I bought this last friday, to replace my impreza, which will fund a work ute
its clean as, auto :-( , and a tight and responsive L24e $850 with 2 months rego
I have 2 5 speeds and a spare L24e from a C210. I was wondering if anyone has
everything else to convert to manual (pedal box, clutch master and line, stick,
console rubber and floorpan seal) and if the yoke is the same with auto and manual
feels good to be back in a skyline, any help is appreciated
https://www.sau.com.au/forums/topic/337928-my-new-daily-drive/
damn.
thanks guys for your help
there is a datsun wreckers in Castlereagh, Sydney, that has a straight C210 coupe
minus engine, gearbox and most of interior if anyone wants it. Has rust in boot, but is worth saving. also 2 MR30 sedans
His name is Carlos, he's a reasonable bloke, have a chat to him
http://www.sportsclassic.com.au/
^^^ Carlos Casmiri ^^^ Rally dude and hoarder of Zed Parts.
You need the tailshaft and speedo cable from the manual, as well as the clutch pedal and the bolt/rod thing that goes through the manual pedal box...
I reckon that, the Auto and Long Manual box would be the same length (didn't measure) so you might be able to use the Auto Tailshaft with a Long Box... but the gearstick will be a few cm further back in the hole...
Biggest problem is going to be the crossmember... the Auto Tunnel is about 10cm wider than the Manual Tunnel, so you are trying to bolt the gearbox crossmember into thin air... Auto one crosses the transmission in a completely different spot, and bolts through the floorpan at different levels, so you will have a slight complex fabrication job...
Cheers,
Daewoo
heeheehee i like that
Im hoping to find a complete manual at the wreckers. nothing in sydney, goulburn has a couple of auto's. i will find one!
thought that would be the case with the long box, so i wont use this option.
Ill be able to fabricate the crossmember no worries. I think my biggest drama will be getting hold of the complete conversion.
This is all very useful info, Thanks daewoo, muchly appreciated!
When you do, can I have one :(:rofl::D ... all progress on mine stopped about 3 months ago when I hit this hurdle, and lost interest... as the teachers all said "Daewoo is easily distracted"...
Two things... the short boxes are in short supply, only ever used in MR30s and Stanzas... and, the plate that holds the input shaft bearing (or whatever it's real name is) is Aluminum, so prone to shitting themself... before I bought it, I would be taking that plate off and seeing if it is faxed, if it is, the plate is the same as a 'K' box, but it usually faxes the whole front housing (which you can also just swap for a 'K' one)...
As it is just a Daily, probably not a big deal...
Cheers,
Daewoo
Edited by Daewoo
Rushy (Pick n Payless) at Blacktown doesn't have any ?????????
Take a drive down to Dapto Pick a Part, they have 5 MR30's down there and I think 2 were manuals complete when I was there last Thursday.
I wasn't looking for manuals persay, but will if you like as I should be down there this week after picking up my manifold from a guy nearby. (Extreme Turbo Manifolds)
Cheers, D
Dapto don't know what they have!
Last Thursday they told me they had ONE (1) but I found FIVE (5) so maybe the four (4) they don't have are manual lol
I'm going back to Extreme Turbo Manifolds on Thursday morning, so I will stop in to Pick a Part and look. If I find I'll take some pickies for you as proof.
Cheers, D
Ok! Been to Dapto today and as usual, they don't know what they have and there was one manual, but the pedal box was being removed when I was there and the rest had gone, if the guys taking out the pedal box already didn't have it.
PM me with what you need for this manual conversion and I'll see what I have spare.
Cheers, Dennis
thanks for that ghostrider. wreckers people are generally pretty dumb, like the guys in Melbourne,
crushed the C210 coupe after having it for only a week and everyone wanting stuff off it
Mag86, i need the whole lot, seeing as the C210 5 speed is too long
Do R32 gtst's use a stubby box? i know is a lot smaller than the R33 box.
had a thought, RB25 n/a and a R32 box. what do you guys think?
Also bought a DR30 series 2 instrument panel, techo goes to 9000!
but all the connections are different to the stock instrument panel.
ill upload a pic asap
Your going to have a problem fitting your S2 instrument cluster into an S1 car. All your connections are diferrent, so you're going to have to rewire or maybe replace the instrument loom. Don't know if the latter is possible, but rewiring would be.
The R32 box can be used but it needs an L series front housing on it. As Mags says Stewart Wilkins will do the mod for you. The gear lever is going to come out of the tunnel a little further back in the hole, which isn't a huge biggie issue.
