As per a post at SilviaWA:
...after 5th April, all 15 yr old imports will have to do almost the same ADR work as the normal RAWS cars. This is definitely going to increase the cost of the car and ADR work. Engineer will have to inspect the car prior to PITS inspection.
Plus, regarding the air conditioning, its not just a matter of degassing anymore, dryer / filler valve..etc will have to be taken out as well.
  • Replies 198
And, if so, there goes the chance of me getting an R32. Which definitely sucks hard. I think that DOTAR's is being a little stupid by disregarding email responses' and by coming to such a conclusion so quickly.
Ok now.. first of all this is WA ONLY !! unless I'm reading wrong, each state has their own engineering rules and regulations and steps required to get a car complied for the road. Not every state requires an engineered car to be later fully inspected by the state transport deparment. This may effect WA and SA (which generally have ****ed up laws anyhow from what I gather), but not the eastern states.
Federally I'd imagine DOTARS can put pressure on state governments to change adherence to various ADR, but really in the end it is up the state government to implement the changes or not.
Please don't blow things out of proportion Elithrar unless you do really have facts and can provide sources and documents. Thanks.
Usually when the gas is removed in the old system a few valves had to be changed anyhow to suit RA134A I believe. So that is not that devestating. In the end when you get it rebuild in australia you get an aircon system that *works*.. many cars that age require a recondition anyhow. I dont' think thats a major problem with anybody considering getting an older car, other than the extra cost involved.
Hi everybody, newbi here since last night. Felt i had to put a bobs worth in on this subject. It is great the amount of effort you people have put in to it and you should be commended for it. I have only read the last few replies on this but thought it is good to get as much input on this subject even if it is not correct.
Imports have always been somewhat of a grey area in regards to regos, rebuilds etc. Because a few have been straining the rules and let go because ultimately the RTA were at fault, big brother has tightened the reigns.
I have written numerous letters, (handwritten is considered more personal although i have to agree it shouldn't matter what it is on) to DOTARS proclaiming to withhold the 15 year rule and hopefully we will get somewhere. My gut feeling is that it will be changed, along with other avenues, until the only way to bring a decent car in will be personal import only.
Unfortunatly, there still continues to be a minority that are greedy and our feds, along with the jap feds have uncovered another 36 exotic stolens at melbourne pier. If anybody is interested in how these cars got here with a full "dereg" you can pm me.
As for importing r32s i am not sure but check on the raws link below:(it is not such a bad thing because this way all cars get the full treatment, ie:seat belts,tyres,cat,aircon etc, because it is now the onus of the raws workshop and not the owner to get the car worthy. Not sure if any raws is doing the 32s yet as it costs hella much money to get the license.
ps. latest news is you now need a certificate to prove that the acon gas was removed in japan before you can get a dereg and if it has no gas then you will probably have to fill it to get it taken out!?!!
Hope this enlightens some here is the link: :wavey:
http://raws.dotars.gov.au/rawswebpublic/RA...AWPubSearch.asp
Predator, I was merely quoting something said at SilviaWA, and never claimed it was 100% true. Apologies if my post was taken that way.
From the Prestige Motorsport mailing list.
For those in Western Australia -- save nearly $1,000 by beating upcoming Department of Transport changes
[/size]
This is a short note to advise all those in Western Australia that the requirements for registration of 15 year old vehicles will soon be brought inline with those of other States, including the requirement for an engineer's sign off once the ADR-related modifications are done.
As most would be aware, some or all of the following items must typically be addressed for vehicles older than 15 years, prior to registration:
Sash belts for rear seats
Sun visors
Child restraint points on the rear parcel shelf
High level brake light
Catalytic convertor
Driver's side mirror changed from convex to flat
Unleaded fuel filler opening restrictor
Side intrusion bars
Dash dimmer switch
Engineer's sign-off
These do vary a great deal from vehicle to vehicle and State to State.  If you are uncertain about what needs to be done for a vehicle you are considering, you should ask the registration authority in your State for further information.  Costs of the work can then be determined by contacting a suitable workshop.  While all the changes can be made by the owner, we do of course recommend our customers to a reliable workshop in their State should they require assistance.
