Hey guys as the Title says im lookin for a good builder in sydney to do my forged 26 , ive asked a few people and they all just wanna recommend their mates so im tryin to get a wider prospective, Have done a search and Proengines seem to be a popular choice so far, if theres anyone else that is a known expert on rb26 then id appreciate it if yas let us know
cheers Joe
Edited by GTR_JOEY
https://www.sau.com.au/forums/topic/338725-recommened-rb26-builders-in-sydney/
lol Mir u wouldnt happen to work at 17 would ya? yeah ive spoken to unigroup, they're definatly on my list atm as ill be gettin it tuned there, cheers TBAG
Joe
Ahhh, so its you hey, I seen this 32 sitting out the back of the workshop, though it was dumped so I stripped it, LOL.
What was the verdict, piston ?
cheers guys ill hit those workshops up and see what they can do, what sorta price range to do the rebuild for yas?
lol, its still insured mate so can u take the whole thing, I put it in the shed out back if ur still lookin for it haha
ahh got the head off yesterday and its got damage to the piston in the valve clearance, looks sorta pitted, still doesnt really explain 0 compression though, have to check the rings now.
hmm the pitting is on both valve reliefs and the valves look ok.... ive come with the terms that i want a forged rebuild and im goin to put some decent power through it anyway, in additon the engine was put together like crap, done 12,000kms since the build and its got oil leak, loose bolts, rust on the inlet cam lobes... just a rubbish job and im not puttin 600hp through it casue it wont last lol
croydon racing.
they might be abit more expensive but i wouldnt trust anyone else. quality of work and attention to detail is amazing.
they built my 26 (600 hp) and havnt had a single problem and they were extremley helpful through out the whole build which was a year ago now.
u dont want sum1 who is just going to slap the engine together and send you on your way
This is another one where people need to refer to THIS...
There are too many people with varying experiences at different workshops, so the best bet is to make a few calls or visits to workshops YOU'VE got in mind and make up YOUR OWN decision based on how comfortable YOU are with the information YOU'VE been given.
Guest
    • After using a protractor for an actually accurate assessment of what is required,  and by NOT using my uncalibrated eyeball I worked out I need a 25° silicone bend from the TB ro the MAF, but, my choice was either a 30° or a 23° (23° is a weird spec), so I grabbed the 23° one from Raceworks I also grabbed 1mtr of 3" straight from Just Jap, I needed 350mm, but they only had 300mm, or 1mtr lengths....meh Also ordered a 1/2" hose bulkhead fitting from fleabay, this has a smoothish mushroom looking head (they are designed for below the water line of boats) that will fit inside the bend, the hose bit and threaded bit looks to long, but nothing that a hacksaw cannot fix if required, the hose will then just get jamed on the threaded bit up to the retaining nut Fingers crossed and the unsightly amount of hose clamps will be reduced down to 4 once all the parts arrive
    • Oil change does not trigger code 21. Code 21 is for coilpacks primary side connection. You can try to clear the code with a battery disconnect, hold down the brake pedal to drain capacitors through the brake lights with the ignition on for 10-15 seconds before you reconnect the battery. I have seen R35 coil conversion permanently cause this code with no ill effects so it might be the resistance it wants to see isn't quite right on one or more coilpacks. Could be inside the ECU, could be the harness, could be a coil. You can test it all if you want or just ignore until the car actually starts misfiring.
    • I forgot you have a Nistune ECU. Use Nistune to do all the tests I mentioned instead of faffing with 30+ year old electrical connectors. You can read MAF volts off that too, there are reference values in the service manual to tell you roughly what it should be in different conditions.
    • No. I think it might be the AFM. Hence the use of the terms "swaptronics", which implies the use of swapping out electronics for the purpose of diagnosis. It's about the only way to prove that a small/niggling/whatever problem with an AFM or a CAS or similar is actually caused by that AFM/CAS/whatever. A known good item swapped in that still gives the same problem is likely to be caused somewhere else. They're all the same. Spraying AFMs with cleaner is an each way bet between cleaning it and f**king it.
    • Oh wow! This might actually work amazingly. Do you know the ratio of the diff? I was told the only thing you need to make sure of is if the front & rear diff ratios are the same. Ours is a 4.083 Thanks!
