recently after picking up the missus i noticed my oil light was on, naturally i freaked out pulled over and turned the car off. when i started it again the warning didnt go away it was still there but dim. no idea whats going on since then ive changed my oil everyday to no avail the lights still dim and from what i can tell i have good oil pressure and its filled correctly. any help will be appreciated
Cheers Jason
Shitty sensor. As I've read many times on here in either the Forced Induction Performance forum or General Maintenance, the stock sensor/gauge is shitty. If you KNOW you have pressure, and that your oil isn't low, invest in an aftermarket gauge and sensor.
I'm not going to attempt to diagnose your cars issue (if there is one at all), but for reference, I have recently hooked up an aftermarket oil pressure gauge into my car (also a S2 R33), and its pretty clear now that the stock gauge doesn't really have a clue whats actually going on. Specifically, my stock gauge only seems accurate +-2BAR (ie. inaccurate), and is very, very unresponsive.
my stock gauge seems to be working fine how ever i do have an autometer gauge which i havent installed yet. its it hard or expensive to replace the sensor?
bit the bullet and finally connected my autometer prolite comp oil pressure gauge, on idle my car floats at 40-50 psi and goes all the way to 90 psi under load. i have a crazy feeling nothing bads happened but the senders def gone... may have something to do with flushing my radiator the other day... water went everywhere :happy: anywho im still not sure and im taking to to japspec tomoz to get it sorted cheers for the replys
What revs are you seeing 90psi at? shouldnt get that high until around 5-6k rpm, if you are seeing that sort of pressue at around 3000 you may have ring seal issue or the PCV breathers might be blocked, dont wanna scare you by saying that, but something to look out for.
cheers for the head up, i am seeing that PSI at 5-6k rpm so im assuming my oil pump is healthy. just got it back from japspec sensor got wet and short circuited but i also got my nismo twin plate put in... never experienced anything like it hahaha :)
Jason
    • https://www.facebook.com/share/19kSVAc4tc/?mibextid=wwXIfr
    • It would be well worth deciding where you want to go and what you care about. Reliability of everything in a 34 drops MASSIVELY above the 300kw mark. Keeping everything going great at beyond that value will cost ten times the $. Clutches become shit, gearboxes (and engines/bottom ends) become consumable, traction becomes crap. The good news is looking legalish/actually being legal is slighly under the 300kw mark. I would make the assumption you want to ditch the stock plenum too and want to go a front facing unit of some description due to the cross flow. Do the bends on a return flow hurt? Not really. A couple of bends do make a difference but not nearly as much in a forced induction situation. Add 1psi of boost to overcome it. Nobody has ever gone and done a track session monitoring IAT then done a different session on a different intercooler and monitored IAT to see the difference here. All of the benefits here are likely in the "My engine is a forged consumable that I drive once a year because it needs a rebuild every year which takes 9 months of the year to complete" territory. It would be well worth deciding where you want to go and what you care about with this car.
    • By "reverse flow", do you mean "return flow"? Being the IC having a return pipe back behind the bumper reo, or similar? If so... I am currently making ~250 rwkW on a Neo at ~17-18 psi. With a return flow. There's nothing to indicate that it is costing me a lot of power at this level, and I would be surprised if I could not push it harder. True, I have not measured pressure drop across it or IAT changes, but the car does not seem upset about it in any way. I won't be bothering to look into it unless it starts giving trouble or doesn't respond to boost increases when I next put it on the dyno. FWIW, it was tuned with the boost controller off, so achieving ~15-16 psi on the wastegate spring alone, and it is noticeably quicker with the boost controller on and yielding a couple of extra pounds. Hence why I think it is doing OK. So, no, I would not arbitrarily say that return flows are restrictive. Yes, they are certainly restrictive if you're aiming for higher power levels. But I also think that the happy place for a street car is <300 rwkW anyway, so I'm not going to be aiming for power levels that would require me to change the inlet pipework. My car looks very stock, even though everything is different. The turbo and inlet pipes all look stock and run in the stock locations, The airbox looks stock (apart from the inlet being opened up). The turbo looks stock, because it's in the stock location, is the stock housings and can't really be seen anyway. It makes enough power to be good to drive, but won't raise eyebrows if I ever f**k up enough for the cops to lift the bonnet.
    • There is a guy who said he can weld me piping without having to cut chassis, maybe I do that ? Or do I just go reverse flow but isn’t reverse flow very limited once again?
