ok so if someone can supply a GTR grille, and maybe the little splitter as well for those of you who want it, then we can get some copies of these made up..
fatz if you are keen on doing this it will be pretty easy to make a profit because no where has them!!!!
Does anyone have one that we can make a mould out of???
also does anyone have one of the front skirts to make a mould out of or where they just pictures???
If we can get the parts I will take a GTR grille and the front skirting...
edit: if cant get that front skirting, then maybe a full GTR bar..these are $495 unpainted and not fitted at most places...
  • Replies 82
boys and girls.
im getting the rear lip off boostmiester.
just spoke to the guy who molds it.(im a non profit organisation)
the rear lip will be made in two pices then glued together with some fancy ****. he recons about 120 for the lip
the front lip would be about 60 but our problem is getting one. anyone got on like i said i dont want to pay 250 for one so if someone can donate one for approximately 1 week that would be tops
now for all yo hippies out there with 32 gts's he has available r32 gtr front bar copy of my car so its identical to a standard gtr and the front guards
gtr front bar is $330 good to go(felafel told you i would find out)
and for the front guards its 250 each
all part adhear to the pepsi challenge e.g if you think they r **** send em back. but i vouch for quality and any parts you r able to inspect at my house anytime
pete
0409226626
fatz/pete,
Where abouts are u located? I'd be in for some GTR Guards and front bar for sure! Just gotta work out how much its going to cost for shipping...
Cheers,
Ni.
***EDIT
oh and a rear lip for the boot.
do u want fries with that?
lol the rear lip is the piece you put UNDER a GTR spoiler... I dunno how that would look by itself. same deal witht he front lip, it goes over the GTR grille, dunno how it'll look without it.
Another thing, if the under-front bumper spoiler is made of fibreglass wouldn't it crack n stuff when u hit it on the ground? wouldn't it be better to make it out of poly eurathane in this case like the original one? As for the grille and the rear lip it shouldn't matter coz these neve suffer any impacts (unless u crash the car).
easy to put on
anyone out there a painter cause if you do a good rate you will have a ****load of buisness.
i cant paint to save my arse but if your offerin beer bring it on
if you want a front bar you can get em now but if you want a front or rear lip keep your cash in your pocket till we get the mold made.
ill speak to mats bro about getting it painted but generally you looking around 300 for a front bar that is painted nicely.. dont skimp on paint cause it will look ****
then if you like it order away
pete
vspec2 m8 if yor name is any relation to your car you shouldnt need these parts lol
i dont want that front lip... i want the front spoiler lip thing.. im dont want a rear spoiler i just want a little flick spoiler on my boot.
inark I want that lip to...but i dont think anyone has one to make a mould...
so i guess it'll have to be the whole GTR bar...
Let me know what's happening with the GTR grille...and i should be able to grab one of the GTR bars, if i can't get a lip in a month or so...
this is the lip you are talking about????
edit: If you are buying a GTR bar for your gts-t it will need some modification to fit..I don't think it is anything major, just due to the larger guards...Something to do with the support bar or something????
yeah thats the one... stuff it then i'll just get the GTR Front Guards, Front Bar and some Side Skirts... and the boot lip if possible
I think the grille might actually be part of the GTR bar???
can someone with a GTR clear this up, or is this a seperate piece..
If the GTR bar that is for sale comes with the grille as well, as one piece... I will definitely buy one in the next couple of weeks...
in relation to making it sticky - pm a mod...
for teh grille, no its a seperate peice, like, form what i have been told, it screws on to these holes on the sides of teh headlights..well i aint sure on if its screws.. but thats where its held on..
its not part of the front bar.
    • Working through possible solutions of converting my mechanical speedo.    Anyone know what type of speedo sensor the factory r34 gtr getrag has ? what the output is ? I assume its not a VSS and more a voltage like earlier speedo sensors ? Can an ECU read it ?
    • roof rail delete used to be a thing, they were made locally for a while too
    • I can get more photos of it here soon and I plan to make a thread detailing the process. I received the car this way and it sorely needs refinishing. That is probably the most appealing photo of it. Up close it is fading, cracked, and needs to be re-glued. Depending on their condition I'm on the fence between refinishing or making a new set.  Another angle hiding the pimples and razor pumps
    • According to this thread the RS4V with build plate RC40 comes with the R200 diff @ 4.083 ratio as well (mine has said RC40 denotation). We may need to check if the axle stubs are the same pattern as well. The auto subframes have longer axles. However I think yours being a later Series 2 as well, we should have the same bolt pattern for the diff stubs. Unless your upgraded rear also has upgraded axles. Either way, I would not be opposed to pulling the covers to check so I can inspect that  fancy rear core  Also I don't have HICAS. I don't believe that should change things but I hope the people here with heaps more experience than me can correct me if I'm wrong   Let me know if you want to attempt to make this work and I can get some pictures of mine from under the car.
    • It's not that straightforward. For example I have had this code because my ignitor/power transistor wires were unplugged. It knows something is wrong but has no idea what it means. If you want to actually diagnose this I recommend following the service manual flowchart for code 21. Ohm out the harness, coilpacks, inspect the ECU, etc. And again, it's entirely possible for there to be no problem at all but if you're running a different coilpack it'll trigger the code because it doesn't like what it sees.
