  • Replies 51
Don't worry INARK, it's ok.... I won't hold it against you...
You can (TRY) follow me out on friday if you like??
Probably meet up near my area with Meggala and anyone else??
:D
hmmmm... dont take off on me!! or i'll have to try and decifer the damn melways... and im maplexic :)
whats ur area?
Out essendon way... Just down Mt Alexander Rd...
Either that or meet at my work in Pt. Melbourne or something??
i'll consult my melways :)
ur work maybe easier... i dont work on fridays or saturdays so it wont be hard to meet u at work. where u work?
haha yeah i read that bit... i mean where am i goin to meet u? like a building? a car park? a seedy alley? a hotel booked under Mr. Smith... leave the key at the desk and make sure ur in ur lace by the time i get there :lol: i just got my superman cape ironed
Unless you're looking a lot more like a very sexy female, and actually are a very sexy female then the hotel aint happening!
How bout we meet at my work in the carpark at 4. I'll PM the addy to ya...
Doc.
Doc.
haha
ok 4pm sounds sounds good...
/shaves legs
Not sure if I'm running, pinapples wont arive till monday, can't find some 16x8 rims to borrow to put semi slicks on..... Really bad exhaust leak needs fixing, plugs need less gap as missing slightly on full boost.....
I'll still go just not sure if running.....
dr u should c if u can keep it sideways all the way through the 1/4 and see what time u can get! it may become a new sport!!:lol:
oooooooo steve.. sounds like a challenge! :rolleyes: will the good doctor take it up.. i hear lots of excuses :)
getting my alarm installed on friday morning.... i think... ****... i better call and make sure
I know what my car can do, where's the challenge in breaking it cause it's not ready? There's nothing I can do about pineapples which is the main problem with smooth launches. The rest will be done by then if I can find some time....
Challenge declined, decision will be made wihtout external influence..... HMPH!
    • Working through possible solutions of converting my mechanical speedo.    Anyone know what type of speedo sensor the factory r34 gtr getrag has ? what the output is ? I assume its not a VSS and more a voltage like earlier speedo sensors ? Can an ECU read it ?
    • roof rail delete used to be a thing, they were made locally for a while too
    • I can get more photos of it here soon and I plan to make a thread detailing the process. I received the car this way and it sorely needs refinishing. That is probably the most appealing photo of it. Up close it is fading, cracked, and needs to be re-glued. Depending on their condition I'm on the fence between refinishing or making a new set.  Another angle hiding the pimples and razor pumps
    • According to this thread the RS4V with build plate RC40 comes with the R200 diff @ 4.083 ratio as well (mine has said RC40 denotation). We may need to check if the axle stubs are the same pattern as well. The auto subframes have longer axles. However I think yours being a later Series 2 as well, we should have the same bolt pattern for the diff stubs. Unless your upgraded rear also has upgraded axles. Either way, I would not be opposed to pulling the covers to check so I can inspect that  fancy rear core  Also I don't have HICAS. I don't believe that should change things but I hope the people here with heaps more experience than me can correct me if I'm wrong   Let me know if you want to attempt to make this work and I can get some pictures of mine from under the car.
    • It's not that straightforward. For example I have had this code because my ignitor/power transistor wires were unplugged. It knows something is wrong but has no idea what it means. If you want to actually diagnose this I recommend following the service manual flowchart for code 21. Ohm out the harness, coilpacks, inspect the ECU, etc. And again, it's entirely possible for there to be no problem at all but if you're running a different coilpack it'll trigger the code because it doesn't like what it sees.
