  • Replies 82
you will get the one EXACTLY SAME ON badak -my skyline...:rofl: as shown on link
i live in southbank, whiteman st
just contact me before 13th and make a time for the deposit
0431 040 070
otherwise have to wait till my ex.bf come back to take over this business for me coz i have to work.
thankyou:)
Just a bit more info for everyone.....
The supplier has ran out of the GTS badges....They informed me that their currently waiting till they've got orders of approx 250-300 before placing an order with the supplier....so far they reckon they've got about 80 + some more from their NZ office so it looks like it might take awhile before anything happens :rofl:
pfft good luck getting that many orders.
Do you have a pic of the badge? coz i know plenty of places that will laser cut one and i wont need to order 1 million before they do it!
Wanna pick this one up for us then and get a price on the laser cut ones Denham? I'll pre-pay if they are a reasonable price. We could customise with our own coloured "S" if they were all silver
Someone needs to give me a good scale picture of it so it can be entered into the cnc machine.
or i will take a GTR badge and replace the R with a S. That would work wouldnt it?
Yeah...I've got a picture of one but the photo was taken at an angle not straight on....Do you want me to scan it and post it up?????
    • Yup. You can get creative and make a sort of "bracket" with cable ties. Put 2 around the sender with a third passing underneath them strapped down against the sender. Then that third one is able to be passed through some hole at right angles to the orientation of the sender. Or some variation on the theme. Yes.... ummm, with caveats? I mean, the sender is BSP and you would likely have AN stuff on the hose, so yes, there would be the adapter you mention. But the block end will either be 1/8 NPT if that thread is still OK in there, or you can drill and tap it out to 1/4 BSP or NPT and use appropriate adapter there. As it stands, your mention of 1/8 BSPT male seems... wrong for the 1/8 NPT female it has to go into. The hose will be better, because even with the bush, the mass of the sender will be "hanging" off a hard threaded connection and will add some stress/strain to that. It might fail in the future. The hose eliminates almost all such risk - but adds in several more threaded connections to leak from! It really should be tapered, but it looks very long in that photo with no taper visible. If you have it in hand you should be able to see if it tapered or not. There technically is no possibility of a mechanical seal with a parallel male in a parallel female, so it is hard to believe that it is parallel male, but weirder things have happened. Maybe it's meant to seat on some surface when screwed in on the original installation? Anyway, at that thread size, parallel in parallel, with tape and goop, will seal just fine.
