have all the intercooler stuff mocked up. ordered new rubber grommets and the crows foot that holds the return pipe and cooler in place on the bottom. waiting on the invoice for those.
question for those with 'northern' cars - can you pull the mirror control out and get a part number off it please. I have found a set of northern mirrors and need that switch. these are heated units and with out the switch the heaters do not work. I already have the harnesses.
fully stripped 32 GTR subframe - filthy from years of dirt and leaking axles.
thanks to whizzn for this.
lines - all intact and DEFINITELY reusable - if I had to buy them new there are $1200 worth of lines there.
of all that I cannot buy the power steering pump line..
these get cleaned up and reused with new retaining clips (which I already have.)
steering rack. this came with the GTR subframe. going to get a quote to rebuild it back to original. not a lot wrong with it at first glance.
I will find out once i get a chance to run it over to driveline services in brendale how bad it is.
my original needs boots and I dare say rack ends. easier to fix this one.
gurney time. that was taken at the virginia car wash the fellow that managed the place kept watching what I was doing.
when I told him what it was out of he gave me a blank look and walked off..
start of thinners bath
half clean
heat shields - nice and shiny. my original is missing the smaller one.
All cleaned up. that took 6 abrasive sponges and a 1 lt tin on thinners to get it to that point. I still have to clean the lines and the mounting tags up.
it will be a pity to sit an engine on top of this.
this one has a MINOR bend on the front line support- I can fix that with two big wrenches.
once I get the lines cleaned up I will reassemble the whole lot and set it aside for when the body comes back.
I want to do the same with the rear subframe as well. that will be a fairly big exercise though.
bought a GTR bonnet , bonnet latch/support and a grill off ebay - now this is starting to look like something.
panel shop cost is a doozy though :P
hope the girl that gets this car appreciates it. (this is for my daughter for those that didnt read earlier)
going to drop off the radar after this for obvious reasons - locals can track me down if you want to look at it.
I may do text updates but no images unless I can do them in such a way that is doesn't show where the car is kept.
those in SEQ probably realise why I am doing this now instead of later. this thing will owe me a 5 figure sum and I wish it to remain int he condition I built it and not burnt or stripped.
Dang it, will have to email you to get updates Chris.
I finally managed to get some time off work Mon just gone and send you that fuel bracket support, cut it a lot larger than what you probly need but it should help you out hopefully
thats sort of the reason I am doing this. you guys are watching this as are 3-400 others. I do not know those people and any one of them could take a liking to the car :)
as I said I will put up text updates but thats probably it at this point.
100% Understand where you are coming from, open forum and all.
ordered new door mouldings last night for it. (the ones that sit on top of the door and butt up to the glass.)
Part Numbers:
80821-04U03
80820-04U03
I had to order a set for a customer so I ordered two sets.
found a source for the destroyed oval rubber boots that are in the doors. N14 pulsar has the same boots and given the number of these things in wrecking yards they are fairly easy to get.
the part is no longer available new. (considering that nissan went to body plugs in 95 or so I know why.)
Well that's a bummer, I was enjoying this build up :( You're an anal bastard like myself :P
Completely understand where you're coming from though, my biggest worry with my S14 build up is security. I have an unopened garage, and I'm shit scared of someone finding out where I live and knocking off something.
Keep up the good work, mate. Can't wait to see the finished product.
Found a BETTER source for the body to door harness boots that the door harnesses have on them
the originals are:
24256-41L10. (35mmx50mm oval boot) - fits into the door
24256-41L01 (50mm round boot ) - fits into body cavity
these are for a 2 door obviously (no idea on a 4 door)
where to find BOTH of them cheaply:
late 90s J30 Nissan Maxima. they are on the door harness and usually in good nick. I have 4 sets as I want two spares. wrecker gave them to me at no charge :)
just bought this:
that will fit nicely into the GTR cluster that I have ( the tach is coming out.)
this in conjunction with a garmin GVN53 and HKS CAMP2 should bring this car into the 21st century quite nicely
already spoke to a speedo cluster repairer as well about making me an overlay with a clear area for it so it all looks factory.
only oversight I had was the amount that a sheet of the material makes - 5 overlays. so once done I will have 4 of them up for grabs in the factory grey instrument color.
    • Yeh I think i'll message an old contact i had for ages that manages his own tyre shop now.. n tell him what i want n work with him before ordering..  Got this 17x9 +30 Driftteks on 245/45/17 PSR Drag Radials on the rear.. They fit well - for your reference in future - Rear guards  have been lipped in & minimal to non flaring of the rear Gaurds.
    • If only it were that easy! I also needed to remove seats, shocks, brake calipers, send my car through a fence, and use measuring and ended up guessing because I didn't remove seats, shocks and brake calipers. It can be hard sometimes Can be a little more complex than 'just measure' if you want to truly measure the entire wheel through all of it's suspension travel. But if you aren't going for every last mm then yeah, you can check the space you currently have and guesstimate.
    • If you own a car, and it has wheels on it, and you know the offset of those wheels, and you have a measuring device, you have everything you need to work out if other wheels will fit.
    • Will this fit? but they are staggered set - RAYS 57DR SEMI GLOSS BLACK 18x8.5 +37 | 18x9.5 +38 5-114.3 STAGGERED SET   or If no go could just get a set 4's wheels of 18x8.5 +37 5-114.3 - would i run 8.5's 235s up front n 245's at the back if I do?   Thanks.
    • Put a clamp on your return line. I have a feeling it's sucking air, and introducing bubbles to your fuel. With a lot of fuel, less problematic. I'd honestly be redoing all the lines in the tank and clamps on everything.   Also, you've given two different answers to the same question: Asked if being followed by the police you could get down to use the whole tank, you said yes you could, so long as you keep off boost. However, you then followed this up that free revving, it would also cause the issues. I'm doubting free revving is enough to make any noticeable boost on what is likely a decent sized turbo.   So now I have to ask, can you actually drive it lightly and use all the fuel, or does it break up even free revving? Also, have you put a fuel pressure gauge on it? Can you hear the pump change noise at all when you're having this issue?
