Pics Of My Skyline From Power Cruise
guys if anyone got any pics of my 32 gtr could ya let me know.. would be keen to see them:)
looks like this
cheers
i dont have any pics, but i do have praise :D , that is one of the cleanest r32's i've seen. Love the black gt-c's.
  • Replies 43
Posted Images
Those flies where bad!!!!! Try to eat chicken treat with 100 flies annoying the shit out of ya... :D
I think i might convert to a single....
Bloody expensive chicken treat too!! sharing a chicken roll, small chips and a coke for $15.50 with 100 flies sucks a big one.
Lol yeh the food there was a rip, we ended up leaving and going to get pizza from Harry and the Boys and then coming back, got 2 large pizzas, a garlic bread and 1.25L drink for $20 :(:)
Getting a bit off topic though lol... How awesome is Sonic, 116mm turbo anyone? Apparently full boost by 4000rpm as well :D
Lol yeh the food there was a rip, we ended up leaving and going to get pizza from Harry and the Boys and then coming back, got 2 large pizzas, a garlic bread and 1.25L drink for $20 :):D
$16.50 for a burger, drink and soggy chips :(
And yeah, Sonic is awesome, he has a 32 GTR too ;)
Those flies where bad!!!!! Try to eat chicken treat with 100 flies annoying the shit out of ya... :)
had a good look at that torana, supposedly 1600hp and "no lag at all" :D the more i looked the more i noticed cheap ebay radiator, fpr, fake speed flow fittings etc ..
speaking of expensive food, the biggest joke was the $35 spectators fee!
had a good look at that torana, supposedly 1600hp and "no lag at all" ;) the more i looked the more i noticed cheap ebay radiator, fpr, fake speed flow fittings etc ..
heard him say it was only making 16psi too, and 40psi is a good efficiency range
Lol I was completely out of petrol. Was surging around corners on the way to the petrol station, seriously had to limp it. 200kms of constant WOP on high boost really takes it's toll :D
Edited by Hanaldo
Shattered no1 snapped me being towed lol
May have it on video, haven't had a chance to go through yet but I got a few incidents down the back straight on footage, once was a pretty close call between a couple of cars but can't remember what they were.
As for SONIC and full boost etc.. I would imagine boost levels would vary according to how many people are in the car as once it starts wheelspinning it's not exactly loaded up too much, the more weight, the more load, the more boost it makes..
    • Manual boost controllers (where a little of the boost was bled off) were quite common back in the day, because they were cheap and easy. Generally they had a manual adjustment screw rather than being fixed like yours. Down side is they always bleed boost, not just when you want them to so an electronic boost controller that uses a solenoid will have less lag.
    • Hello , im new here and i have A31 home build  RB25det neo stock eng / turbo  aem ems 2 blue connector  aem 3.5 map aem cas disk aem wideband connected to ecu  355 lph pump 550 nismo yellow injectors side feed aftermarket regulator  and won’t start with base aem tuner basic tune eventually flipped cas 180 degree so it triggers on correct stroke not in exhaust cycle  Now it won’t start Wideband reads 10 and 11 at lowest fuel setting  and will share calibrations soon for aem tuner i think something is wrong in aem tuner    please if you have any information, am very grateful
    • Legend. I ended up finding the facebook account of the owner of the first car i sent but sadly he deactivated the account. I think you’re right in saying it’s some sort of well done custom job. Really appreciate your help anyways.
