Hey fella's...
Got a question for ya's where I need a bit of help or real advise on somethin please....
Got a Aeromotive A1000 fuel pump where it was running good for the first 200-300 k's and then recently while driving it's started making a louder noise as if it's still actually priming while driving. One thing I've noticed is that once it starts making this noise when i'm driving the car, it doesn't feel like it's getting enough fuel cause it feels like it's running on 5 cylinders, etc. The engine is getting enough fuel and that to keep running but if I try to accelerate more it just stutters along and then gives up at some stage and doesn't want to move.
It'll start fine when it's cold though and it'll run for a good 30-40k's and that and then once (my opinion here) it's hot (like after driving the car around for a period of time), it just doesn't want to work properly anymore.
Keen to know if anyone else has had this problem or know of this problem with these fuel pumps?
Last night I was ready to actually rip the pump out, throw it on the ground and take a sledge hammer to it. LOL
Look forward to hearin from anyone that can advise or help out with this guys :P
Can anyone else maybe recommend a replacement for this pump as well maybe?
Edited by street-gtr
https://www.sau.com.au/forums/topic/336482-aeromotive-fuel-pump/
Hey fella's...
Look forward to hearin from anyone that can advise or help out with this guys :)
How much power ou making? What injectors?
A couple of hours ago, went and started it since leaving it in the garage from last night.
Started and primed perfectly fine and then once oil temp reached around the 60 mark, it started making the loud noise again.
Hadn't rev'd it or even driven it, had been sittin there for a good 10-15mins warming up.
check voltage at the pump. check for leaks and blockages in the lines and make sure the fuels not getting too hot
Hi
All braided lines and have been tested for blockage and nothing.
only around about 260hp for now.
can't remember the injectors sorry, around 1000cc though.
Did you just pick a random sub forum to post this in or did you think the question was appropriate to be posted in the rb30 conversion section?
no, it's cause i've actually got a rb30 bottom end buddy :)
1000cc with 260hp? .. wha ..
yeh, on run in tune right now. sorry.
I had something simalar to this and it was hard to find. Ended up being the pickup was collapsing on itself. When you took it out and looked at it, it looked fine, no blockage. But under load it collapsed and created a blockage.. Just a thought you could check.
As soon as I found it and replaced it, the pump was perfectly quiet.
Interesting... I highly suspect that there's nothing wrong with the pump to the extent to say "its broken, get a new one"... cause it primes ok and starts and feeds fuel to the engine still, etc so i'd say it could be something as small as this maybe.
How did you fix it? What was the problem
one of the plugs to the relay wasn't plugged in.
soon found this out when i was checking the fuses.
Doesnt it shit ya when people ask for help with a problem, fix it, then dont pass on the info that could help someone else.
yeh, it does shit yah when people don't have much time to come on and post everything about it hey... considering that 'fixed' post was posted from my iphone.
lol. always something simple.. what sort of ampage does the a1000 pull? ive seen a bosch 044 burn out a 30 amp relay.. (more to do with the poor contact with some aftermarket relay holders melting
not to sure mate.
the pump ended up being f**ked after only running on one relay.
some people who think they have a idea on how to do this shit really have no idea.
now i'm up for a new pump!!!
From what I have seen with A1000 pumps is that they really are a race use only pump, aimed at drag racing where they are only switched on for a few seconds.
From memory they are a reconfigured carburettor pump so origionally designed to run at 7-10PSI, just happens that they are big enough to push 100psi when attached to a EFI reg.
Doesnt help solve the issue I know, but just a heads up for the future.
Same goes for most Yank Pumps (SX, Magna Fuel etc)
A1000 isn't much of a pump... they fail regularly in the US circles (im in the us for the last 5 years).
Look at weldon for a good solid reliable pump.
Any pump combo you get you will need some style controll. staged, pwm etc...
    • Well GTSBoy, prepare yourself further. I did a track day with 1/2 a day prep on Friday, inpromptu. The good news is that I got home, and didn't drive the car into a wall. Everything seemed mostly okay. The car was even a little faster than it was last time. I also got to get some good datalog data too. I also noticed a tiny bit of knock which was (luckily?) recorded. All I know is the knock sensors got recalibrated.... and are notorious for false knock. So I don't know if they are too sensitive, not sensitive enough... or some other third option. But I reduced timing anyway. It wasn't every pull through the session either. Think along the lines of -1 degree of timing for say, three instances while at the top of 4th in a 20 minute all-hot-lap session. Unfortunately at the end of session 2... I noticed a little oil. I borrowed some jack stands and a jack and took a look under there, but as is often the case, messing around with it kinda half cleaned it up, it was not conclusive where it was coming from. I decided to give it another go and see how it was. The amount of oil was maybe one/two small drops. I did another 20 minute session and car went well, and I was just starting to get into it and not be terrified of driving on track. I pulled over and checked in the pits and saw this: This is where I called it, packed up and went home as I live ~20 min from the track with a VERY VERY CLOSE EYE on Oil Pressure on the way home. The volume wasn't much but you never know. I checked it today when I had my own space/tools/time to find out what was going on, wanted to clean it up, run the car and see if any of the fittings from around the oil filter were causing it. I have like.. 5 fittings there, so I suspected one was (hopefully?) the culprit. It became immediately apparent as soon as I looked around more closely. 795d266d-a034-4b8c-89c9-d83860f5d00a.mp4       This is the R34 GTT oil sender connected via an adapter to an oil cooler block I have installed which runs AN lines to my cooler (and back). There's also an oil temp sensor on top.  Just after that video, I attempted to unthread the sensor to see if it's loose/worn and it disintegrated in my hand. So yes. I am glad I noticed that oil because it would appear that complete and utter catastrophic engine failure was about 1 second of engine runtime away. I did try to drill the fitting out, and only succeeded in drilling the middle hole much larger and now there's a... smooth hole in there with what looks like a damn sleeve still incredibly tight in there. Not really sure how to proceed from here. My options: 1) Find someone who can remove the stuck fitting, and use a steel adapter so it won't fatigue? (Female BSPT for the R34 sender to 1/8NPT male - HARD to find). IF it isn't possible to remove - Buy a new block ($320) and have someone tap a new 1/8NPT in the top of it ($????) and hope the steel adapter works better. 2) Buy a new block and give up on the OEM pressure sender for the dash entirely, and use the supplied 1/8 NPT for the oil temp sender. Having the oil pressure read 0 in the dash with the warning lamp will give me a lot of anxiety driving around. I do have the actual GM sensor/sender working, but it needs OBD2 as a gauge. If I'm datalogging I don't actually have a readout of what the gauge is currently displaying. 3) Other? Find a new location for the OEM sender? Though I don't know of anywhere that will work. I also don't know if a steel adapter is actually functionally smart here. It's clearly leveraged itself through vibration of the motor and snapped in half. This doesn't seem like a setup a smart person would replicate given the weight of the OEM sender. Still pretty happy being lucky for once and seeing this at the absolute last moment before bye bye motor in a big way, even if an adapter is apparently 6 weeks+ delivery and I have no way to free the current stuck/potentially destroyed threads in the current oil block.
