  • Replies 51
Posted Images
Hi Enjoy your R34 mate. The Nismo aero kit is kinda out there, but still looks great. Even better once rear wing is off. Fat as. What have you got planned for your beast???? I have just bought my 3rd skyline (r32,r33,r34) a r34gtt auto with 92,000kms . I bought for 9k. I have a manual gearbox/clutch etc with pedal n master cylinder so I'll be changing that over to. I did hear a story that the the auto ecu is different though. Anyways there a great car. My next is a R34gtr as this gtt will be my daily driver. Every car I've owned has been a Nissan. Had Sivia's to. Lol.
We generally meet up on Friday nights here:
http://maps.google.com.au/maps?f=d&sou...008256&z=18
In the carpark parallel to the lake on that "Menindee Dr" road. There's a thread labeled "Friday night NOT at museum" here, people generally post in there when they're heading out. Meet time is usually 9:30 onwards.
Otherwise we occasionally do other things like dinners and whatnot...sometimes we go for a cruise randomly, but I think most people couldn't be stuffed as there's a lot of other wankers in their commonwhores, WRX's, Lexus (Lexii?), and Beamers who give other drivers on the road a bad name and bring attention.
On the note of your car, I reckon it wouldn't look too bad at all if you removed the wing completely, then got yourself some new rims - say, R34 GT-R rims. Perhaps even sprayed black. Would look pretty sweet then :down:
Looks quite clean. I had the same rear wing on my GTT but got it changed before I picked it up from the dealer. It's a matter of personal choice though. The series I GTTs had the large rear wing, but I opted for the series II rear wing.....see pic.
Righto, sounds like fun. Ill have a look out for the next meetup.
Im not sure what I want to do to the car as far as looks go. I not sure what I want to do to the car full stop. gonna start with suspension and probably a fmic and see what happens.
    • That is way more science than even I would use. I just eyeball it, not even accounting for the non-verticality of the tape measure when held on the lip and the centre at the same time. +/- 2mm is good enough for the girls I go out with.
    • So, before putting them in I need to understand the stock ride height. This is how I measured it: First, check the diameter of the wheel's centre cap, it was 52mm. Then put a piece of masking tape approximately across the centre and measure 27mm (half) from at least 3 sides to get a reasonable idea of the centre of the wheel cap. Mark that with a horizontal line as one measuring point. Then, directly above the wheel on the guard, put another piece of masking tape in approximately the centre. Use a string line to find out the point on the guard above the centre of the wheel cap and mark that. Then it is simple, just a tape measure to check the distance from centre of the wheel to the centre of the guard. Final results where  LF: 381mm RF: 379mm LR: 401mm RR: 400mm Pretty even considering they are 120,000klm old factory springs, lets call that 380 front and 400 rear.
    • So....knowing that I have a problem with power steering temps on track and another Wakefield day booked in next Friday, I've done the obvious thing They are very reasonably priced at $1650, considering they are a big monotube shock, double height adjustable (don't have to change pre-load to change ride height), one way adjustable damping and standard sized and customisable springs if you want something other than what comes with them. They come with 9kg/mm front and 4.5kg/mm front and I went with that as a starting point because I'll add adjustable sway bars too https://justjap.com/products/bc-racing-coilover-kit-ds-ds-infiniti-q50-v37-14-current#description Unfortunately they didn't come with rear strut tops so I've re-used the factory ones which was a bit of a pain. Also, the adjuster for the rear shock will be an absolute nightmare to get at, and while there are extensions in the kit I can't see any way you can actually attach or use them
    • I also had 2 bulbs blow at once, years ago in the stagea. made for a fun drive home. The issue was the voltage regulator had failed in the alternator and it was giving 15+ volts. Really, I was lucky all that was fried were the headlight bulbs. So, I'd suggest you check the voltage across your battery terminals with the car running and warmed up. Yes, you will need a multimeter to do so, sorry.
    • Good work to think to check that, and thanks for coming back to post up the outcome.
