well when i was looking for cars, the soarer was one of the main cars i was looking at, although i don't own one and someone may like to shed some light on what its like to own, i will tell you my experience:
- we had a lot of trouble when i was looking as the 3 or 4 we looked at were burning oil... from what i have heard this is not common although something to watch out for when buying ANY car for that matter...
- TT version very quick but is like a boat to drive
- V8 was smooth to drive, still quick enough and has more fruitful goodies inside. its also a very reliable piece of machinery.
- a bad point may be that many mechanics in australia may not touch them as there is no english instructions for the dash or any of the electrics. but www.planetsoarer.com.au may help you out in that department.
pretty much if you want a car to get you from point A to point B in STYLE, and quickly, then this car is a BEAST! but it handles like a boat and is a bitch to park also. that's why i chose a syline, because it suits my driving style better and i drive lots and park in all sorts of places. good luck with the purchase.
cheers,
Waz.
https://www.sau.com.au/forums/topic/33608-soarer/#findComment-673577
A friend at work has a TT 91 Soarer. They are very nice cruise mobiles but:
- Manuals are very rare
- The airbag suspension is boat like
- The active suspension model is rare and expensive but the active suspension is awesome
- Theyre heavy
- I think they dyno about 160rwkw stock so they are still very quick
- The TT 6 is much quicker than the V8.
I think they can look very phat with a nice paint job and a mild body kit.
The 96 models on got VVT and a single turbo engine as well as some cosmetic things and im sure a bucket load more.
https://www.sau.com.au/forums/topic/33608-soarer/#findComment-673579
lol.... I cant believe I've made such newbie mistake... very common when you dont get enough sleep.... Correctoin inline 6 :)
I've test driven V8 and inline 6 TT both... for my mate
My friend ending up with TT cuz its more powerful...
but now I think of it If I had choice I would choosen V8 with nice exahust... have you heared it??? damm that sounds good :D
yeah they are like boat in the handling department, but it can be managed by installing some whiteline swaybar and any after market suspension kits plus some nice hard PINEAPPLES :D
but they are just too big for me...but for Big blokes( like my mate) Its plenty room. also nice room at the back if you are not 6'10 or less :(
cheers
Joe
https://www.sau.com.au/forums/topic/33608-soarer/#findComment-673844
i like em;
i seen this one parked out the front of my place!
http://maxe.ausforums.com/?agn=thread&id=1991481
plus we were having fun with a real quick bright yellow one last nite on the way home from netty
https://www.sau.com.au/forums/topic/33608-soarer/#findComment-673864
thanks for the help guys. i'm mostly learning about the jap cars at the moment, i only got into them a little once i started riding in them.
what's getting me is why they are so cheap, cause they look damn good on paper. their original value has deminished a lot more than most other cars, does anyone know why? i think that points to some kind of design flaw that was found later down the track, could be wrong.
i'm learing on a huge auto :rofl: that's another reason why i think they'd make a good choice one day. prolly be the lexus ones by the time i get the money!
https://www.sau.com.au/forums/topic/33608-soarer/#findComment-675105
Id be worried about the electrics stuffing up! man the amount of shit in those cars, the electric dash can sometimes go blinky and screw up.
95% are auto and they are quite expensive to mod compared to skylines i rkn. Once you do the basics, zorst, pods, fmic maybe then after that its hell expensive. They have shitty ceramic turbines too so they dont like to be boosted much at all.
Talk to the guys here http://www.lexus.australia.as/entry.htm its an australian soarer forum.
https://www.sau.com.au/forums/topic/33608-soarer/#findComment-675250
heres some info about soarers, for those interested:
http://www.sportsluxurycars.com.au/vehicle...yota_soarer.htm
e.g.
0-100km/h 6.9sec
0-400m 13.4sec
Top Speed 260km/h
Turning Cirlce 5.4m
Drag Co-eff 0.32
i went to this place a while back, and they specialise on soarers mainly.. with full evolution bodykits.. etc
https://www.sau.com.au/forums/topic/33608-soarer/#findComment-675292
    • oh they were with that motor, you need to remove the engine to change the spark plugs (don't have to, but it does make it easier)
    • I certainly fall into the annoyed camp, but glad to hear that if it's happening at low boost then I'm not likely going to blow a turbo and end up with metal shards in my oil. Just feels like it prevents me from really driving it without hesitation and "peak" performance. Wonder if it's the VCAM, it did an impressive job of shifting the torque curve and faster spool, but maybe now it's "too fast" and there's too much air for how open the throttle is.  Based on some other threads, will also do some reading on synchronizing the actuators. They are the default actuators that come on the Garrett's and I would think they would be set the same coming from the factory, but if the turbos don't actually work exactly the same way at the same time as previously mentioned, it would be worth making sure the actuators are actuating together properly
    • I went down this rabbit hole before, ended up sourcing a motor from the UK (I'm in Japan) which also didn't function correctly. With the original motor, I disassembled it and reassembled it and it works somewhat, sometimes. What I could deduce from all my screwing around is that there is calibration of the gears on the inside of the motor and two ramps on the main gear which activate switches that operate the motor and move the sunroof either to retract into the roof or tilt. Where I got stuck was that, it seemed in my case that one or both of the switches that are activated by the ramp on the gear did not always activate and thus the motor did not move, causing it to sometimes not retract or tilt (apologies, I've forgotten which way it didn't work.).  Of course this part is discontinued at Nissan now, it's the same part in the S15 but no other models. I also contacted the manufacturer of the component for schematics - forgot the name, they're based in Gifu - but they declined to share the information due to being bound by an NDA, sadly. Looking through my pictures now, it seems I last had a crack at this in 2022. See, I so kindly wrote "open" and "close" next to the switches. If you figure it out, please do tell me. Those little switches, with the red buttons may need to be replaced.
    • It says 300ZX, does that make it an Aus delivered car? Funny how back in the day I just couldn't care less about Z32's and these days I am just in love with them. Back when Nissan was into pushing the envelope. 🤣
