BC Racing BR vs ISC N1?
Sorry to put you on the spot :P
i would be interested in the comparison as im looking to get some soon
http://g35driver.com/forums/brakes-suspens...ete-review.html
Lol looks like I mite be choosing hsd hrs herd alot gd things about them. What's the difference between isc n1 vs hsd hr's??
Edited by r32man09
Hey
Thinking putting sum new coilovers in my r32 just dunno what to get? My cars and a daily but once everythings done plan to to take it to the track
cheersu
What's your budget? Are you after value for money only or are you after suspension that actually works and competitors use?
I have a budget of about $1700 set up for street/track
mate I'm about to ditch my teins for a Bilstein/king spring combo. bilstein shocks can be made height adjustable by adding extra circlip grooves which lock the spring seat onto the shock body. you could use any brand spring on them. Most people who know what there are talking about say bilsteins (aussie spec) have good valving off the shelf for street/track work for GTSt's only GTR's need to be tweaked.
a set of bilsteins come in around $1200 and maybe and extra $100 for extra circlip grooves and a set of springs is around $300-$400.
I've had teins for years and they are good, I fitted BC's into my Mrs 33 and they have excellent adjustability, fitted tein super streets in wrx but bilsteins would have to be the most effective setup in that price range if your serious about lap times.
And i'd be looking at something around 6kg front and 4-4.5kg rear spring wise. (adj. sway bars ideal also)
hope this helps mate
On a budget BC racing is the win i believe. $1199- ive got them really stiff in my rb s13 and had no probs, my good mates also have them in an r32, r33, cefiro and they all agree... brand new 24mths replace warrenty. and they make them for ANYTHING.. Matthew
    • Yeah and hence my ghetto way of slamming the brakes, get the ABS to cycle, rebleed seems to be a sensible workaround.
    • Hey! Happy to help. Nothing inherently wrong with the adapter, it's more so with Brett Collins himself. He gave me a lot of incorrect information when I was in contact with him and was extremely rude when I challenged him. He stated I could not use any aftermarket twin plate clutches except for his own, not to use the dush shield, bla bla bla and it was all BS.  Collins stated to cut roughly 14mm's off the housing, I took off 15mm to make room for the dust shield. I would confirm with whatever adapter manufacturer you're using.
    • There's plenty of OEM steering arms that are bolted on. Not in the same fashion/orientation as that one, to be sure, but still. Examples of what I'm thinking of would use holes like the ones that have the downward facing studs on the GTR uprights (down the bottom end, under the driveshaft opening, near the lower balljoint) and bolt a steering arm on using only 2 bolts that would be somewhat similarly in shear as these you're complainig about. I reckon old Holdens did that, and I've never seen a broken one of those.
    • Let's be honest, most of the people designing parts like the above, aren't engineers. Sometimes they come from disciplines that gives them more qualitative feel for design than quantitive, however, plenty of them have just picked up a license to Fusion and started making things. And that's the honest part about the majority of these guys making parts like that, they don't have huge R&D teams and heaps of time or experience working out the numbers on it. Shit, most smaller teams that do have real engineers still roll with "yeah, it should be okay, and does the job, let's make them and just see"...   The smaller guys like KiwiCNC, aren't the likes of Bosch etc with proper engineering procedures, and oversights, and sign off. As such, it's why they can produce a product to market a lot quicker, but it always comes back to, question it all.   I'm still not a fan of that bolt on piece. Why not just machine it all in one go? With the right design it's possible. The only reason I can see is if they want different heights/length for the tie rod to bolt to. And if they have the cncs themselves,they can easily offer that exact feature, and just machine it all in one go.
    • The roof is wrapped
