note being defensive, just the only reason iv been given so far is "cos its stainless". i was after a reasonable reason that one would pay the extra
So it doesn't rust...
So it makes good power...
To get it to tuck up nicely under a lowered car...
That $750 mild system was only worth $60 in materials, you feel ripped off?
I run ethanol in my car so a mild system wouldn't last more than a few months im guessing... You are right though, stainless isn't special, titanium is a much better choice. :P
I run ethanol in my car so a mild system wouldn't last more than a few months im guessing... You are right though, stainless isn't special, titanium is a much better choice. :D
  • paint a. A liquid mixture, usually of a solid pigment in a liquid vehicle, used as a decorative or protective coating.
  • stainless makes good power? better than mild steel? could you give me some stats on how it makes more power then a mild steel system?.
  • a custom hand made one would tuck up just as much, if not better then an off the shelf item.thats why its called custom made... it wouldn't be custom if it didn't suit the car it was being made for exactly
  • no not at all, cos i didn't pay excessively for a full sick brand name one
  • obviously if theres reason such as methanol, then thats a reason... my question was biased on the average every day driver
EDIT:
im not trying to ague the point, just curios as to why i would want to pay the extra other then "cos its stainless" or "cos its [brand name]", when u can get something made locally that will perform exactly the same
Edited by GeNOS
pretty sure the only bonus with stainless is because it wont rust and looks cleaner.....
i would never put a stainless exhaust on my car, not worth the extra $ imo, unless ofcourse you A. love your car enough to spend extra and B have extra money to throw around.
As with most mild steel tight arse exhausts, mandrel bends are rarely used, gas is not purged inside the pipe while welding, galvanising is not cleaned off before welding, mostly mig welded not tig, not to mention, you cant heat wrap mild.
Its just not worth spending the time to get good power on a low cost system that will only last a few years. You don't think its worth the money? I do and so do my customers.
the main reason is rust and longevity. Something you might be intimately acquainted with, looking at your sig.
Depending on how you use your car, that one mild steel might turn into rust quite quick, even if its painted, because you can't paint from the inside out...
They also sound different, as i understand it, mild steel has a dull, softer note, while stainless has a louder, harsher note (obviously this is highly depended on the muffler/resonator set up)
Its fine if you want to go for an cheaper product, just don't judge us for wanting the opposite.
your stating defects in workmanship, not the product.
EXACT same system, performance of stainless vs steel is what im talking about. not high end stainless vs steel system made up by barry in his shed after a case of VB.
why would you heat wrap your cat back system???
mild steel lasting "only a few years"? hardly. but yes, obviously it wont last as long as stainless.
most people would usually sell your cars on long before it would be an issue. plus if your a keen modder, your probably making changes here or there, which may require changing it anyway before its an issue
anywho, ill agree to disagree
Agreed.... and the difference in exhaust note as stated by PN-Mad - well in my experience this has been the case anyway.
Exact same system, I don't see there being a difference in performance.
You wouldn't bother heat wrapping a cat-back... but dump pipe or possibly front pipe? Definitely.
Depends on the engine and driving conditions as to how long it will last... Take the VQ for instance, there is quite a bit of water vapour that goes through the exhaust (and sits in it when the car is turned off). With a stainless exhaust, this is not a problem... or how about if you drive on dirt roads? Having mud stuck to a mild steel exhaust would also speed up oxidation due to the moisture being "held" onto the steel. Even if it was painted, the protective paint could easily be scratched off in areas by stones or speed bumps.
Why is modification easier for a mild system than a stainless one? They can both easily be cut and welded so labour charge is the same and both are readily available.
Perhaps the prices quoted to you for a stainless system in the past have been a little cheeky?
I suppose another plus to a stainless exhaust would be re-sale. There has to be a reason people will state in their sale ads "Full custom stainless exhaust" in they have one and only "Full custom exhaust" if they have a mild steel one.
Both systems have their +'s and -'s, but for the sake of a couple hundred bucks I will always go with a stainless unit over mild.
I was tinkering around on youtube before,
kinda wishing i went the Exoticspeed route instead of HKS. There Exoticspeed RII-Titan model is basically a near perfect replication of the extremely pricey Amuse system :rofl2:
http://www.exoticspeed.ca/product_info.php...roducts_id=4921
After reading all those comments the reason I went with what I did is that at the end of the day , I got the satisfaction of modifying my own car , giving me the feeling that I was making my car my own , the system was a perfect fit and there was absolutely nothing that needed to be modified to make it fit , I also have the piece of mind that I know exactly what parts and fixings are used on my car , also I plan to keep the car till the day it dies so I bought with the intention to buy something that will last me longer , even if it costs more in the short term .
    • Ok so after much research and talking with knowledgeable people I've got my turbo conversion done and it's all running great other than 1 small issue.  Car has remained auto with the na auto and tcm, I've used a stagea ecu with. NIstune board and everything is great other than my gear selection on the dash. It illuminates park, reverse, neutral, 3rd and 2nd. But nothing drive or what gear your in when you pop it into tiptronic.  I'm sure there is may e 1 wire in the ecu plug I need to move to rectify this. Dose anyone here have any ideas?   Cheers guys
    • Sorry I haven't been following all the detail, so you may have tried this. Does it idle with the tiniest bit of throttle you can add? You've mentioned the IACV, does it have an AAC valve and have you adjusted it at all (ie, screw the idle adjust screw all the way in, then back it out a couple of turns until idle is stable)?
    • My bad, I unplugged the one underlined in red instead of yellow before. With the car started, after unplugging the IACV (the one underlined in yellow), it idled at around 400/500 for 3 seconds before stalling. Attempting to start the car without the IACV will not start the car.   It does stutter and sputter for around 5 seconds before dying. However, immediately after starting it, you can already hear some slight sputters from the exhaust.   It won't start with the AFM unplugged. If it is when the car has already started, it stalls in a few seconds.   Yesterday, I did take some logs using Nistune of 3 scenarios. Car idling till it stalls Car idling and unplugging the IACV Car idling and removing the AFM I also have some previous logs of when the Car is idling till it stalls and when driving and it cuts. I am not really knowledgeable enough to understand what to look for. After every test, car idles rougher and rougher, until I have to stop. It will be fine the day after.
    • There is no difference between a 17x8 and an 18x8. The total diameter of the tyre needs to remain +/- the same (so you don't mess up the gearing, speedo reading, and clearance when turning front wheels..... so you just need to use a lower profile tyre on th 18 than you do on the 17. /rocket surgery.
    • I thought the same to start with. But then I thought it was one of those LCAs where the end of the ARB goes through a bushing in the LCA itself, instead of having an end link.
