTSBoy) suggestion. You're talking moving from a 1/8" size, to a 1/2" effectively. 4 times bigger. Why skip the commonly available sizes in between? The bigger you go, the more likely you are to strip the threads out at a later date, as guaranteed, someone will put a huge spanner on the M12 and really tighten it up, and you're only in thin wall, so not a lot of threads to engage!
    • Hi. Yeah thanks. Car is already at tuners and it staying there to resolve "many" issues they do not like. So it is in a good hands. Getting a good tune on that Nistune ECU too so the car would be good. Just needs a little tune up and love.
    • Probably gonna remove manifold and turbo. I’m not sure if I can get M12 x 1.5 air tight. Could use high temp Loctite 246 or something similar, but I don’t know. Maybe it’s just best to remove everything again and weld an 1/8NPT on there instead.
    • Yeah, saw the ratios, not impressed. Would like the punch I have in the first gears now. With those ratios it won't be the same.  Also want the h pattern gearing, or at least a quiet gear set that don't need to come apart for service each year. Looks like the only "reasonable" way Is a 8hp70 transmission, but where is the fun in that🤷‍♂️
