  • Replies 140
Yeah too right krishy
I canned the 4wd turbo for now
can't trust mike,bloody hopeless!
Putting a deposit down on deans black c34 laurel later this week
the stagea originally went up for sale so I could by it,so to sound completely gay,think it was meant to be mine
Just going to give everyone a quick update then I think I'm done
after speaking to just cars in regards to the aftermarket parts that were on the car that weren't covered on my policy,I was informed that I have every right to get those parts back and to put the standard items back
the only thing that I wasn't allowed to takewas my wheels,whatever,the laurel is 4 stud anyways
parts I got back today,with the help of chef
full exhaust including my sweet sweet straight pipes!
Gtr seats
boost controller
taillights
260 rear bar
my dash cluster
rear flares
adjustable wastegate actuator
rear wing
my shark fin off the roof
all in all,those parts minus my front mount and wheels were every thing I wanted off it to keep anyways
so my advice to others is if you don't ask your insurance company what you are entitled too,they won't tell you
so hassle the shit out of them like I did
payout will be thro this week,so I'll pick up the laurel then,then it all starts again
can't wait!
Thanks to everyone who helpedout or at least offered through out this situation
you truly are a wonderful bunch of people to say the least
stay tuned to see what I can do with this laurel!
Peace out
I was looking at the pickles auctions and I think this might be your car coming up
Looks like you can have the chance to buy your stagea at pickles auctions next week
http://www.pickles.com.au/damaged/vehicle/...2116450/lotid-0
Nah,I won't be buying it back brad
got most of the good stuff off it already
although it does still have a front mount,lowered springs and a decent front lip on it and my work wheels
be interesting to see what it goes for,but I can't see them getting the 4grand for it that they wanted from me to buy it back
    • I wanted to try and preserve the front bumper as long as possible, they're not cheap and are made to order in Japan. Taking inspiration from my previous K11 Micra build where I made an undertray for the Impul bumper, I did the same for this BN Sports bumper but a little slimmed down.  This time round I only made a 'skid plate' (if that's the correct wording/term) for just the bumper surface area, the Micra version covered the gap like an undertray. Starting off with a sheet of mild steel approx. 0.9mm thick 4ft x 2ft in size. I traced around the bumper, cut it out and cleaned the edges. Luckily I was able to get two halves from one piece of metal In the video I installed it as is, but I've since then I've removed it to spray and add a rubber edging trim. The rubber trim is suitable for 1-2mm and it's a really nice tight fit. The bolts had to be loosened due to the plates being too tight against the bumper, the trim wouldn't push on I used some stainless M6 flat headed bolts for a flusher finish (rather than hex heads poking down), I believe this style fastener is used for furniture too incase you struggle to source some. The corner's are a little wider, but this may be an advantage incase I get close to bumping it  The front grill got some attention, finally getting round to repairing it. Upon removal one fixing pulled itself out of the plastic frame, one side is M8 that fixes inside of the frame, where as the other side is M5. Not knowing I could get replacements, I cut down an M8 bolt, threaded it inside the frame along with a decent amount of JB Weld.  The mesh was replaced to match the bumper. One hole on the bonnet/hood had to be drilled out to 8mm to accommodate the new stud, once the glue had set it could be refitted. I think the reason the grill was double meshed was to hide the horn/bonnet latch (which makes sense) but I much prefer it matching the bumper Bumper refitted and it's looking much better IMO The Youtube video can be seen here: https://www.youtube.com/watch?v=bVZP35io9MA
