Hi Guys,
Went to fit pineapples in my R34 GTT at Traction Tyres on the weekend and was told i needed to replace the following:
"Front caster bushes leaking, Front & Rear tie rod boots split".
I was wondering if someone could point to me in the right direction of parts to replace them with.
I have tried a search but unfortunately could not find the information I was after especially with the tie rods.
I have had a look at the whiteline website and saw the following but not sure?
For the caster bushes: KCA 331 http://www.whiteline.com.au/product_detail...t_number=KCA331
For the tie rods? I wasn't sure? These? http://www.whiteline.com.au/product_detail...rt_number=W0206
In addition if there is anything else worth replacing that may as well be done to save labour costs let me know.
Thanks in advance!
hey bud,
if you want to do a complete suspension overhaul here is the complete christmas wishlist;
Shocks - ~$1200
Springs - $600
swaybars adjustable - $225 each
hicas eliminator (if req) - $220
Castor Bushes
Radius Rod - $120
Front Arm/Camber - $170
Rear Arm upper/Camber - $145 x 2 you will need
Subframe - $130
not too sure of any good suspension/steering workshops in melbourne, but you may have some luck if you have a gander in the suspension/tyres section, you may find some places
all the best with it, and as always, report your findings and experience with whoever you go with so others can benefit off the feedback!
danny
  • 2 years later...
Huh this is a dead thread huh anyway ill still post for the benefit of readers I'm in the same boat need to register my car just imported it and I need to fix the castor and rear right suspension before getting road certificate.will post updates.
  • 3 months later...
slight gravedig, anyone know anywhere in hornsby NSW or anywhere else which will supply all parts such as this:
Castor Bushes
Radius Rod - $120
Subframe - $130
    • Cheers. Skyline is back on the menu, can’t get rid of it. It’s like a child you don’t want, or herpes
    • I got back to Japan in January and was keen to get back on track as quickly as possible. Europe is god-awful for track accessibility (by comparison), so I picked up a first-gen GT86 in December just to have something I could jump into right away. The Skyline came over in a container this time and landed in early January. It was a bit battered after Europe, though—I refused to do anything beyond essential upkeep while it was over there. The clutch master cylinder gave out, and so did the power steering. I didn’t even bother changing the oil; it was the same stuff that went in just before I left Japan the first time. Naughty. Power steering parts would’ve cost double with shipping and taxes, so knowing I’d be heading back to Japan, I just postponed it and powered through the arm workout. It took a solid three months to get the car back on the road. Registration was a nightmare this time around. There were a bunch of BS fees to navigate, and sourcing parts was a headache. I needed stock seats for shaken, mistakenly blew 34k JPY on some ENR34 seats—which, of course, didn’t fit—then ended up having the car’s technical sheet amended to register it as a two-seater with the Brides. Then there’s the GT86. Amazing car. Does everything I want it to do. Parts are cheap, easy to find, and I don’t care what anyone says—it’s super rewarding to drive. I’ve done a few basic mods: diff ratio, coilovers, discs, pads, seat, etc. It already had a new exhaust manifold and the 180kph limiter removed, so I assume it’s running some kind of map. I’ve just been thrashing it at the track non-stop—mostly Fuji Speedway now, since I need something with higher speed after all that autobahn time. The wheels on the R34 always pissed me off—too big, and it was a nightmare getting tires to fit properly under the arches. So I threw in the towel and bought something that fits better. Looks way cleaner too (at least to me)—less hotboy, less attention-seeking. Still an R34, though. Now for future plans. There are a few things still outstanding with the car. First up, the rear subframe needs an overhaul—that’s priority one. Next, I need to figure out an engine rebuild plan. No timeline yet, but I want to keep it economical—not cutting corners, just not throwing tens of thousands at a mechanic I can barely communicate with. And finally, paint. Plus a bit of tidying up here and there.
