finally got my baby back on the rd...
yeah REAL good on back support... they dont have as much movent like the GTST seats but they dont need em... they like mold to ur back... heaps comfy... a really decent upgrade.
piss easy to put in... maybe 10mins for each seat... just make sure when ur putting any seat in u never tighten the bolts until all bolts are in and remember to put the belt clip back on.... which i forgot after installing the first one... which was a pain the arse to get on when the seat was bolted in :D
for the cost factor id just go GTR.... they look sweet... suit the rest of the interior and bolt str8 in. Aftermarkets cost more and generally dont come with the right rails. Sure they probably offer more support (and are WAY harder to get in and out) but who needs that much more support ALL the time on the rd?
yeah i guess you are right...
i havent done any research yet on the aftermarket items, but i have sat in a few GTR's and seats look and feel quite good...and if they bolt straight in as you say, might be the way to go...
just worried about how they would look with the rest of the sII interior...do they just come in one colour???
Do they offer any more head room? I need seats that sit lower by at least an inch, or 1/2 an inch with a skin head as well.
I dont like the idea of shaving my head!
mine sit pretty low... im 6ft 2-3 and can fit in with a hat on or even a helmet with 2inches of room to the roof... BARE in mind however i dont have a sunroof which means anyone with a sunroof will still have the same issues
lmao no worries.
if u live anywhere near dingley we can meet up tomorow cause ive got to get a few things to clean it up a bit like front tyres and some paint for the wipers and stuff.
    • Hi,  Just joined the forum so I could share my "fix" of this problem. Might be of use to someone. Had the same hunting at idle issue on my V36 with VQ35HR engine after swapping the engine because the original one got overheated.  While changing the engine I made the mistake of cleaning the throttle bodies and tried all the tricks i could find to do a throttle relearn with no luck. Gave in and took it to a shop and they couldn't sort it. Then took it to my local Nissan dealership and they couldn't get it to idle properly. They said I'd need to replace the throttle bodies and the ecu probably costing more than the car is worth. So I had the idea of replacing the carbon I cleaned out with a thin layer of super glue and it's back to normal idle now. Bit rough but saved the car from the wreckers 🤣
    • After my last update, I went ahead with cleaning and restoring the entire fuel system. This included removing the tank and cleaning it with the Beyond Balistics solution, power washing it multiple times, drying it thoroughly, rinsing with IPA, drying again with heat gun and compressed air. Also, cleaning out the lines, fuel rail, and replacing the fuel pump with an OEM-style one. During the cleaning process, I replaced several hoses - including the breather hose on the fuel tank, which turned out to be the cause of the earlier fuel leak. This is what the old fuel filter looked like: Fuel tank before cleaning: Dirty Fuel Tank.mp4   Fuel tank after cleaning (some staining remains): Clean Fuel Tank.mp4 Both the OEM 270cc and new DeatschWerks 550cc injectors were cleaned professionally by a shop. Before reassembling everything, I tested the fuel flow by running the pump output into a container at the fuel filter location - flow looked good. I then fitted the new fuel filter and reassembled the rest of the system. Fuel Flow Test.mp4 Test 1 - 550cc injectors Ran the new fuel pump with its supplied diagonal strainer (different from OEM’s flat strainer) and my 550cc injectors using the same resized-injector map I had successfully used before. At first, it idled roughly and stalled when I applied throttle. Checked the spark plugs and found that they were fouled with carbon (likely from the earlier overly rich running when the injectors were clogged). After cleaning the plugs, the car started fine. However, it would only idle for 30–60 seconds before stalling, and while driving it would feel like a “fuel cut” after a few seconds - though it wouldn’t fully stall. Test 2 – Strainer swap Suspecting the diagonal strainer might not be reaching the tank bottom, I swapped it for the original flat strainer and filled the tank with ~45L of fuel. The issue persisted exactly the same. Test 3 – OEM injectors To eliminate tuning variables, I reinstalled the OEM 270cc injectors and reverted to the original map. Cleaned the spark plugs again just in-case. The stalling and “fuel cut” still remained.   At this stage, I suspect an intermittent power or connection fault at the fuel pump hanger, caused during the cleaning process. This has led me to look into getting Frenchy’s fuel hanger and replacing the unit entirely. TL;DR: Cleaned and restored the fuel system (tank, lines, rail, pump). Tested 550cc injectors with the same resized-injector map as before, but the car stalls at idle and experiences what feels like “fuel cut” after a few seconds of driving. Swapped back to OEM injectors with original map to rule out tuning, but the issue persists. Now suspecting an intermittent power or connection fault at the fuel pump hanger, possibly cause by the cleaning process.
