Gday lads, thought id give a quick report on how i went with this mix
So methanol was $260 205l drum, bp98 $1.?? a litre. and with e85 costing us $550 for 205l here in perth i thought it would be worthwhile giving this ago.
result was 560hp at 21pounds and we ran out of fuel system, as an idea we ran 527 at the same boost level.. but the methanol mix picked up through the middle
would i do the methanol mix again.. probably not, will just finish of this drum and will be trying e85 next
and just so you guys know methanol is poisonous and corrosive it is illegal to be used on the street, even mixed with the petrol it is a very strong methanol smell when burning
details on the build
R32 GTR
ENGINE
built engine
stage 2 hks 272 cams
hks cam gears
TO4Z Garrett
6 boost
48mm turbo smart gate
twin z32 afms
fuel system
sx fuel pump,surge tank,-8 lines
1450 fuel injector clinic
sard reg
https://www.sau.com.au/forums/topic/338301-methbp98-mix/
Why did you go Methanol instead of Ethanol?
I can not see any advantages...
was sittin with a good mate that runs methanol in his burnout car and after a few discussions and some research we thought we'd give it a go..
plenty of positives for it lad(e85 in perth is $2.68 per litre my methanol/petrol mix worked out at $1.35 a litre half the price and just as much power potential), unfortunately for me it didnt go as planned, i underestimated the fuel system required.at a guess if i ran another sx pump and some id2000's i have no doubt we would be seeing over 650.BUT i am pretty sure if i run e85 with the same setup i have now i will have the same issue with not enough fuel system..
e85 50% 50% bp like you have used is probably what i will try next, if it doesnt perform the way i want i will upgrade the fuel system too a monster setup
my setup is methanol safe ie. i run a seperate fuel cell in the boot, all lines are teflon, pumps are meth safe, injectors are meth safe. and also this car is not a street car, it isnt even licensed, i would not suggest for anyone to use this type of mix if they were planning on driving it daily or were not prepared to flush the system and store the fuel correctly.
https://www.sau.com.au/forums/topic/338301-methbp98-mix/#findComment-5467761
Ran this tune around the track at powercruise for the weekend.. very impressed, feels much stronger through the whole rev range compared to my pump tune.
anyone ever done this mix and successfully made power? any fuel system guru's that could tell me what i need to upgrade to reach my 26-27 psi boost level?
or could the methanol be reduced and the bp increased? what sort of effect on octane does this have?
will still be giving e85 a shot but just curious to give this another crack too..
https://www.sau.com.au/forums/topic/338301-methbp98-mix/#findComment-5480834
the engine bay wiring was the least of my worries tryin to get that car to powercruise man :thumbsup: haha we were still adding terminals to the main battery terminal on saturday morning!! mostly fuel system sh*t, that will eventually be hidden to a junction box somewhere.. yeah was lookin for ya on the cruises, but we were never on the same cruise eh.. saw brockas in my mirror once coming down to the main straight and was hopin for a run.. but he wouldnt come play!! he may have been leavin track or something.. anywayssss
e85 will happen.... but i have a drum of methanol i have to do something with :D
https://www.sau.com.au/forums/topic/338301-methbp98-mix/#findComment-5480901
http://www.skylinesaustralia.com/forums/E8...80&start=80
old news but is a alternative for E85 if you cant get it somewhere.
yeah been following that thread too trent!
Its a convenience thing for me aswell, for example last weekend i was at powercruise here in perth and camped up with some of my v8 mates who run on methanol, so there was plently of methanol to go round..
at the end of the day, i dont drive this car on the street.. and its as simple as undoing and switching two -8 fuel fittings from cell to main fuel tank and flushing with pump 98.. for long term storage.
another thing people may be interested in.. after running 180litres of this mix, my oil is still fine.. i was concerned about it milking up but have had no issues YET.
