Bought the ceffy bout 8 months ago for a decent price just something to drive to work and back in. Then my partner bought a new mazda 3 and I aquired her lancer.. So we took the car back to Hervey Bay (thats where im from) and it sat in the shed and ran out of rego. Though to myself in this time I could put a car together and still be able to get to work and back. So the old rb25 came out of the ceffy and the 26/30 built started. Picked up a rebuilt rb30 off a mate here in brissy and then it all started. Sourced a rb26 head had it reco'd, light port and a set of tomei 270deg 10.25mm lift cams and tomei buckets/springs fitted also went for a single throttle setup for something different. Looking for a streeter to make 450-500rwhp all day every day.
So the things Ive collected on the way are:
Jun plennum
90mm throttle body
hks fuel rail
sard 800cc injectors
sard fpr
dash fittings
2 x 975 external pumps
haltech e11v2 patch loom and 3bar map sensor
crap load of dash fittings and braided line etc
Pulled the rb30 bottem end apart and found that it had been reco'd maybe 100km ago and is in very good condition.
ACL pistons
ACL bearings
Ballanced Rods/crank
Need to fit new water pump and a possible nitto oil pump/crank collar. Also looking for the turbo side of things at the moment maybe a 6boost manifold and a gt3540 or maybe T04z something along those lines as the power output is at the lower end of the scales and I want it to be a street car with decent response.
Got stuck into the engine bay with a mate thanks Keiron aka (Gtir-keiron) got it prepped and paintedd blue with green zerelick. Put it back together the next day.
so it started out like this:
Uploaded with ImageShack.us
base down
clear on and a close up of the colour change
parts all fitted back up
Small collection of parts
https://www.sau.com.au/forums/topic/335807-ants-rb2630-a31-ceffy/
  • Replies 75
Decided to go gt42r as we came accross a deal at a good price. So we sourced a trust manifold and a tial 44mm wastgate off a guy here on the forum. So hopefully we will get the wiring loom run and the computer in the car aslo still have to tap the block for the second tentioner and fit the head to the block, fingers crossed it'll be done this weekend ;).
thanks man should be interesting pretty much got eveything now so just gotta bolt it together and tune it fingers crossed itll be finshed very soon. It a bit hard when you live in brissy and the car is 3hours away :P
No worries man I'll get picks up asap, missed out on going home this weekend got called into work. Next weekend should see the wiring loom, engine in and turbo on and lines finished off! Not long now.
yeah will be cept ive been ripped off on my manifold and gate as ive bought one from a forum member and have been done $900 as its been over 2 weeks since ive paid for it and still havent recieved he also screwed over someone else on here too..
To be honest ant and i had the engine bay stripped down and painted in about 5 to 6 hours.
Motor already out of the car helped alot.Ant is really good with strip down work as he has pulled so many cars apart and put them back together again.
Wow anthony you got ripped off by a forum member dude? Name and shame time really mate and im sorry to hear about that.
I hope he comes clean and sends you the items mate really.
    • They are under bucket shims. Tomei provides a test shim kit and then any measurement of shim required.
    • I always wondered how you were supposed to buy a set of 24 buckets and somehow magically have every single one of them yield exactly the desired clearance. I would have thought you'd need to assemble a cam with either 12 "sample" or "example" buckets of known top thickness (or a single such sample/example 12 times over!!) measure clearances at every valve, and then do the usual math to work out what the actual "shimness" of each bucket needed to be, before buying the required buckets to make up he thicknesses that you didn't have on hand.
    • I now seem to be limited in power due to my rev limit/hydraulic lifters in my built RB25. I'm looking into converting over to Tomei solid lifters. Question for anyone that has done the conversion. I was always under the impression that when using the Tomei solid lifter conversion, you would also require new valves (Longer or shorter stems, I can't remember which).  I don't know where I got this idea, as so far I see no mention of this in any of the Tomei documentation. It just states I need the Tomei solid buckets, solid lifter cams and upgraded springs. As my head is already built, all I would need is another set of 1000$ Kelford cams, 500$ buckets and about 4H hours of my time installing and I'm off to the races!?!? There's no way it's that simple, I must be missing something?
    • I couldn't agree more. I should have started from the get-go with a NEO or solid bucket conversion. I started looking into converting over to solid lifters yesterday. Now for some reason I was always under the impression that when using the Tomei solid lifter conversion, you would also require new valves (Longer or shorter stems, I can't remember which).  But I see no mention of this on any of the Tomei documentation. It just states that I need the Tomei solid buckets, solid lifter cams and upgraded springs. As my head is already built, all I would need is another set of 1000$ Kelford cams, 500$ buckets and about 4H hours of my time installing and I'm off to the races!?!? There's no way it's that simple, I must be missing something?
    • BRUH, one of the biggest mistakes of my life..... and i've had plenty ;[)
