  • Replies 43
Yeah, I admit it does look a bit like Megatron, but I reckon the official pics, when they come out, will do it justice.
In the end I think I could put up with the looks for Veyron-matching performance capabilities.
Hottest car on the face of the earth.
And when you have a car that weights under a tonne and can do 0-100 in 2.5 seconds, you're allowed to make it look anyway you want to because if anyone says anything about them, simply challenge them to a race. When they back the f**k down, laugh at them from the drivers seat of your ugly car and then drive off.
here's a bunch of 'teaser' shots previously released,
1. Bonnet:
2. Engine cover:
3. Dash through to cabin (seat and steering wheel in background):
4. Wheel:
5. Possibly the world's sexiest seat through to steering wheel:
6. Rear vent with spoiler base:
It is over the top. But so is Lamborghini in general.
You shouldn't buy a super car (esp a Lambo) if you want something subtle.
I thinks its awesome.
Astin Martin DBS.
The best super car in my opinion. No its not the fastest, but it is the epitome of style, class and power. It still looks badass but it does it in a classy way not by raping your eyes with over the top styling.
The DBS may not be the fastest around a track but I know that every supercar out performs my driving ability so really the fact that its not as fast is basically meaningless to me.
Merc and Gall are both still secksy though. This one just missed the mark.
Edited by person
    • OK, so a bunch of trim needs to come off to get to the rear shock top mounts. Once the seat is out of the way, the plastic trim needs to come off. Remove 2 clips at the top then slide the trim towards the centre of the car to clear the lower clip Next you need to be able to lift the parcel shelf, which means you need to remove the mid dark trim around the door, and then the upper light trim above the parcel shelf. The mid trim has a clip in the middle to remove first, then lift the lowest trim off the top of the mid trim (unclips). At the top there is a hidden clip on the inner side to release first by pulling inwards, then the main clip releases by pulling the top towards the front of the car. The door seal comes off with the trim, just put them aside. The the lighter upper trim, this is easy to break to top clips so take it carefully. There is a hidden clip towards the bottom and another in the middle to release first by pulling inwards. Once they are out, there are 3 clips along the rear windscreen side of the panel that are hard to get under. This is what the rear of the panel looks like to assist:
