hey guys, had an accident last week.. got cut off on highway and hit barrier at 110km/h.. got out of it ok.. i think my air flow meter may be screwed.. it idles fine just once you come on boost it starts missing pretty bad.. almost like its actually running on 5 cylnders.. sounds like a wrx.. well a sick one! anyway i got home and let it idle for a few seconds and thought i heard a wierd sound.. so i take off the pod.. and put my ear up to the air flow meter..and sure enough.. i hear a little sound.. sounds like a bell!!!! WTF! like a little bell just ting.. ting.. etc.. is my turbo on its way out.. the car still felt pretty strong before the accident and i have never noticed this sound b4? any one know anything? any help would be great. by the way this is a rb20det.
cheers.
https://www.sau.com.au/forums/topic/33702-weird-noise-from-turbo/
:upurs: nah, its funny because you drive down there pretty much any day and see all these cars that have like hit the side barrier, and its like 5 lanes and so open wide viewing angle the whole way to the GC and everything.. it makes the Monash and Ring roads in melbourne look like narrow roads so i'm not sure people manage it!
Thats some nice whoring.
I'd take it to a profesional for an opinion. Maybe pull the af meter off and havea look to see if anythings loose in there, check wiring hasn't been crushed in the inner guard if the car was an auto before the conversion.
Probably pull the front pipe off and have a look in the turb to see if you can see any chips in the blades and have a feel for play in the shaft. BB turbo should have very little shaft play.
Unless somethings fallen off the af meter then the turbo shouldn't have eaten anything though.
.. i was heading into brisbane, in the left lane and some **** head decide to take my lane.. he was going quick and there was a car ahead of him.. so he cut me off.. predator.. before you open your uselss mouth about shit you dont know nothing about go to your kitchen and get a glass of shut the hell up.. call me a fool for running into the barrier.. f**k you! bhdave, DJ_L3ThAL thanks for the replys.. ill have to pull the turbo off and check it out.
Just take the pipe from the compressed side off and look for "shiny bits" first. May save some work.
remember a turbo spins way quick so if it was interfering anywhere it would sound like a squeal
"interfering...squeal" sounds like gordo and DJ with their 14 yo :)
took everything off bar the turbo and there doesnt seem to be any signs of anything. the turbo wheel spins freely and there is no metal shavings.. there is very little play in the turbo as well.. hmmm.. but i guess when its spinning as fast as it would when i come on boost if there was a tiny bit of play it would get worse????
    • sold listed as a Tomei LSD 1.5 Way For 1998+ Nissan Skyline ER34 25GT RB25DE w/Open R200 https://www.ebay.com/itm/174006114594?campid=5338967980&mkevt=1&mkcid=1&toolid=10050&customid=&mkrid=711-53200-19255-0&loc_physical_ms=108689&loc_interest_ms=&campid=5338967980&mkevt=1&mkcid=1&toolid=10050&customid=71883f2ccc571356e0a757bc7adfdde2&mkrid=710-53481-19255-0&loc_physical_ms=108689&loc_interest_ms= it went in like butter all gears, alignment, back lash etc, rotation and clearances correct, and if rolling all rotates smooth and free when coasting down road , clutch in or out over 10 mph smooth... its the binding, clunking and jerking from a stop that is most concerning, also seems like its going to tear the tires off in 10 miles of normal road driving.
    • What 1.5 way? There's no such thing really as a 1.5 way, just different ways of explaining 2 ways with different ramp rates. HOWEVER. In any driving in a straight line your 1.5 or 2 or 1.7 way should have no clunking at all. With the clutch fully depressed the diff should be silent (unless it's welded but I'm assuming it's not). Something aint right here.
    • Clutch is a spec brand, new clutch system,( PP, flywheel, friction disc, etc. pull type) installed 100 miles ago, with no problems.
    • looking for some help and maybe some insight on others experience with a new LSD. R34 GT ran and drove beautifully, but always alot of grip loss due to the open R200 rear end, so I just installed a new 1.5 LSD way into the stock open R200 for a ER34. Simple. Everything seemed right. I test drove for the first time this weekend. as I started to back out the garage the first time slowly with tires straight it sounded and felt like I had a loose or half disconnected drive shaft...that was clucking around loose and shaking entire vehicle, and making it feel like the trans clutch was spontaneously slipping then grabbing very roughly while just letting out pedal slowly. I backed it out went to pull forward with the same noise, shake and slip grab feeling with hesitation, I turned the tires to back out more and then pulled ahead some same thing but worst because of added wheel resistance (which that I expected) puzzled … pulling it back in checking everything over and finding nothing wrong, I tried it the next day. same thing, couldn’t believe how it shook everything again making a terrible noise and making it feel like the trans clutch was slipping and grabbing, but I got it out of garage into the driveway, got it straight, drove forward and then reveres a few times in a straight line everything shaking , causing what felt like clutch slip and grab every time, sounded like right behind front driver tire and I could feel it in the floor board with my feet,... worst right when beginning to let clutch pedal out to engage slightly, shuttering and sounding terrible along the way…I managed to slowly get down the road, babying it the whole way, once I was rolling (out of 1st) seemed to be better and between shifts, then clutch felt closer to normal…not slip/ grab etc., but back down to any stop, straight road or turning, same thing. Made no difference if all tires were straight or if I was turning. All other gauge read out correct. with in 2 miles as planned I reached the empty parking lot and performed the break in procedure that came with lsd, essentially to drive in a figure 8 a bunch.  Did this, binding chattering, and shaking the car the whole way. I drove it back home seemed somewhat normal once I was in straight line and past 10 mph or so, and I know it will “bind” on corners and cause some tires squeal when turning especially from a stop, but when I begin to move it still causes what feels like the trans clutch to slip and jerk badly as well as shaking the entire car, and sounds terrible, that I didn’t expect. I used the fluid they supplied with LSD kit and did the breaking, planning to change fluid as they suggest after breaking, but wondering will it get smoother or less aggressive with use? maybe a 1.5 is just too aggressive for normal road driving?   I have a LSD that I put in my 71 cuda when I restored it, with amazing smooth , quite yet effective results. Different style LSD but that ones a joy to drive. maybe expecting too much from this R200?
    • Join SAU NSW for a flame-grilled feed & flame-spitting cruise! Sunday 17th August 2025 3:30PM Meeting Archies Flame Grille Sylvania Waters 4:45PM Cruise Departure 5:15PM Arrival at Cape Solander Kurnell Meet Location: Archies Flame Grille Final Destination: Cape Solander Kurnell *Disclaimer* There will be a lead and follow car so no one should get lost. If you would like to attend or bring others along please put your name down and a +1 as numbers will be needed prior! This is NOT a race and we will all be adhering to all road rules. If this is what you want please come to one of our many track days. This is an official SAU:NSW event and will be run under a CAMS permit. One of the things that really sets our club apart is our commitment to being true enthusiasts. When on normal roads we strive to maintain good relations with the authorities as well as the public in general. When attending one of Skylines Australia NSW events please try to: • Be aware of surrounding environment and act accordingly. • Drive courteously on the state’s roads as a true enthusiast should. • Understand how important it is to maintain the good name of SAU NSW and thus, treat others accordingly. • Any misbehavior will not be tolerated and you will be asked to leave.
