yeah man it sucks but the police are no involved so hopefully they get the f**ker. So looks like I wont be doing the 42r setup on the car as the manifold and gate where the last things in needed. Looking at putting standard twins on the car now to get it going :/
  • Replies 75
natett: just means more money that I now have to find to fork out. Ill see what happens im in no rush atm as I was looking at getting the car up and running by chrissy. I was looking at buy a 6boost mani and gate off another forum member but after what ive just been through I dont think I could waste that much money again :laugh:
The Quick spool valve goes between the turbo and manifold.
A valve closes on side of the manifold so the turbo spools up quicker, once boost gets into positive pressure the valve opens allowing full potential of the turbo.
Basically you can make 800rwhp and have it on full boost by 4000rpm :(
a lot of the supra guys in the US have used them. and the mega dollar supra build on here has 2.
they seem to show some impressive gains through the mid range however there isnt much info on them being used daily etc
when i go 3.4 ill be using one but thats another 12 months away haha
    • Lamb roast on Saturday will be different 🥲
    • They are under bucket shims. Tomei provides a test shim kit and then any measurement of shim required.
    • I always wondered how you were supposed to buy a set of 24 buckets and somehow magically have every single one of them yield exactly the desired clearance. I would have thought you'd need to assemble a cam with either 12 "sample" or "example" buckets of known top thickness (or a single such sample/example 12 times over!!) measure clearances at every valve, and then do the usual math to work out what the actual "shimness" of each bucket needed to be, before buying the required buckets to make up he thicknesses that you didn't have on hand.
    • I now seem to be limited in power due to my rev limit/hydraulic lifters in my built RB25. I'm looking into converting over to Tomei solid lifters. Question for anyone that has done the conversion. I was always under the impression that when using the Tomei solid lifter conversion, you would also require new valves (Longer or shorter stems, I can't remember which).  I don't know where I got this idea, as so far I see no mention of this in any of the Tomei documentation. It just states I need the Tomei solid buckets, solid lifter cams and upgraded springs. As my head is already built, all I would need is another set of 1000$ Kelford cams, 500$ buckets and about 4H hours of my time installing and I'm off to the races!?!? There's no way it's that simple, I must be missing something?
    • I couldn't agree more. I should have started from the get-go with a NEO or solid bucket conversion. I started looking into converting over to solid lifters yesterday. Now for some reason I was always under the impression that when using the Tomei solid lifter conversion, you would also require new valves (Longer or shorter stems, I can't remember which).  But I see no mention of this on any of the Tomei documentation. It just states that I need the Tomei solid buckets, solid lifter cams and upgraded springs. As my head is already built, all I would need is another set of 1000$ Kelford cams, 500$ buckets and about 4H hours of my time installing and I'm off to the races!?!? There's no way it's that simple, I must be missing something?
