Hey guys,
For the right price, I will let the following go:
- R33 S1 RB25DET - 127xxxKM - Complete motor, manifolds and all $1000
- R32 ECU, Splitfire coilpacks, Z32 AFM, 690cc injectors, complete harness - Tuned to suit complete setup $800
- HKS 3037 pro S - Turbo, HKS dump (suits factory location), water+oil lines, 3" metal intake, silicon joiners (complete setup bolt on turn key) $2500
- R33 GTST Gearbox - Clutch, lines, all accessories, tailshaft (exchange with whatever nissan shaft you have). $1200
This setup is everything you will need to have the kit BOLT UP AND TURN ON in your car. The only things that are not included are the FMIC and the front pipe back exhaust.
The dump that is included with the turbo is the GENUINE HKS ITEM designed for the pro S and to suit factory bolt up location in a GTST. This will bolt into all R32/33/34.
I would prefer to sell the lot AS A PACKAGE. I WILL DISCOUNT A LOT OFF THE PRICE TO DO SO. But, I warn, low ballers will be punished :).
This would be PERFECT for someone with a R32 GTST. All you will need is an exhaust and a front mount (which most of you have) and viva la 300rwkw.
Reason for sale: custom conversion.
PM only at this stage, drop the deposit and I will remove it all from the car.
Cheers.
https://www.sau.com.au/forums/topic/336009-eoi-full-rb25det-hks-3037-setup/
Wiring harness to suit a 32?
R33 repinned for 32 ECU.
Will supply entire engine harness. This is a turn key package, out of my car running, into your car running.
can you please give more specs on the turbo???
ie what rear housing?? shaft play??? etc
thanks
Turbo is in perfect working order.
No shaft play, purchased from eldorode666 on this forum recently and sourced via HKS themselves. Unit has roughly 10,000Km on it.
.87 rear housing, internal gated.
Make good note that the HKS dump pipe to suit SKYLINES is INCLUDED. As is a HKS big can actuator.
The setup is in the car and running. Comes with everything you need to bolt it to your motor and have it run. Comes with intake and meets up with any aftermarket front pipe made for a skyline.
I would prefer to sell everything in one hit, but I will consider parting the larger items first.
Cheers,
what power did it make on what boost and mods?
Its tuned, but I honestly have not run it on the dyno. The tune was done by CEFF1E and will be reliable.
I can see to having it tweaked if a touch up is necessary. The car can be viewed running, but I do not have an FMIC so I will not be winding the boost up.
Morning all,
To all PMing;
Once the turbo setup is sold, I will be happy to start separating parts. I will put up a revised price list once that takes place, for individual items.
Cheers,
Bump - Have interest but is still officially available at this stage.
First in best dressed.
Sell complete for a song or part out once turbo kit is sold.
Willing to accept non refundable deposit to hold, car is not being driven so your investment will be sound.
Gearbox will either be sold with the setup or once the turbo sells. Same goes for the motor.
If the turbo setup sells first Ill part the rest out one bolt at a time if I have to. If the turbo doesnt sell theres no other sales.
Items currently available:
Long motor $1000
Gearbox $1200
Seems like turbo kit and electronics are pending sale.
Also have a BRAND NEW JJR STEALTH INTERCOOLER KIT. I bought it on saturday and decided to part out tonight, no longer need the cooler kit... $500. I threw the boxes out and bolted it to the car.. Its been start and driven from the top of the driveway back to the garage :) Sydney pickup only.
    • Possibly avoid using a Cometic one unless the deck/head surface are perfectly flat. I did have a look just then and forgiving gaskets such as Tomei or Nitto don't exist for the FJ20, however the Bar-Tek or Kameari ones look good and might do the trick.
    • Because pipe threads for pipe things. M threads for bolt things. Throw some teflon sealant onto it and dust your hands off knowing you did the right thing, instead of going twice around the block to achieve a result using the wrong things. Of course, all of these solutions are ignoring the fact that the minimum thread pitch we're talking about here is 1.25mm, with the 1/4" in NPT or BPS being out around 1.4mm. You will need to know that the boss you're tapping has enough thickness for at least a few threads. That's one of the reasons that 1/8" is commonly used - because the pitch is <1mm. And why would you look to use 1/4" NPT in a BSP country anyway? Ugh.
    • Just throwing around ideas, does it need to be in the compressor cover? Why not the hot side piping?
    • 1/8NPT drill size = 8.7mm. Since the hole got messed up by me, it’s probably around 9mm.    So 1/4” NPT would be next step. A drill size of around 11mm would be preferred there which is not way of my M12 (drill 10.5mm and tap M12 threads)
    • 3 Kids are starting to hit that ages. I wanted to get them something special to learn on, put down the screens and have some fun. 4Door 2001 R34DE Black Pearl GV1 Jap Import, AU 2nd owner. Pre Work done. Suspension - Wheels Pedders SportsRyder Coilovers   Wheels TSG Spokey Boi 18'x9.5"+15 Body JASI Aero 4 door Type R Full Kit LED Conversion - Parker, Blinkers, & Reverse Exhaust Hurricane Headers 100 CPI high flow cat 2.5" Piping Cannon muffler Internal Bride low max stradia ii - front seats  Bride RO seat base and Rails (R/H) Cube short shifter LED Conversion - Interior