I was originally going down the RB25DE conversion until I stumbled across my PNV and decided to keep it a bit stockish. It's a relatively easy conversion and been done to bits, along with the RB30E conversion.
I'm about to have a huge cleanout of accumulated bits, so if your interested let me know.
Cheers, D
This is what you want if your going to do it easy!
http://cgi.ebay.com.au/Nissan-DR30-Skyline...=item58867ab14f
If you buy this, take it to South West Instruments at Smeaton Grange and he will modify it for you. He did my S2 cluster a few years ago.
Cheers, D
Yo! here is my instrument cluster
I like how yours goes to 260km/h. ill think about that one
that cluster itself will justify a engine transplant :-)
The series 2 dash KILLS the series 1 dash!
thanks andrew, good info!
engine exchange isnt a huge priority at the moment
might do it in 6 months or so
ghostrider, when you do your clean out, if you can gather a
complete 5 speed conversion, including tailshaft,
and also series 1 hotplates in good condition. If you have
all this, and we can talk price.
thankfully, you dont live too far from me
I read somewhere that for ideal air supply, the plenum
volume is matched with engine displacement, and double engine
displacement for n/a engines. cut 3 sides off the stock plenum
smoothen the inlet runners and tig up a 2.4l volume plenum.
dont know if im dreaming now, but a RB30 throttle body and airflow meter
to a aftermarket ecu?
The 260km/h speedo is very difficult to get these days, as Jenesis wont trade outside of the domestic market. One sold on ebay (complete cluster) recently for a little over $200.00 and the Tomei variety 240km/h gets onto Yahoo in Japan a bit often but landed it would cost in excess of $600.00.
When you look at the back of the S1 cluster, you will find it entirely diferrent to the S2.
I might have an Aussie S2 dashboard harness in a grey dash under the house that you can play with if you like. I'll have a look over the weekend and let you know.
Mechanical parts I will be reluctant to let go because I have 2 x KHR30 Paul Newman coupes & an DR30 coupe track car that need maintaining. A stock tailshaft I might have, as I'm upgrading one of my PNV's to the stronger larger DR30 tailshaft. The companion flange might be an issue because all my R30's came out with R200 diffs.
Probably the only box I have that I would be prepared to let go is an HR31 RB20DET box.
The RB30E throttle body isn't much better than the one you have now. The next one up is the 60mm KA24E (U12 Pintara) or RB25DE throttle body and with an a/mkt ECU you wont need an AFM at all, as it will most likely use an MAF sensor.
As for an inlet plenum, you might find it's more cost effective to extrude hone or power port the manifold. I have an N42 (non EGR) 280ZX inlet manifold that has been comcoated, that I might be tempted to part with, or maybe a stock 280ZX EGR manifold, depending how your bent.
    • Bummer...yeah i "need" something to "ease" up the work and for my driving it would be enough.    Iam counting the tune "without" turbo. I do not mean "cheap" like something from Temu around 200 USD, "Cheap" is something around 1000 USD?
    • Starter motors used to use the weight of metal (magnets) to provide torque. Now they use (more) current instead. This. It's completely normal.
    • So thing that had me stumped, but I think is OK....is that when it was up in the air, in neutral I had it running to bleed to coolant while I put the wheels back on. I noticed the rears were turning (slowly) which I'd never seen before 20250928_163512.mp4     Because there had been an issue with clutch slip due to pedal adjustment on the dyno, I assumed there was still and issue so spent some quality time upside down under the dash adjusting the pedal....but no matter what I did the wheels still turned in neutral. Even disconnected the master cylinder to pedal rod and same. In despair, I even removed the clutch slave so there was no chance of any preload causing it.....still happened. So either: 1. Something is not right in the bellhousing, or 2. Its a thing sometimes with cold, thick gearbox oil Internet says it might be 2, I hope so!
    • OK, few more things sorted and it is ready for a shakedown on 10-Oct, with one weird thing. Changed the run in oil and filter for the good stuff. 8l came out, about 8.5 went in with filter so that looks all good. Changed the starter (again), this time for a brand new one, works good. Interesting that the Taaaarks one is shorter than factory but spins harder, I guess electronics have moved on a little in the last 30 years. Will be nice to have a bit of extra space under there. Put the timing cover back on, and noted where the cam gears were set as a record.  Will need to double check the timing but it is pretty close. Also put the coil pack cover and intake snorkel back on. Exhaust Inlet Changed the water out for coolant, bled up nicely. Removed the rear brake pads (well worn factory sumitomo ones!), gave the hardware a good clean and reassembled. I've put bendix XP on the back again because the price is excellent at $150 a set and they worked well on the V37. Front pads have plenty so no issue there
