Hi fella.
I currently have a headunit running 2 front speakers and 2 rear 6x9". I have a 400watt boss amp running my 10" sub. Now my 6x9" speakers sound shithouse....distort to early......what should i do? Im a n00b.
*new 6x9's?
*run another amp for rear speakers? If i run another amp how i do it...i aleady running an amp for sub
cheers!
https://www.sau.com.au/forums/topic/33697-help-setting-up-my-car-audio/
yeah, i'd be inclined to ditch the 6x9s like nugget said. 6x9s are only useful for bass when u dont have a sub, but when ur looking for a bit more clarity its time for them to go. Plus if ur running them off ur head unit, they're probably underpowered which doesn't help.
  • 4 weeks later...
yeah chuck the 6x9's out or sell them. 6" splits in the front and 6" coax in the rear, shit all over 6x9's. they distort cos the sound comes out the same spot for low mid and high range, cos you have each speaker behind itself. whereas with split you have a good 6" cone for main low and medium and for high you have a seperaste tweeter. mount the little tweeter set on the backplate of your mirrors, put sound backing/deadning on your 6" cones and it will sound schmick, very good indeeed. you need the sound to come from the front
most people focus on bringing the sound from the back, should be from the front
try and amp all around if you can, amp some and not others is pox and nasty. i agree it is cheaper but if you good sound spend the dollars, mkuch like a car, you want a good car, spend the $ and get good, not 80% good, 100% good
get a fairly stock 4 channel amp and amp your front splits and rears, will sound good
either amp them all or none, amping just subs sounds random and out of whack
worst case yif you are on a tighjt tight budget get front splits, amp them and normal rears. keep the subs or sub amped and amp the front splits. will sound, but better with rears amped too, and not 6x9's amped, 6" coax amped
my system in my 33 =
alpine cdx9807 cd/mp3 head unit 50wx4
alpine 6" pro splits in the front with the tweeter mounted on the mirror mounts
alpine 6" coax in the rear parcel shelf
alpine 2 x 12" subs in the boot, standard box
alpine monobloc amp for the subs, no idea on what wattage, can give model number
alpine 4 channel amp for the front splits and rear coax's
alpine rca to random AINET adapter so i can get sound from my dvd player
total cost including install was 1800 , head unit is aorund 500 ish, subs are fairly expensive, same with splits and coax's, all fairly decent stuff, not the best i agree, but **** it cranks
and also you can crank and stereo but it needs to sound good and clear
i can crank the head unit to like 24 on an original cd audio (not mp3) and it ****ing sounds awesome. mp3 obviousloy not as good, they lack quality.
if youre in melb, can give a demo
no offence, shop around, i wouldnt goto strathfield. yeah their sales droids will say oh we can sell u this setup for 200 cash less, blah blah. less cash price existed in 1980, not anymore
speak to some audio buff's, find out what u want, get a non biased opinion. ask fhrx. get work out a budget and say i want this from this
dont goto them with a problem, goto them with a requirement, let them work out how to make it happen and give you the solution
    • Yes I can see how that would put you off HFM, especially with the price of good quality brake fluid. From what I understand it as you say the BM50 is the standard BMC for a R32 GTR, I must admit I would like to go far a Genuine Nissan BM57, but lack of cash prevents that at present. With the price being so close between the genuine BM50 and BM57 a BM57 New it seems a better choice as you gain that 1/16 bore size with the BM57, I would be interested in how much difference you feel with the BM57 fitted. I am going to take SteveL's advice in the short term and see how much actually comes out of that proportioning valve vent and save up for the Genuine Nissan part. Thanks for clarifying the HFM failure
    • Thanks mate. I just got the post inspection 1/2 done from state roads when the starter motor packed up, either that or the car alarm system is having trouble.  OEM part number 23300-AA112.
    • Hi, I though I was coming to an end in finding a replacement starter motor for a rb25de neo. I came across a starter motor from Taarks and a message below stating: Direct fit. 11 Tooth count. All below part numbers have been superseded to 11 teeth. Can some body shed some light on going from 8 teeth to 11 teeth apart from 36-month / 25,000 km warranty for passenger vehicles to 12 Month Warranty. Compatible with the following Nissan part numbers: 23300-20P00 23300-20P01 23300-20P05 23300-20P10 23300-20P11 23300-AA111 23300-AA112 23300-AA300 23300-08U10 23300-08U11 23300-08U15
    • Low battery? Maybe check capacity? I know first-hand, on BMWs if your battery drops below 80% capacity, it starts causing strange issues.
    • 8.5 +37 = should fit rear, but I think it'll hit on front. What you want is low 30s/high 20's front, mid 30's rear. That 17" screenshot you posted looks good, I'd run it on my R32 (but that's long dead now). For tyre sizes, my rule of thumb is: 8': 235, 9": 255. But that's just my opinion. Nismo sizes: 18x8.5+35/18x9.5+38 is a good starting point.
