Hey guys,
At the moment i have a RB25DET with a front facing plenum, front mount, exhaust etc. I will be adding come injectors, manifold and a TD06H 20g 10cm external gate.
I have the opportunity of getting a Link G3 for $500 and im just wondering if i should get it or not as from what i can see it seems like it would handle my setup quite easily but im not sure?
thanks,
Andrew.
https://www.sau.com.au/forums/topic/338874-link-g3/
Hey guys,
thanks,
Andrew.
That's a good price if you are buying it from someone and you know its working well. Otherwise its like any second hand piece of technology - great if it works waste of money if it doesn't.
https://www.sau.com.au/forums/topic/338874-link-g3/#findComment-5475681
Link has more capacity and abilities than Nistune. Nistune is normally better value for money (although will not work with R33 ecu and you will have some adapting to do) but if you can get a Link for $500 that will be a better buy. Any Vipec dealer should be able to tune a Link. Here is a link to the factory ...you can get info from their tech dept:
http://www.linkecu.com/
https://www.sau.com.au/forums/topic/338874-link-g3/#findComment-5475961
    • But first....while I was there, I also swapped across the centre console box for the other style where the AV inputs don't intrude into the (very limited !) space.  Part# was 96926-4GA0A, 284H3-4GA0B, 284H3-4GA0A. (I've already swapped the top 12v socket for a USB bulkhead in this pic, it fit the hole without modification:) Comparison of the 2: Basically to do the console you need to remove the DS and PS side console trim (they slide up and back, held in by clips only) Then remove the back half of the console top trim with the cupholders, pops up, all clips again but be careful at the front as it is pretty flimsy. Then slide the shifter boot down, remove the spring clip, loose it forever somewhere in the car the pull the shift knob off. Remove the tiny plastic piece on DS near "P" and use something thin and long (most screwdrivers won't fit) to push down the interlock and put the shifter down in D for space. There is one screw at the front, then the shifter surround and ashtray lift up. There are 3 or 4 plugs underneath and it is off. Next is the rear cover of the centre console; you need to open the console lid, pop off the trim covering the lid hinge and undo the 2rd screw from the driver's side (the rest all need to come out later so you can do them all now and remove the lid) Then the rear cover unclips (6 clips), start at the top with a trim tool pulling backwards. Once it is off there are 2 screws facing rearwards to remove (need a short phillips for these) and you are done with the rear of the console. There are 4 plugs at the A/V box to unclip Then there are 2 screws at the front of the console, and 2 clips (pull up and back) and the console will come out.