https://www.sau.com.au/forums/topic/338301-methbp98-mix/#findComment-5481859
    • Back again. I returned to Japan in Jul/Aug to spend time with the car on my birthday and remind myself what all the sacrifice and compromise is for. It happened to line up with the monthly morning meet in Okutama, which I have been wanting to go to for a long time. It's a unique event at a unique spot with really rare, interesting, and quirky cars. It's where all the oldheads and OGs gather. The nighttime scene at DKF certainly has its place and should be experienced if you're into cars, but there's too much bad attention and negativity around it now. IMO the better time is Sunday morning at DKF or Okutama; it's more chill and relaxed. I'm glad I was finally able to go, but not sure it's worth the drive from all the way from Nagoya immediately the day before, unless I was already staying in Tokyo for the days right before the meet, because you have to wake up quite early to make it in time. Funnily enough though I didn't drive the car all that much this trip because it was just too damn hot. While there were zero issues and running temps were nominal and the A/C was strong, RBs already run crazy hot as it is. Sure, it took it all like a champ but something about driving these cars in the ridiculous heat/humidity bothers me and makes me feel like I'm asking too much of it. I'm just me being weird and treating the car like a living thing with feelings; I'm mechanically sympathetic to a fault. Instead I was mainly driving something else around - a KX4(silver) 2001 X-Trail GT, that I acquired in May. There's a few different flavors to choose from with Xs, but visually it's the Nissan version of the Honda CR-V. Mechanically it's a whole different story as this, being the top-trim GT, has an SR20VET mated to a four-speed auto and full-time AWD! It was a very affordable buy in exceptional condition inside and out, with very low mileage...only 48k kms. Most likely it was owned by an older person who kept it garaged and well-maintained, so I'm really happy with how it all worked out. It literally needs zero attention at the moment, albeit except for some minor visual touch-ups. I wanted something quirky, interesting, and practical and for sure it handily delivers on all three of those aspects. I was immediately able to utilize the cargo and passenger capacity to its full extent. It's a lot of fun to drive and is quite punchy through 1st and 2nd. It's very unassuming -in the twisty bits it's a lot more composed than one would think at a glance- and it'll be even better once I get better tires on it(yes, it's an SUV but still a little boat-y for my liking). So...now I have two golden-era Nissans in silver. One sports car and one that does everything else; the perfect two-car solution I think👍 The rest of the trip...I was able to turn my stressed brain off and enjoy it, although I didn't quite get to do as much as I thought. I did some interesting things, met some interesting people, and happened into some interesting situations however, that's all for another post though only if people really want to know. Project-wise, I went back to Mine's again to discuss more plans and am hoping to wrap that up real soon; keep watching this space if that interests you. Additionally, while working in the tormenting sweatbox that is the warehouse, I was able to organize most of the myriad of parts that my friend is storing for me along with the cars, and the 34 has a nice little spot carved out for it: And since it can get so stupid hot in there, that made it all the more easy -after I was standing there looking at the car and said 'f**k it'- to finally remove all the damn gauges that have mostly been an eyesore all this time. Huzzah. The heat basically makes the adhesive backing on the gauge mounts more pliable to work with, so it was far less stressful getting this done. I didn't fully clean it up or chase the wiring though; that will happen once I have the car in closer possession. Another major reason to remove all that stuff is to give people less reasons to get in my car and steal s**t while it's being exported/imported when/if the time comes, which leads us to my next point... ...and that is even though it's time in Japan is technically almost up since it's a November car and the X would be coming in March, I'm still not entirely sure where my life and career is headed; I don't really know what the future looks like and where I'm going to end up. I feel there's a great deal of uncertainty with me and as a result of that, it feels like I'm at a crossroads moreso now than any point in my life thus far and there are some choices I need to make. Yes, I've had some years to consider things and prepare myself, however too much has happened in that time to maintain confidence and everything feels so up in the air; tenuous one might say. Simply put, there's just too much nonsense going on right now from multiple vectors. Admittedly, I'm struggling to stay in the game and keep my eyes on the prize. So much so in fact, that very recently I came the closest I ever have before to calling it quits outright; selling everything and moving on and not looking back. The astute among you will pick up on key subtext within this paragraph. In the meantime I've still managed to slowly acquire some final bits for the car, but it feels nice knowing there's not much left to get and I'm almost across that finish line; I have almost everything I'll ever want for my interpretation and expression on what it is I think an R34 should be. 'til later.
    • Thanks for that, hadn’t used my brain enough to think about that.
    • Also playing with fire if they start to flow more air down low than what the stock twins can. It's not even up top you need to worry, it can be at 3000rpm and part throttle and it's getting way more flow than it should.
    • Any G40/1000 or G40/1250 results out there?
    • You still want a proper tune on the stock ECU though. Stock tune + stock ECU with GT-SS/-9s is probably playing with fire if you're running more than stock airflow/power.
