it'll mainly affect idle. if the rest of the map is good then it should idle much better. when i went from stockers to 555s i used the settings i posted on the previous page (albeit with a pfc) and it started straight away and ran perfectly, even drove it that way for a few weeks.
I can't see anything on the page?
It says the part about:
"This is by far my most popular addition, a preliminary version has been in circulation to Nistune users for some time. So those who don't use Nistune, here it is"
But then bellow it is a white screen?
Everything else on the site looks to work though. Good website by the way man, you do it yourself?
dunno bout every voltage but it should be close enough. im assuming when you enter +.18 into the power fc it just uses the same correction accross the board
yea in the pfc there are the two columns(injector) that you enter the change in size% and one for the change in ms...this is on the hand controller
Now noticed in datalogit there is the same two columns as the hc and also an Inj lag(ms) vs. batt V table similar to the Vipec table so do you adjust anything in this table when you change the injectors or just the two column (injectors) table and leave it at that??
PM-R33 .... maybe vipec has this same overall setting change in the software so you dont need to change that actual table you mentioned??
U don't have to adjust the ms/Volt table unless ur AFR changes when electical loads are applied to the engine.
Then to set it disconnect ur alternator and as the volt slowly decrease set the ms/Volt table at the current Voltage to keep the AFR at idle constant.
what about the minimum injector pulse width?
I've adjusted my lag time to work well, but when I'm say cruising on a slight down hill, and only slightly touch the accelerator, i get spluttering, i watched and noticed my AFR's leaned out in this situation.
Am i correct in thinking it's got more to do with minimum pulse width than injector lag times?
fine with no throttle, fine with normal throttle. It's just that really low almost like resting the foot on the pedal kind of throttle.
When i say lean i mean about 17-18:1
14.7 with low throttle, 20+:1 (no fuel) with no throttle. But just the interchange between throttle and no throttle basically.
using NIStune with seimens deka injectors
    • ..this is the current state of that port. I appreciate the info help (and the link to the Earls thing @Duncan). Though going by that it seems like 1/4 then BSP'ing it and using a bush may work. I don't know where I'd be remote mounting the pressure sender... to... exactly. I assume the idea here is that any vibration is taken up by the semiflexible/flexible hose itself instead of it leveraging against the block directly. I want to believe a stronger, steel bush/adapter would work, but I don't know if that is engineeringly sound or just wishful thinking given the stupendous implications of a leak/failure in this spot. What are the real world risks of dissimilar metals here? It's a 6061 Aluminum block, and I'm talking brass or steel or SS adapters/things.
