have all the intercooler stuff mocked up. ordered new rubber grommets and the crows foot that holds the return pipe and cooler in place on the bottom. waiting on the invoice for those.
question for those with 'northern' cars - can you pull the mirror control out and get a part number off it please. I have found a set of northern mirrors and need that switch. these are heated units and with out the switch the heaters do not work. I already have the harnesses.
fully stripped 32 GTR subframe - filthy from years of dirt and leaking axles.
thanks to whizzn for this.
lines - all intact and DEFINITELY reusable - if I had to buy them new there are $1200 worth of lines there.
of all that I cannot buy the power steering pump line..
these get cleaned up and reused with new retaining clips (which I already have.)
steering rack. this came with the GTR subframe. going to get a quote to rebuild it back to original. not a lot wrong with it at first glance.
I will find out once i get a chance to run it over to driveline services in brendale how bad it is.
my original needs boots and I dare say rack ends. easier to fix this one.
gurney time. that was taken at the virginia car wash the fellow that managed the place kept watching what I was doing.
when I told him what it was out of he gave me a blank look and walked off..
start of thinners bath
half clean
heat shields - nice and shiny. my original is missing the smaller one.
All cleaned up. that took 6 abrasive sponges and a 1 lt tin on thinners to get it to that point. I still have to clean the lines and the mounting tags up.
it will be a pity to sit an engine on top of this.
this one has a MINOR bend on the front line support- I can fix that with two big wrenches.
once I get the lines cleaned up I will reassemble the whole lot and set it aside for when the body comes back.
I want to do the same with the rear subframe as well. that will be a fairly big exercise though.
bought a GTR bonnet , bonnet latch/support and a grill off ebay - now this is starting to look like something.
panel shop cost is a doozy though :P
hope the girl that gets this car appreciates it. (this is for my daughter for those that didnt read earlier)
going to drop off the radar after this for obvious reasons - locals can track me down if you want to look at it.
I may do text updates but no images unless I can do them in such a way that is doesn't show where the car is kept.
those in SEQ probably realise why I am doing this now instead of later. this thing will owe me a 5 figure sum and I wish it to remain int he condition I built it and not burnt or stripped.
Dang it, will have to email you to get updates Chris.
I finally managed to get some time off work Mon just gone and send you that fuel bracket support, cut it a lot larger than what you probly need but it should help you out hopefully
thats sort of the reason I am doing this. you guys are watching this as are 3-400 others. I do not know those people and any one of them could take a liking to the car :)
as I said I will put up text updates but thats probably it at this point.
100% Understand where you are coming from, open forum and all.
ordered new door mouldings last night for it. (the ones that sit on top of the door and butt up to the glass.)
Part Numbers:
80821-04U03
80820-04U03
I had to order a set for a customer so I ordered two sets.
found a source for the destroyed oval rubber boots that are in the doors. N14 pulsar has the same boots and given the number of these things in wrecking yards they are fairly easy to get.
the part is no longer available new. (considering that nissan went to body plugs in 95 or so I know why.)
Well that's a bummer, I was enjoying this build up :( You're an anal bastard like myself :P
Completely understand where you're coming from though, my biggest worry with my S14 build up is security. I have an unopened garage, and I'm shit scared of someone finding out where I live and knocking off something.
Keep up the good work, mate. Can't wait to see the finished product.
Found a BETTER source for the body to door harness boots that the door harnesses have on them
the originals are:
24256-41L10. (35mmx50mm oval boot) - fits into the door
24256-41L01 (50mm round boot ) - fits into body cavity
these are for a 2 door obviously (no idea on a 4 door)
where to find BOTH of them cheaply:
late 90s J30 Nissan Maxima. they are on the door harness and usually in good nick. I have 4 sets as I want two spares. wrecker gave them to me at no charge :)
just bought this:
that will fit nicely into the GTR cluster that I have ( the tach is coming out.)
this in conjunction with a garmin GVN53 and HKS CAMP2 should bring this car into the 21st century quite nicely
already spoke to a speedo cluster repairer as well about making me an overlay with a clear area for it so it all looks factory.
only oversight I had was the amount that a sheet of the material makes - 5 overlays. so once done I will have 4 of them up for grabs in the factory grey instrument color.
    • Well GTSBoy, prepare yourself further. I did a track day with 1/2 a day prep on Friday, inpromptu. The good news is that I got home, and didn't drive the car into a wall. Everything seemed mostly okay. The car was even a little faster than it was last time. I also got to get some good datalog data too. I also noticed a tiny bit of knock which was (luckily?) recorded. All I know is the knock sensors got recalibrated.... and are notorious for false knock. So I don't know if they are too sensitive, not sensitive enough... or some other third option. But I reduced timing anyway. It wasn't every pull through the session either. Think along the lines of -1 degree of timing for say, three instances while at the top of 4th in a 20 minute all-hot-lap session. Unfortunately at the end of session 2... I noticed a little oil. I borrowed some jack stands and a jack and took a look under there, but as is often the case, messing around with it kinda half cleaned it up, it was not conclusive where it was coming from. I decided to give it another go and see how it was. The amount of oil was maybe one/two small drops. I did another 20 minute session and car went well, and I was just starting to get into it and not be terrified of driving on track. I pulled over and checked in the pits and saw this: This is where I called it, packed up and went home as I live ~20 min from the track with a VERY VERY CLOSE EYE on Oil Pressure on the way home. The volume wasn't much but you never know. I checked it today when I had my own space/tools/time to find out what was going on, wanted to clean it up, run the car and see if any of the fittings from around the oil filter were causing it. I have like.. 5 fittings there, so I suspected one was (hopefully?) the culprit. It became immediately apparent as soon as I looked around more closely. 795d266d-a034-4b8c-89c9-d83860f5d00a.mp4       This is the R34 GTT oil sender connected via an adapter to an oil cooler block I have installed which runs AN lines to my cooler (and back). There's also an oil temp sensor on top.  Just after that video, I attempted to unthread the sensor to see if it's loose/worn and it disintegrated in my hand. So yes. I am glad I noticed that oil because it would appear that complete and utter catastrophic engine failure was about 1 second of engine runtime away. I did try to drill the fitting out, and only succeeded in drilling the middle hole much larger and now there's a... smooth hole in there with what looks like a damn sleeve still incredibly tight in there. Not really sure how to proceed from here. My options: 1) Find someone who can remove the stuck fitting, and use a steel adapter so it won't fatigue? (Female BSPT for the R34 sender to 1/8NPT male - HARD to find). IF it isn't possible to remove - Buy a new block ($320) and have someone tap a new 1/8NPT in the top of it ($????) and hope the steel adapter works better. 2) Buy a new block and give up on the OEM pressure sender for the dash entirely, and use the supplied 1/8 NPT for the oil temp sender. Having the oil pressure read 0 in the dash with the warning lamp will give me a lot of anxiety driving around. I do have the actual GM sensor/sender working, but it needs OBD2 as a gauge. If I'm datalogging I don't actually have a readout of what the gauge is currently displaying. 3) Other? Find a new location for the OEM sender? Though I don't know of anywhere that will work. I also don't know if a steel adapter is actually functionally smart here. It's clearly leveraged itself through vibration of the motor and snapped in half. This doesn't seem like a setup a smart person would replicate given the weight of the OEM sender. Still pretty happy being lucky for once and seeing this at the absolute last moment before bye bye motor in a big way, even if an adapter is apparently 6 weeks+ delivery and I have no way to free the current stuck/potentially destroyed threads in the current oil block.
