After a week of brr brr brr coming outa the exhaust & car shaking & driving like absolute shit.
I did the coilpack trick to no avail and eventually went to see David from DMD-Tuning as we knew the coilpacks were shot when we boosted up to 14PSI. They started to breakdown upon higher boost so we swapped them over with his 2nd hand ones he had for a tempory fix but it didnt change. removed all spark plugs and noticed one was all gunged (if such a word) up. cleaned them & put em back but still was like it had a very lumpy cam on.
he hooked up his laptop with Nistune loaded and listed to my standard (returned) ecu and one by one he disabled the coilpacks and noticed the drop in RPM until he came accross cylinder one and there was no drop in RPM..ah ha dead spark plug, replaced with a spare and now back to normal.
He's a bloody genious....
Thanks heaps Dave if you see this.................
Dazza
https://www.sau.com.au/forums/topic/336419-car-sounding-driving-like-a-wrx/
Was In the process of doing this Paul when i read you msg.
yeah Dave had a personal family hospital issue that neaded attention hence his awol with his mobile. I did opologise to him re heaps of messages left (none were nasty though)
I did mention to him that you had spoken to him and said your a great guy... lol
Dazza
    • The wideband reading is meaningless if it's not running. Why are you using shitty old sidefeeds on any engine, let alone a Neo? What manifold and fuel rail are you using to achieve that? Beyond that, can't help you with AEM stuff as I've never been their ECU/CAS combo.
    • Manual boost controllers (where a little of the boost was bled off) were quite common back in the day, because they were cheap and easy. Generally they had a manual adjustment screw rather than being fixed like yours. Down side is they always bleed boost, not just when you want them to so an electronic boost controller that uses a solenoid will have less lag.
    • Hello , im new here and i have A31 home build  RB25det neo stock eng / turbo  aem ems 2 blue connector  aem 3.5 map aem cas disk aem wideband connected to ecu  355 lph pump 550 nismo yellow injectors side feed aftermarket regulator  and won’t start with base aem tuner basic tune eventually flipped cas 180 degree so it triggers on correct stroke not in exhaust cycle  Now it won’t start Wideband reads 10 and 11 at lowest fuel setting  and will share calibrations soon for aem tuner i think something is wrong in aem tuner    please if you have any information, am very grateful
    • Legend. I ended up finding the facebook account of the owner of the first car i sent but sadly he deactivated the account. I think you’re right in saying it’s some sort of well done custom job. Really appreciate your help anyways.
    • Totally equivalent. Stock often goes from the comp cover because that's where the actuator is also installed and the factory needs 2" of hose to make the connection - and it comes as a pre-assembled unit. They totally have a boost reference from somewhere between the turbo and the throttle(s). Oh, jeez. Just do it in M12 then. We don't actually care that much. I would expect any such AN converter fitting to rely on an o-ring or some other seal onto a flat surface under the flange of the hex**, because bolt threads are no intended to provide a pressure seal. unlike..... pipe threads. **which also requires a suitably flat and smooth surface on the turbo's boss to provide the seal.
