hey guys i have 33 gtr.. it already has good coilovers in it but im looking to improve the handling a bit more i just wanted to no what the next step is?? how much is to be gained by installing bigger sway bars??
also i have heard mixed reports on weather or not i need to install z32 air flow meters when pushing over 300awkw??
any help would be appreciated cheers
Ryan
The point of swaybars is to balance the handling so it neither favors understeer or oversteer, since the GTRs are nose heavy (like a FWD) they benefit from a thicker (or stiffer setting if adjustable) swaybar up front and a smaller swaybar (or softer setting if adjustable) up back. But GTR swaybars are pretty decent in my opinion (Whiteline/Selby adj. bars weigh a tonne since they are solid bars, completely up to you if you want to add that weight), you can dial in the balance by adjusting the damper settings on your coilovers (it's what I do) having different setting front and back.
Stock AFMs only support about 300kw, but please search on this subject as I don't want to repeat info I've already posted time after time in other threads.
Upsde down Miss Jane.
The fat swaybar needs to be at the rear, the thin one at the front. Stock sway bars are hopeless when married to high spring rates.
    • Hi...so a "development" here aswell The swap is "done" and car went "test drive" BUT it seems the clutch(maybe gearbox?) is a little bit sad? I bought this clutch kit https://justjap.com/products/xtreme-heavy-duty-organic-clutch-flywheel-kit-nissan-skyline-r31-r32-r33-push-type "Problem" is that the first gear is hard to put into and it seems that the clutch is not disengaged. It was not the problem with the old clutch...(or like sometime the first gear would not get as easy specialy when the fluid was cold) So? Can it be like...bad "install" or is the clutch wrong ((it should not have been) i done research to get the right one) Or is this "normal" with new clutch and needs to be break in?
    • @Duncan I can try  and thanks i did not thought about VIN and part numbers for 33/34. @GTSBoy yeah it looks like iam gonna do that
    • Forgot to include this but this is the mid section of my steering rack that looks like it has a thread/can be turned with that notch mentioned in the post:
    • Hey everyone, Wanted to pick some brains about this issue I'm having with rebuilding my 33 rack (PN is 49001-19U05). All of the tutorials/videos I've seen online are either R34 or S Chassis racks which seem to be pretty straightforward to disassemble but this process doesnt carry over to my rack. Few of the key differences that I've noted The pinion shaft on the other racks bolt on with 3 torx bolts: Whereas my rack bolts on with 2 allen head bolts: These changes are pretty inconsequential but the main difference is how you pull the actual rack out of the housing. The other skyline/s chassis racks can be taken out by tapping the rack out of the body with a socket and it just slides right out. I'm unable to do that with my rack because there's a hard stop at the end that doesn't let the seal/shaft be tapped out. Can also see a difference in the other end of the rack where mine has a notch that looks like you're able to use a big wrench to unthread 2 halves of the rack whereas the other racks are just kinda set in with a punch. My rack: Other racks: TLDR; Wanted to know if anyone has rebuilt this specific model of steering rack for the R33 and if there were any steps to getting it done easier or if I should just give this to a professional to get done. Sorry if this post is a bit messy, first one I've done.
    • I would just put EBC back on the "I would not use their stuff" pile and move on.