We always suggest with 15 year old vehicles that an allowance of about $1,200 be made for the modifications required prior to registration, if paying a workshop to undertake the work.
However, previously as little as about $300 to $500 was sufficient to prepare most vehicles imported under the 15 year rule, for registration in WA.  This will be changing next week with the indicated date being Monday 5th April 2004.  We are still waiting on advice of the exact changes from the WA Dept. Transport but based on information so far, we expect that the list of requirements will include more of the above items as well as an engineer's sign off.
We have been told that any vehicles bought before the 5th April will be exempt from the changes.  We would assume that an invoice from the Japanese supplier and a dated receipt for funds transfer to Japan for the vehicle will be sufficient evidence of this fact.
So if you are in WA and you are intending to import a 15 year old vehicle, then you will need to purchase prior to 5th April in order to beat the changes and save yourself nearly $1,000.
Hi everyone
In the never ender fight to stop the government doing us over again, I've added a step 6 to my "how to stop the 15 year rule changing" page.
ie http://www.r34skyline.com/politics/do15years.htm#Step6
I show you how to find out if you are in a marginal seat and who your local member is - who you should complain to!
Get on those phones! :-)
Ian
Step 6: Contact your local representative, especially if you are in a marginal Libera/National seat!
Some of the fedral seats can be lost with just a few hundred votes in the next election! So if you are in one of the marginal seats, talking to your local representative will be especially effective..
If you'd like to know if you are in a marginal seat, and the contact details for your representative, I've put a list up by electoral name (http://www.r34skyline.com/politics/electio...n2004/index.htm),
or by postcode (http://www.r34skyline.com/politics/electio...alPostCodes.htm).
Even if you're not, there are instructions on how you can look up who your member is, and his contact details, on either of those links.
So contact your member and tell him how unhappy you are, and that you will be thinking of this issue when you vote later in the year!
Well, the response period for comments to DOTARS' proposed changes to the 15 year rule has ended. So what to do now ? Sit back and wait for them to announce the option that THEY think we should have, then try to complain when it's all too late ? I think not.
Rather, the pressure needs to be increased.
It's time to contact your local Member of Parliament. The most impact will be generated by contact with MP's in marginal seats who are naturally very receptive to any issue that may serve to weaken their prospects for re-election. However, it is very important also for those residing in 'safe' electorates to contact their local MP to not only make them aware of the issues, but to bring to their attention how many tens of thousands of voters will be completely pi**ed off if the 15 year rule changes.
How to Contact your Local MP
Writing a short letter will be the most effective method, followed by a phone call, and lastly e-mail (only use e-mail only as a last resort as this tends to be ignored by Politicians). If you are not sure what this issue is about or what to say to your MP, you can read through all our previous updates at:
http://www.prestigemotorsport.com.au/?/au/...e=Industry+News
Not sure who to contact ? No problems -- see below
To find out who your local MP is by using your postcode, use the following website:
http://www.aec.gov.au/esearch/searchb/main.htm
Then to find contact details for your MP, go to:
http://www.aph.gov.au/house/members/mi-elctr.asp
Marginal seats by name of seat and postcode are shown at:
Chances of Success are Good
Bear in mind that we are pushing simply for the current regulations to be retained as they are -- this is always the path of least resistance for Govt. and providing that sufficient public comment reaches local MP's, there is a very good chance that the 15 year rule will be left alone for at least the next couple of years. Imagine the possibilities for all the new models this will give us access to at amazing prices. All you need to do to have your say is to take the time to write and post a short letter, or call your local MP and let them know how you feel !
Thanks
Many thanks again to www.r34skyline.com for their efforts in putting together relevant information, for full detail see:
Well i hope they keep the rule, I'm planning on getting my 35k Honda NSX next year:)
Australia is the most overegulated country on the planet, I wish the govt would just rack off and let ppl do what they want, is this a free country or not?
