Hello fellow sau members
Background: Mods
Turnflow IC
Turbo back zorst
Standard turbs
Standard ECU, injectors, blah blah
Walbro 500hp pump
greddy profec II
About a month or two ago (lets say winter) my ECU has been going into R&R with anything past 7.5psi. My Greddy Pro B is set to lo of 8, hi of 10. (Prior to Winter it was hitting 10psi with no r&r). It's now Spring and temps above 20deg and it's still going r&r
Now I understand what R&R is, I have been to a reputable tuner/mech to check for vacuum/boost/intake leaks/AFM etc etc and understand that the air density in Winter may cause r&r amongst other things
Was wondering if anyone has a spare R34 ECU to do the old switcharoo to see how it reacts to my setup?? Curious to see is all
Located southern Syds
https://www.sau.com.au/forums/topic/336027-r34-gtst-ecu/
R&R usually gets worse in winter, and isn't as bad in hotter weather. there may possibly be an issue with the AFM, coil packs or spark plugs.
of course swapping in a different ecu will tell you whether it's ecu related however if it still does it it doesn't rule out other possible causes.
what is the actual problem you are having? is it a missfire? if it is then the first thing i would do is check the gap on the plugs if you aren't sure what the gap is, or reduce the gap on the plugs (especially if they are a 1.1mm gap). if that makes the problem go away then you don't have R&R, you have weak coils/spark plugs.
https://www.sau.com.au/forums/topic/336027-r34-gtst-ecu/#findComment-5437692
No missfire, I've replaced the sparkies with BCPR6ES .8 gap as well just to be sure. I'll have a good strong pull up until about 4000rpm, then no power till about 5700rpm, then power comes back on to redline. I can also tell in fuel consumption that it's running rich, plus the carbon soot I can see.
Coils seem fine, haven't noticed the common R34 "Slip TCS" light issue that is synonymous with the coilies, but then again, I haven't had a multimeter/voltage test done on them.
Will prob get that and an AFM test done to rule those bits out.
Otherwise it's r&r.. Just gives me an excuse to get an aftermarket ECU really lol.
https://www.sau.com.au/forums/topic/336027-r34-gtst-ecu/#findComment-5437861
your best bet would be to put it on a dyno and check the afr's. that will tell you for sure if it's R&R or not. if the power is dipping but afr's aren't changing much then you know it isn't R&R. the fact that it is still doing it in warmer weather makes me think it isn't so much R&R but something else. when i had my 33 i used to only get R&R on very cold mornings and i could always make it do it at certain times of the day in similar temps. on warmer days i couldn't get it to do it at all.
but then it also comes down to whether the R&R is being triggered by a faulty AFM or something like that since it has changed from how it used to be. even things like cleaning the AFM may help with diagnosing the problem.
https://www.sau.com.au/forums/topic/336027-r34-gtst-ecu/#findComment-5438529
Yea, you've got some good logical points there. No point in assumptions, may as well get it on the dyno, check the A/FR's, clean AFM etc and then deal with it once I have the results
Cheers mate
https://www.sau.com.au/forums/topic/336027-r34-gtst-ecu/#findComment-5438920
    • That is surely the biggest gathering of Stageas in North America, ever!
    • Remember kids - if you can't afford to buy 2 GTRs......
    • I know people cry at the price of the Getrag 12-14k for a conversion now, but it really is a nice mid point. Not going to get change from 10k on a gearset installed.  $30k++ for sequential.   I know you run the risk of a damaged used one and parts are hard to get but as a street car gearbox its really hard to beat. If you enjoy a more traditional manual, its the choice no question.
    • Time to decide what’s more import, your power level or your budget because you’re going to struggle to keep both
    • Our Southern Highlands Cruise is proudly registered with “R U OK?” Day.  Sometimes the best way to check in on your mates is by getting out for a drive together. Sharing a common passion like cars creates the perfect space to chat, connect, and support each other.  A simple “R U OK?” can make all the difference. Let's enjoy the drive, the company, and look out for one another. PLEASE WEAR YELLOW FOR “R U OK?” DAY Sunday 14th September 2025 9:30AM Meeting Crossroads Homemaker Centre 10:00AM Cruise Departure Via Old Hume Hwy 11:45AM Arrival at Mittagong RSL Club Meet Location: Crossroads Homemaker Centre Final Destination: Mittagong RSL Club *Disclaimer* There will be a lead and follow car so no one should get lost. If you would like to attend or bring others along please put your name down and a +1 as numbers will be needed prior! This is NOT a race and we will all be adhering to all road rules. If this is what you want please come to one of our many track days. This is an official SAU:NSW event and will be run under a CAMS permit. One of the things that really sets our club apart is our commitment to being true enthusiasts. When on normal roads we strive to maintain good relations with the authorities as well as the public in general. When attending one of Skylines Australia NSW events please try to: • Be aware of surrounding environment and act accordingly. • Drive courteously on the state’s roads as a true enthusiast should. • Understand how important it is to maintain the good name of SAU NSW and thus, treat others accordingly. • Any misbehavior will not be tolerated and you will be asked to leave.
