Why not try a retrofit with the r33 240km/H dash with lcd screen?
nah. then I lose my torque gauge and the cluster is a different shape so it is not a direct fit.. the HKS peice does tach any way so it will have a digital tach and info meter similar to the more modern R34 GTR.
I have a few electrical tweaks to go on it - this is one of them
also this screen will double as a navi screen when the HKS piece is not being displayed. again its a tweak that I am used to having in the other vehicles I own.
this is a R34 obviously but you get the idea:
did that in 2008 to a mspec nur.
just ordered and paid for NEW heated mirror glass and the associated switch that runs it.
2nd last image of the car you will see it has blue mirrors. the original red ones worked but were missing screws. found these and the associated harnesses to run them. checked that the harnesses are supported by the car - they are. mirror glass was missing.
part numbers for those playing at home.
9636505U00 - Mirror RH
9636605U00 - Mirror LH
25570-71L00 - Switch
mirrors and switch were $290.
I am going to try and get the side glass next. nissan japan seem to be paranoid about shipping it directly to me so I am going to get a mate of mine to pick it up for me.
(repost - fixed images.)
just bought this:
that will fit nicely into the GTR cluster that I have ( the tach is coming out.)
this in conjunction with a garmin GVN53 and HKS CAMP2 should bring this car into the 21st century quite nicely
already spoke to a speedo cluster repairer as well about making me an overlay with a clear area for it so it all looks factory.
only oversight I had was the amount that a sheet of the material makes - 5 overlays. so once done I will have 4 of them up for grabs in the factory grey instrument color.
Is this just a LCD Monitor with a VGA plug?
I have headed ones in my R32* but have never ever needed to use them and being in WA dont think i ever will. Maybe if i come over east ill go to the snow just so i can use them..lol.
I like the nav screen trick. May i suggest (if you can) edit your first post to include the complete list of part number so people can find what they are after with out going through the complete thread.
* VW not a nissan before you get excited
no. I could buy it as a VGA unit with a composite feed as well . could not be bothered as I have a custom interface already on paper for it any way.
this one is composite video only. I will use the unused radio buttons on the top left of the cluster to toggle between the units.
if I can get a admin on my side I will update the first page. there are a lot of part numbers in the 24 odd pages - that I do know.
I could not buy the normal mirrors.. I had picked up the blue mirrors to fix my red ones. I noted an extra two pin harness hanging off it. prior to this I had been in possession of 3 cars that were the same so I made notes of chassis numbers and with a bit of translation help found that this was a cold weather option. (the battery was the other - northern cars have a HUGE battery.)
my van has the same idea except that it goes from navi to a camera. if I get bored I *MAY* do that as well to this car. need to get the overlay done and the HKS item here first.
I am going to use add on harness to add the 'missing' sensors that I I do not already have. I am not sure if front torque is on the data stream or not. never looked and I can't really look until I can power the car up and thats NOT for quite a while yet.
spent today talking to a instrument repairer in salisbury. explained what I was trying to do and he showed me a few examples of the work they do with dials . dropped the tach and indicator overlays off to them and said take your time.
I still need to take them the LCD panel for measurement so everything lines up correctly. I am also getting a new indicator panel done (top center panel with the green arrows and high beam icon.)
the indicator overlay is s 4 color piece and I'm told will be a bitch to make correctly. the aim with this one is to put a security word in black/red on there below the high beam indicator area. the cluster has a spot there for a extra light and that s what it is going to be. the light itself will be a LED out of a toyota starlet cluster, its the only thing bright enough to light that area and not take a nuclear power station to run it.. (I have 30mA to play with most lights take 2-300mA to run)
I will put up images of it once they get it done. for those thinking cheap ebay dials - nup! these are good enough to be OEM.
Christmas for me!!!
I have:
new heated mirror glass
window moldings - set (flat ones that sit on top of the door.)
heated mirror swtich
new sun visors
all of the outside engine bay stickers
tyre placard sticker
new rear grab handle
I will do images in a bit.
    • Why are people so insistent on making dirty water?!
    • Fark what are the changes of that snapping like that, clean. Nek minnit, custom radiator goes in, with built in oil cooler like those discontinued PWR ones from yesterdeacades ago
    • I thought I'd do a write up on an auto transmission fluid change for a the nissan 7 speed Automatic. At some stage the genius engineers decided that the fluid in the trans was "for the life of the transmission", (which seems kind of self supporting to me) and removed the dip stick and fill tube (funnily enough there is still a casting for it). Anyway, for this job you do need 2 specialist tools in addition to regular hand tools, jack and good chassis stands. You need a way to pump fluid up to the transmission; I got one of these but there are plenty of other options: https://www.ebay.com.au/itm/364584087070 Don't trust the generic listing though, it does not come with the required adapter for the Nissan 7 Speed. You need one of these, can't do the job without it: https://navarapart.com.au/product/genuine-nissan-patrol-y62-d23-np300-navara-re7-dipstick-fill-connector1 You need a heap of compatible transmission oil. Could be Nissan, could be anything else rated for Nissan Matic S. You need at least 10 litres, I had 15 to give it a better flush... Also, you need some biiig oil catch trays, at least one of these, or bigger if possible (volume was fine, size was very marginal): https://autobarn.com.au/ab/Autobarn-Category/Tools-%26-Garage/Specialty-Tools/Oil-Service/Garage-Tough-Oil-Drain-Pan-Black-16L---GT1068/p/TO03191 Finally, a measuring jug is very useful if your pump does not have volumes marked on it, I got a 6l one: https://www.repco.com.au/oils-fluids/fluid-accessories/measuring-jugs/penrite-measuring-jug-6l-pmj006/p/A5322648 Oh, and gloves.....this stuff is horrible (not as bad as diff oil, but getting there) ....First, jack up your car.....
    • So I mentioned the apprentice, @LachyK helped take the bonnet off. We just undid the nuts on the hinges and unclipped the gas struts, then pulled the bonnet back a little as the front was catching on the front bar.  I had a good look at everything today and have removed the rams, repaired/reset the hinges and bolted it back together like it never happened. I'll do a separate write up on the repair, and I also removed the poppers from the Fuga today too to save grief down the road.....as said above it is at least $5k to repair retail. I'm also happier about my ability to prepare a race car, and less happy about Nis-nault's engineering (I can hear @GTSBoy sAfrican Americaning) because the top hose of the radiator didn't slip off.......it snapped clean off. By practice I put the hose clamp hard up against the flare on a neck to make it least likely to ever move (thanks @Neil!). I guess that puts a little more pressure on the end of the pipe as it is further away from the rad, but still, that is pretty shit. I've put it back on for now as there was a fair bit of neck still there, but obviously there is no lip on the neck any more so I don't think I'll track it again until I have a new rad. Speaking of which....more research required. It looks like Koyo makes a standard size radiator in ally which I'll grab in the meantime, but I really want something thicker so might have to go custom in the medium term (ouch) Coolant still needs a refill and I have the pressure tester on it over night, but other than a wash down of the engine bay it seems alright. And @MBS206 noted something noisy on the front of the engine and I think I agree....time for a new accessory belt and tensioners I think.
    • our good friends at nismo make a diff for it, I have one (and a spare housing to put the centre in) on the way. https://www.nismo.co.jp/products/web_catalogue/lsd/mechanical_lsd_v37.html AMS also make a helical one, but I prefer mechanical for track use in 2wd (I do run a quaife in the front, but not rear of the R32)
