Hey guys! need some advice / help! got my car serviced recently and ever since then the car has been running pretty crappy! I cant figure out what it is, it runs fine mostly, but when i let go of the throttle i can feel a vibration coming through the car, can feel it through the drivers seat and through the foot rest where the clutch would be (cars auto), that whole left side vibrates, not dramatically, but enough to notice easily. It seems to get worse on lower revs and i can't figure out what it is, coil packs and plugs are fine, car was running fine before the service. The car doesn't sound the same as it used to either, seems to be more quieter than normal on idle and as i said when i rev upto like 2K and then slowly let og of the throttle i can feel the car vibrate and then become stable again, really weird! HELP!
car: R33 Gts-t Auto
mods: turbo back exhuast, Pod, R34 Side mount, bleed valve boosted to around 9-10psi and SAFCII tuned by RE customs
what the service guys did:
change plugs
change belts (not the timing though)
oil change
auto transmission fluid change
thanks!
https://www.sau.com.au/forums/topic/338375-vibration-issue/
Auto transmission issue perhaps. I've been in cars, particularly VN/VP commonwhores and similar year falcons that were a bit iffy on decel. It was as though the box wasn't sure if it was manual or auto, seeing as auto boxes essentially put the clutch in when you let of the throttle.
Might have put in the wrong transmission fluid or something
https://www.sau.com.au/forums/topic/338375-vibration-issue/#findComment-5468548
ye i was thinking the same thing! might have to flush it and put a new batch in! but can you really go that wrong with auto tranny fluid?
https://www.sau.com.au/forums/topic/338375-vibration-issue/#findComment-5468567
    • http://calfinn.com.au/product/1500kg-standard-trolley-jack-cj-2t-c/1500kg-standard-trolley-jack-cj-2t-c   I have this and fits under a S3 33 GTR with no issues. Purchased in 2009 and not one issue. It was $950 back then. Not cheap but something so important isn’t worth cheaping out on.
    • Just trying to get my head around this. At 5psi of boost, you turn on your wmi pump, and then you're using a 3000cc injector, to allow flow upto the actual engine, where you have your 6x200cc injectors and a 500cc injector. If the above is correct, what advantage are you obtaining by having the 3000cc injector blocking flow, is this just incase a line breaks between that injector and the motor you can stop flow immediately? Or are the 6x200cc and 500cc less injectors and just spray nozzle?
    • Welcome! New member myself, but I had an R33 back in 2002. Best advice I could give, based on my experience: if you're running the factory turbo, be very conservative with boost. I made the mistake of just fiddling around with the boost controller and cranking the boost for fun, and the end result was my intake pipes popping off frequently from the constant deluge of oil that was being blown into the recirc by the stressed-out turbo, which itself was siphoning oil from the engine and farting it out both sides of its centre bearing (or something to that effect). If I could do it all again, I would have gotten a new turbo and had a tune dialled in professionally and then just left it alone! Funny you mention the metal shavings in the gearbox, as I had the same thing - the probe plug (magnetic drain plug, essentially) would come out caked with shavings. At least it was doing its job. Not sure if that's just sacrificial wear and part of the deal, or if my gearbox was shagged, but I wasn't abusing it. Enjoy the R33 - they're a dying breed, and if they weren't $35k+ on CarSales in Queensland, I might have picked up one of those again, instead of the 370GT I own now (though I'm loving the 370GT, that big 3.7L V6 just hits different).
    • Howdy folks. I owned an R33 back in 2002, which was thoroughly beyond my capacity (financially speaking) to maintain/insure, so we parted ways in 2004. Fast forward 21 years (to literally yesterday, in fact) and I'm now the proud owner of a 2007 V36 370GT. I'm happily surprised by how much power the VQ37VHR makes, compared to the RB25DET, considering the latter is turbocharged. I had planned to add a turbo at some point but I'm on the fence about whether I'll even need it (though I do love the sudden onset of extra torque). Any other 370GT owners around the traps, I'd love to hear about your experiences with this car (good and bad).
    • Perhaps the answer is... more jacks!* *proper jacks must be used.
