no. N=4wd. so the block is different. I have 4wd block. use the box you have as it is better geared that a GTR box. same box different gearing.
found these in a wreck today. they are a LOT cleaner than what I already have.
if you want to buy new ones they are still available.
the S15 uses the same bits in the same color. these cost me $10 and once I clean them up they will look just as good.
I also have a newer A pillar trim without holes in it.
Chris, i got a chance to check that bracket out for you. PM me your email and i'll flick you a few pics to verify as they are a bit big to load up here.
pm sent.
I was at option 1 when I saw it. currently it is pinned between two steel plates so I can flatten the thing out.. when I got it the thing was all sorts of bent.
been a bit busy sorting out other cars and had little time to work on this one. :(
done a bit of dummying up of things but thats about it. I'm looking for a R33 or R32 GTR BOV return pipe now.
    • Or, is it a case of what it is like owning an R series Skyline? NFI what the previous owner has done or fiddled with... Ha ha ha After reading through this thread, I went on a bit of a research about the Q50/Q60. Now I'm quite intrigued by them! Is the AWD in them more like a WRX where it's always AWD, or is it more like the ATTESSA in the GTRs? By the sound of this TCU tuning, this sounds like a case of someone has made some real software for it, and you just need the right piece of hardware, and then you license that specific vehicle/TCU. Or is this a case of the software will be really expensive so only a few tuners have it, and you still have to pay a license per vehicle?
    • No, code 21 is very straightforward. It can only be the things described in that diagnostic flow. In fact it has no way of knowing that the spark plug resistance is out of spec.
