ive got an aussie delivered s14 and im rebuilding the diff ive heard that the diff ratios are like 3.692 or sumthing and thats a really really shit ratio i want to put an 4.1 or 4.3 in it
ive got a spare s13 diff there and the gear ratio labelled on that says 48:11
what is that is that 4.1 or something else im a bit unsure
thanx patrick
https://www.sau.com.au/forums/topic/334990-diff-ratios/
thanx patrick
You may want to do some more research. The 3.692 ratio, is found in the S15 with a 6 speed manual gearbox and not in the S14.
So I'd figure out exactly what you have in your S14, before you start panicking.
https://www.sau.com.au/forums/topic/334990-diff-ratios/#findComment-5427573
I posted this up the other day in another thread.
Maybe we can sticky it?
Nissan diff ratios:
4.900 - C23 Serena SR20DE 4WD Auto
4.636 - C23 Serena SR20DE 4WD Manual, C23 CD20T 4WD
4.375 - R32 RB20DET 4WD, A31 Cerfiro RB20DET 4WD
4.363 - R34 RB25DE 4WD, R34 RB25DE Manual, R34 RB20E, R33 RB25DE 4WD, R33 RB25DET Auto, R33 RB25DE, R32 RB20DET, R32 RB20E,
C35 Laurel RB25DE 4WD Auto, C34 Laurel RB25DE 4WD Auto, C34 Laurel RB25DE Auto, C33 Laurel RB20DE Manual
A31 Cerfiro RB20DET, A31 Cerfiro RB20DE Manual, S13 CA18DET, S13 CA18DE, C23 Serena SR20DE 2WD, C23 Serena CD20T 2WD
4.111 - R34 RB25DET Auto, R33 RB25DET Manual, C35 Laurel RB25DET Auto, C35 Laurel RB20DE Auto, C34 Laurel RB25DET Auto, C34 Laurel RB2
0DE Auto,
S13 SR20DE (ABS),
4.083 - R34 RB25DE Auto, R33 RB20E, R32 RB20E (ABS), C33 Laurel RB20DE Auto, A31 Cerfiro RB20DE Auto,
S15 SR20DE, S14 SR20DET Manual, S14 SR20DE Manual, S13 SR20DET Manual, S13 SR20DE (ABS), S13 SR20DE
3.916 - S13 SR20DET Auto, S14 SR20DET Auto, S15 SR20DET Auto, A31 Cerfiro RB20E. 5 & 6 bolt
3.692 - S14 SR20DET ADM Manual, S15 SR20DET Manual. 5 & 6 bolt
3.583 - R33 RB25DE Auto, C33 Laurel RB20E Auto
* transmissions as stated, if not listed it means they are available in either Manual or Auto.
If anyone can add to this list, either if its ratio or cars, please do so.
Edited by RBceffy25
  • Like 1
https://www.sau.com.au/forums/topic/334990-diff-ratios/#findComment-5427759
quick question is there a big difference in 4.1.1 in a r33 manual diff to a 4.3.1 as i have a kazaa 2-way diff to go in my car for the drags.
thanks
4.3 is better for the drags as long as u dont have to change into 5th before crossing the finish line
https://www.sau.com.au/forums/topic/334990-diff-ratios/#findComment-5431351
thanks
as DVS32R said aslong as you do not need 5th gy the finish line, but the shorter the ratio the better acceration you get but the more likely you are to wheel spin, i have the 4.11.1 in the gtr and on street tyres on low boost it will brake into 4wd wheel spin as it comes on boost in the first 2 gears and the 4.3 would only make that worse
  • Like 1
https://www.sau.com.au/forums/topic/334990-diff-ratios/#findComment-5435045
  • 4 years later...
revisiting my last comment 4 years ago
4.3 ratio
shit traction
shit fuel economy
lower mph from 127 to 115
i would recommend for lower powered cars if you want a quicker accelerating car or for drift
im looking for 3.9 or 3.69
has anyone got any expirience with these gears
  • Like 1
https://www.sau.com.au/forums/topic/334990-diff-ratios/#findComment-7426140
I could have told you that, oh wait I did :P
We went 3.9s from 4.11s in the BSM car and went faster 2 seconds around EC, they then went 3.55 from a 34 after I stopped going in and that is what was in it for world time attack
Personally with 350rwkws+ I would go the 3.69s, but then that depends how big your horsies are, I know 3.69s are easy to get for the R200 but finding them for the front diff is proving harder to do, I know there is a WRX that has that ratio but which exact model is what I am finding hard to nail down
  • Like 2
https://www.sau.com.au/forums/topic/334990-diff-ratios/#findComment-7427042
I think so, realy depends how much torque it makes though, have you got a dyno graph, the more torque you make the better the use you will get for longer diff gears
The biggest issue your going to have with 400kw and rear wheel drive is traction, so anything you can do to add in keeping it will make car faster
https://www.sau.com.au/forums/topic/334990-diff-ratios/#findComment-7427605
    • You know how your car rolled through a fence in your last jacking escapade? Scissor jacks increase the likely hood of that sort of thing happening immensely!
    • http://calfinn.com.au/product/1500kg-standard-trolley-jack-cj-2t-c/1500kg-standard-trolley-jack-cj-2t-c   I have this and fits under a S3 33 GTR with no issues. Purchased in 2009 and not one issue. It was $950 back then. Not cheap but something so important isn’t worth cheaping out on.
    • Just trying to get my head around this. At 5psi of boost, you turn on your wmi pump, and then you're using a 3000cc injector, to allow flow upto the actual engine, where you have your 6x200cc injectors and a 500cc injector. If the above is correct, what advantage are you obtaining by having the 3000cc injector blocking flow, is this just incase a line breaks between that injector and the motor you can stop flow immediately? Or are the 6x200cc and 500cc less injectors and just spray nozzle?
    • Welcome! New member myself, but I had an R33 back in 2002. Best advice I could give, based on my experience: if you're running the factory turbo, be very conservative with boost. I made the mistake of just fiddling around with the boost controller and cranking the boost for fun, and the end result was my intake pipes popping off frequently from the constant deluge of oil that was being blown into the recirc by the stressed-out turbo, which itself was siphoning oil from the engine and farting it out both sides of its centre bearing (or something to that effect). If I could do it all again, I would have gotten a new turbo and had a tune dialled in professionally and then just left it alone! Funny you mention the metal shavings in the gearbox, as I had the same thing - the probe plug (magnetic drain plug, essentially) would come out caked with shavings. At least it was doing its job. Not sure if that's just sacrificial wear and part of the deal, or if my gearbox was shagged, but I wasn't abusing it. Enjoy the R33 - they're a dying breed, and if they weren't $35k+ on CarSales in Queensland, I might have picked up one of those again, instead of the 370GT I own now (though I'm loving the 370GT, that big 3.7L V6 just hits different).
    • Howdy folks. I owned an R33 back in 2002, which was thoroughly beyond my capacity (financially speaking) to maintain/insure, so we parted ways in 2004. Fast forward 21 years (to literally yesterday, in fact) and I'm now the proud owner of a 2007 V36 370GT. I'm happily surprised by how much power the VQ37VHR makes, compared to the RB25DET, considering the latter is turbocharged. I had planned to add a turbo at some point but I'm on the fence about whether I'll even need it (though I do love the sudden onset of extra torque). Any other 370GT owners around the traps, I'd love to hear about your experiences with this car (good and bad).
