Hey guys,
Since Ive had my Skyline R33 GTST S2 (few months now),the indicators are just not responding whatsoever when i flick the stalk left or right.
The previous owner of the car did have neons around under the car but then ripped them out and left the loose wires so i have since pulled them out.
The car does have an aftermarket alarm system if it should have anything to do with it....
I have checked the indicator fuse but it is all good,the only thing i can think of is the indicator relay (where ever it is) or a bad earth.Also i have replaced the stalk but still no good..hazards are working tho.
It has been troubling me since i bought it,can anyone please help me?
https://www.sau.com.au/forums/topic/339886-no-indicators/
Is a rwc a Road Worthy Certificate?
If it is,i didnt get actually get a road worthy certificate with the car because it was yellow stickered because it has a huge dent on the rear quarter panel hence me buying it so cheap.
https://www.sau.com.au/forums/topic/339886-no-indicators/#findComment-5488871
other than checking the relay it has to be related to the wiring... do you know if they were working prior to neons being removed? if so start from the wiring with that.
an auto elec should be able to sort that out for you fast and cheap, doesn't sound like a huge problem.
good luck.
https://www.sau.com.au/forums/topic/339886-no-indicators/#findComment-5489377
Yeah the hazards work fine,the indicator lights and that work when theyre on its just when i switch it at the stalk it dosnt work.
I'm pretty sure the indicators didnt work prior to the neons being removed.
What would i be expecting to pay if i took it down to a auto eletrician?
https://www.sau.com.au/forums/topic/339886-no-indicators/#findComment-5490352
It'll help if we knew where you were.
And even ask in your own state's subforum if someone there can help out as a sparkie.
The problem seems to be at the stalk.
^+1
If the hazards work, you've eliminated alot already. And the second hand stalk could still be the problem. A dodgy hazard switch can cause no indicators as the hazard switch over-rides the indicators. Also, to find your flasher relay, turn the hazards on and follow the noise. I'd be looking for a wiring problem between the stalk and the hazard if everything you've posted is true.
https://www.sau.com.au/forums/topic/339886-no-indicators/#findComment-5499812
The guy who i bought the second hand stalk of said the indicators were working prior to him removing it.
blk94r33, i do think i have a dodgy hazard switch,when i push the button the hazrds don't stay on because the button pops straight back out,thanks for the suggestion ill have a look at it today.
https://www.sau.com.au/forums/topic/339886-no-indicators/#findComment-5499895
Yup. Hazard switch +11ty. As I said, the hazard switch is designed to over-ride the indicators, is it's faulty it'll still over-ride the indicators, causing them not to work, and yours is faulty if the button won't stay on.
1. Get second hand hazard switch. (Check before purchase it works)
2. Fit second hand hazard switch. Fixed=go to step 3, not fixed go to step 4.
3. Drive car.
4. Check for problem in wiring between stalk, hazard switch, and flasher can. Still not fixed? Step 5.
5. Take car to auto elec or similar industry professional, as you've exhausted my vague-symptom-internet-diagnostics-capabilities, return to step 3.
https://www.sau.com.au/forums/topic/339886-no-indicators/#findComment-5499926
blk94r33 thank you soo much!! the faulty hazard switch WAS the cause of the problem.
The previous owner of the car removed the dash fascia and then removed the the hazard switch and every thing else to paint it.
When he screwed the switch back into the fascia he did it a little too tight therefore causing the switch to pop back out when you pushed it and that caused the indicators not to work.
Thanks everyone else for your help :D
https://www.sau.com.au/forums/topic/339886-no-indicators/#findComment-5500582
    • Bit of a pity we don't have good images of the back/front of the PCB ~ that said, I found a YT vid of a teardown to replace dicky clock switches, and got enough of a glimpse to realize this PCB is the front-end to a connected to what I'll call PCBA, and as such this is all digital on this PCB..ergo, battery voltage probably doesn't make an appearance here ; that is, I'd expect them to do something on PCBA wrt power conditioning for the adjustment/display/switch PCB.... ....given what's transpired..ie; some permutation of 12vdc on a 5vdc with or without correct polarity...would explain why the zener said "no" and exploded. The transistor Q5 (M33) is likely to be a digital switching transistor...that is, package has builtin bias resistors to ensure it saturates as soon as base threshold voltage is reached (minimal rise/fall time)....and wrt the question 'what else could've fried?' ....well, I know there's an MCU on this board (display, I/O at a guess), and you hope they isolated it from this scenario...I got my crayons out, it looks a bit like this...   ...not a lot to see, or rather, everything you'd like to see disappears down a via to the other side...base drive for the transistor comes from somewhere else, what this transistor is switching is somewhere else...but the zener circuit is exclusive to all this ~ it's providing a set voltage (current limited by the 1K3 resistor R19)...and disappears somewhere else down the via I marked V out ; if the errant voltage 'jumped' the diode in the millisecond before it exploded, whatever that V out via feeds may have seen a spike... ....I'll just imagine that Q5 was switched off at the time, thus no damage should've been done....but whatever that zener feeds has to be checked... HTH
    • I think Fitmit had some, have a look on there (theyre Australian as well)
    • Hah, fair enough! But if you learn with this one you can drive any other OEM manual. No modern luxury features like auto rev-matching or hillstart assist to give you a false sense of confidence. And a heavy car with not that much torque so it stalls easily.
    • Actually, I'd say all three are the automatic option. Just the different trim levels. The manual would be RSFS, no?
