Ok ill try and explain it as clear as possible. First of all the problem is on an RB25DE R33 Series 1.
Maybe 1 month ago the problem worsened and the car would cut out and not rev past 2500, would die on idle and sounded like a rotary. So took out the AFM and resoldered the joints inside.
Now the car is drivable, when you first start it, without throttle it will die. Starting with throttle works but for the first 30 seconds if there is no throttle the revs drop below 500 and will die unless you accelerate.
When driving the car it runs fine until about 3k and if you change gears at this point it's fine but if you put your foot flat to the floor the revs climb extremely slow after about the 3k mark and is hence really slow. My point is that the AFM is stuffed or the wiring because the lower revs are fine because its better lean but once it hits the higher revs when its supposed to richen up it doesn't and therefore is really slow. (Incorrect signal from AFM?)
I took the cover off the AFM and with the key switched to on the AFM reading was 0.25v give or take 0.05v. On idle the reading was 1.5volts so only a bit higher than the 1.1v that it should be. When i revved it i didn't see it go past 3volts.
Firstly are these readings acceptable or should i just replace the AFM?
Secondly i tried checking the voltage of the plug to see if this was a problem by measuring the reading of the negative terminal on the AFM plug and the earth of the car and got 0 volts. The manual did not suggest what is right or wrong for this test.
The manual suggested to test the ECCS relay and ECCS loom.
Is the ECCS relay behind the computor(behind passenger kick panel)??
Any help is useful, i want to get it fixed by the end of the holidays so i can drive it to school :P
https://www.sau.com.au/forums/topic/337044-faulty-afm/
Eliminate the possibilities one at a time. Swap the AFM - if that doesnt solve it, move onto the next item. Check the ECU loom (and even try swapping one) make sure there is no dodgy looking wiring (eg. cut wires with bad connections). I'd also definitely be inspecing coils, plugs, ignitor module, even fuel pump. It is a 17 year old car - maybe even your injectors are worse for wear...
Maybe even try doing a diagnostic / check for error codes
hope you sort it out mate, good luck
https://www.sau.com.au/forums/topic/337044-faulty-afm/#findComment-5450629
Have you tried running the car with afm unplugged...
I had a dodgey afm
Mine ran fine with it unplugged but wouldnt idle and sounded like a rotary when it was plugged in...That said i didnt try driving it whilst unplugged but it idled fine..
not really sure why this is but try it...
https://www.sau.com.au/forums/topic/337044-faulty-afm/#findComment-5450648
Thanks for the suggestions, shold of mentioned but didnt want to ramble... Ive got new superspark ignition coils in the car, i pulled out the injectors and had them cleaned. I did run the car with the AFM unplugged but didnt go for a drive, the thing is the problem is only when driving the car that it doesnt rev freely, when in nuetral its fine.
As for diagnostics check before resoldering the joints it showed error code 12 - AFM and still shows the same thing, i did reset the computor. Ive put different plugs in it recently but i might change em back cause i wasn't too sure about them, im thinking if it's the ignitor then it wouldn't start so i don't think its that but it's just a thought.
I might test the fuel pump too, it does make the buzzing noise when turning the key to on which i dont remember it doing but ive got a poor memory and dont have any cars to compare with.
I dont want to buy a new AFM and it turns out its not that thats the problem, i dont want to waste too much money
https://www.sau.com.au/forums/topic/337044-faulty-afm/#findComment-5450799
Alright thanks for the suggestions, the best option is to replace the AFM because it is 17 years old so hopefully i can get one new for cheap around here. If i still have problems then i'll do the checking of the loom.
https://www.sau.com.au/forums/topic/337044-faulty-afm/#findComment-5451881
  • 9 months later...
    • Have a look at that (shitty) pic I posted. You can see AN -4 braided line coming to a -4 to 1/8 BSPT adapter, into a 1/8 BSPT T piece. The Haltech pressure sender is screwed into the long arm of the sender and factory sender (pre your pic) into the T side. You can also see the cable tie holding the whole contraption in place. Is it better than mounting the sender direct to your engine fitting......yes because it removes that vibration as the engine revs out 50 times every lap and that factory sender is pretty big. Is it necessary for you......well I've got no idea, I just don't like something important failing twice so over-engineer it to the moon!
    • Yup. You can get creative and make a sort of "bracket" with cable ties. Put 2 around the sender with a third passing underneath them strapped down against the sender. Then that third one is able to be passed through some hole at right angles to the orientation of the sender. Or some variation on the theme. Yes.... ummm, with caveats? I mean, the sender is BSP and you would likely have AN stuff on the hose, so yes, there would be the adapter you mention. But the block end will either be 1/8 NPT if that thread is still OK in there, or you can drill and tap it out to 1/4 BSP or NPT and use appropriate adapter there. As it stands, your mention of 1/8 BSPT male seems... wrong for the 1/8 NPT female it has to go into. The hose will be better, because even with the bush, the mass of the sender will be "hanging" off a hard threaded connection and will add some stress/strain to that. It might fail in the future. The hose eliminates almost all such risk - but adds in several more threaded connections to leak from! It really should be tapered, but it looks very long in that photo with no taper visible. If you have it in hand you should be able to see if it tapered or not. There technically is no possibility of a mechanical seal with a parallel male in a parallel female, so it is hard to believe that it is parallel male, but weirder things have happened. Maybe it's meant to seat on some surface when screwed in on the original installation? Anyway, at that thread size, parallel in parallel, with tape and goop, will seal just fine.
