Forwarding on some info on this:
Is a Oz delivered KMGC210
has L26
S.U. Carbie, suck through for turbo, manifold & turbo in the boot.
Yellow in colour, beige velour interior, GL model
51,800km (wow)
multi-spoked alloys (sound similar to the R30 Ti rims)
https://www.sau.com.au/forums/topic/337538-210-turbo-coupe/#findComment-5458252
Looking at that coupe gave me flash backs of what mine looked like before i spent a zillion on it. You really have to like them in a big way, it's easy to see this one requires a lot spent on it and unfortunately these cars aren't everyones taste so selling later will mean your going to lose money unlike maybe a LJ Torana is possibly an investment. But I do love my JAPORANA as the guys at work call it. It's different and around here quite rear, so it gets plenty of attention especially with the V8 rumble.
https://www.sau.com.au/forums/topic/337538-210-turbo-coupe/#findComment-5459378
That's an old 'Creations' kit; TO4, 32mm Garrett Wastegate and it looks to have a Stromberg rather than SU (mine had a 2" Jag SU on it when I bought the same sort of kit in '97). Laggy as hell on an L24, let me tell you...
:P
https://www.sau.com.au/forums/topic/337538-210-turbo-coupe/#findComment-5461167
    • https://www.facebook.com/share/19kSVAc4tc/?mibextid=wwXIfr
    • There is a guy who said he can weld me piping without having to cut chassis, maybe I do that ? Or do I just go reverse flow but isn’t reverse flow very limited once again?