Auction Price History over last couple of months.
A total of 6 matches were found, average of 2,785,000 $34,830 or $46,900 plus compliance cost and the price isnt getting lower.
Date Year Car Name Chassis Model CC KM Shift Colour Options Grade Price
15/4 1990 NSX NA1 ? 3000 85 F5 black AC leather PW 4 2901
14/4 1990 NSX NA1 ? 3000 35? F5 red AC AW leather PW R 2390
25/3 1990 NSX NA1 ? 3000 70 F5 gun metal AC leather PW 4 2894
10/3 1990 NSX NA1 ? 3000 50 F5 black AC leather PW 4 3305
10/3 1990 NSX NA1 ? 3000 90 FA black AC leather PS PW 4 2605
5/2 1990 NSX NA1 ? 3000 64 FA red AC leather PS PW 4 261
And if you think Australia is the most overegulated country on the planet, I wish the govt would just rack off and let ppl do what they want well look at countrys like Malaysia and Singapore which have traiffs of 100 to 150% then complain.
  • 2 months later...
Vehicle Standards Bulletin VSB10 - Importing Vehicles to Australia
ALERT - IMPORTATION OF VEHICLE 15 OR MORE YEARS OLD
The Government is currently considering the responses to the discussion paper on the Importation of Vehicles 15 or More Years Old and the options outlined in the paper.
Prospective importers should be aware that there may be changes to the current regulations. You should not assume that vehicles manufactured in 1990 will be allowed to be imported should the regulations be changed.
    • You know how your car rolled through a fence in your last jacking escapade? Scissor jacks increase the likely hood of that sort of thing happening immensely!
    • http://calfinn.com.au/product/1500kg-standard-trolley-jack-cj-2t-c/1500kg-standard-trolley-jack-cj-2t-c   I have this and fits under a S3 33 GTR with no issues. Purchased in 2009 and not one issue. It was $950 back then. Not cheap but something so important isn’t worth cheaping out on.
    • Just trying to get my head around this. At 5psi of boost, you turn on your wmi pump, and then you're using a 3000cc injector, to allow flow upto the actual engine, where you have your 6x200cc injectors and a 500cc injector. If the above is correct, what advantage are you obtaining by having the 3000cc injector blocking flow, is this just incase a line breaks between that injector and the motor you can stop flow immediately? Or are the 6x200cc and 500cc less injectors and just spray nozzle?
    • Welcome! New member myself, but I had an R33 back in 2002. Best advice I could give, based on my experience: if you're running the factory turbo, be very conservative with boost. I made the mistake of just fiddling around with the boost controller and cranking the boost for fun, and the end result was my intake pipes popping off frequently from the constant deluge of oil that was being blown into the recirc by the stressed-out turbo, which itself was siphoning oil from the engine and farting it out both sides of its centre bearing (or something to that effect). If I could do it all again, I would have gotten a new turbo and had a tune dialled in professionally and then just left it alone! Funny you mention the metal shavings in the gearbox, as I had the same thing - the probe plug (magnetic drain plug, essentially) would come out caked with shavings. At least it was doing its job. Not sure if that's just sacrificial wear and part of the deal, or if my gearbox was shagged, but I wasn't abusing it. Enjoy the R33 - they're a dying breed, and if they weren't $35k+ on CarSales in Queensland, I might have picked up one of those again, instead of the 370GT I own now (though I'm loving the 370GT, that big 3.7L V6 just hits different).
    • Howdy folks. I owned an R33 back in 2002, which was thoroughly beyond my capacity (financially speaking) to maintain/insure, so we parted ways in 2004. Fast forward 21 years (to literally yesterday, in fact) and I'm now the proud owner of a 2007 V36 370GT. I'm happily surprised by how much power the VQ37VHR makes, compared to the RB25DET, considering the latter is turbocharged. I had planned to add a turbo at some point but I'm on the fence about whether I'll even need it (though I do love the sudden onset of extra torque). Any other 370GT owners around the traps, I'd love to hear about your experiences with this car (good and bad).
