You call him and tell him i dont care if its written off you can take them. Better being a a functioning care instead a whore that will be goin to the auctions soon i just wish they would let me take the kit off it
  • Replies 51
Are they stock coils or aftermarket? I'm assuming stock, or you'd want them yourself :) I'm willing to throw some $ your way for the stock coilpacks swap if you're serious about it, and not just in a 'don't give a f**k' mood about the car. You might as well get something back. Where are you located? I'll be swing past Boostworx in the morning if you want to tag along and see what you can remove :D
Hey ruby yeah thats cool i live in norwood i have to get shit out of car of my missus and i need to get my grill off it anyway so yeah give me a buzz and ill meet you there if you like what time do they close. 0407792160
I'll be swinging past Boostworx about 9-9.30am. Bit late now, so I'll SMS you tomorrow when I'm leaving in about half hour.
:D
