I don't think it has anything to do with the cat.
As I mentioned earlier, there are two blue plugs ( see the attachment). They are the variable valve timing stuff. So If you unplug the one on the left hand side (driver's side), the noise's gone. whereas if it is plugged, you will get that ticking rattling noise up to 2000rmp and when you go over it, it disappears.
Therefore I don't think it has anything to do with the cat.
Some said it's the valve lifter, some said it's caused by a broken spring (valve spring), Nuwan said it might be timing chain.
I will take it to Nuwan's shop tomorrow as he sounds like he knows about these cars.
If it doesn't work, I'm planning to go to TAFE and do a mechanic course.
Sick and tired of it.
Edited by NISMO-61
Nuwan doesn't seem to know these electromagnetic VQ25's too well, the last guy got a 5k quote for engine out, replace cam chains etc and it wouldn't have fixed the issue. Will be interesting to see what he has to say.
Yours is a 2.5?
I can definitely have a look for you, get on to it soon as it will only get worse.
do you hear it when you rev in Neutral?
or just when your driving accelerating?
When the blue plug is plugged, you hear it in neutral ONLY when you kick the accelerator. If you let it run in idle, no problem at all.
when you drive, you hear it up to 2000rpm and then it disappears.
and is it like "metal to metal" rattling? like a tinny sound??
It's not tinny at all. It's like a rattle gun. It's a strong and disturbing sound.
Yours is a 2.5?
Mine is 3.0. VQ30DD engine.
Nuwan will have a look at it. I just rang him today and he said he is dealing with three more at the moment. I will just take it down there to see what he says.
where exactly you are Scotty. I would like to take it to your place and have a bit of discussion as well.
oh man, when you said it's not like a "tinny" sound, so not a metal to metal sound... then I would think it's not the Cats...
when you step on the accelerator in Neutral you can see hear the sound clearly is that right?
Correction, it is 'tinny'. I read is as 'tiny'. Sorry :unsure:
Yes it is tinny as if two metals are banging into each other. As i said it sounds like a rattle gun.
When I step on the accelerator in neutral, I can hear it until the rev gets over 2000rpm. Same thing happens while driving.
does the sound occur all the way from 0k rpm to 2000 rpms? or between say 1500 rpm to 2000 rpm?
and whereabouts is the sound coming from? engine bay or somewhere below the steering wheel/front wheel???
PM'd.
I have the same rattle just starting at the moment on my car, and I don't have too many spare assemblies. Mainly happens around 2200 - 2500 revs right? One clunk per revolution.
Mine happens up to 2000rpm as I believe that where the variable valve timing is needed. After 2000, there is no knocking noise at all.
Hi Nismo, how did you go? Did you end up getting the problem fixed?
I've decided to live with my noise as I'm pretty sure mine is just something loose down in the exhaust, I'll just get them to tighten some bolts down there at my next service.
I dont think I will get it fixed.
If I try to sell the car, how much you reckon I would get?
Spend 3.5K to get it fixed........ I would rather drive it this way and when its completely dead I will sell the parts and get rid of it.
The next car I would buy is not going to be any more expensive than $500.
I'm sick and tired of new technology shits.
lol fair eniough mate, but 3.5k to get it fixed? You could buy a used engine for that price isn't it?
Is it just the VCT problem?
who quoted you 3.5k? seems abit much isn't it..
  • 1 year later...
It's not the timing chain, it is usually caused by the cvt actuator assembly. I have replaced a few now with s/h assemblies and fixed the noise.
Who diagnosed it to the chain anyway?
  • Like 1
    • This seems to be a very popular swap since all the turbo skyline prices went through the roof! I'll let someone more familiar chime in, but I understand that yes you probably want to swap the loom in to swap out the auto TCM stuff. You should not assume everything just plugs in either, you need to check at least the ECU wiring diagram for any differences at the plug at the left headlight and probably the ones near the ECU that join the dash loom too
    • hows it fellas, my first post here which seems crazy cos half the forums i read are like the same age as me haha. to make a long story short ive got an r34 sedan (rb25de neo auto) which im swapping to a s0/s1? rb25det, r33 big box and nismo gt pro lsd. i have the motor and gearbox all bolted up outside the car, old motor and trans out. i bought the motor with stock ecu and loom, do i switch over to that? or will it be easier to get a r34 manual ecu and keep the loom if thats even possible.  also engine mounts look different, anything else thats different or incompatible? cheers, hope this all makes sense Paddy
    • att.4QNbuJlz_gNZPFBGFqeEvxSUHXkGt7z40V59MrtXTPg.mp4
    • Plan on the day will be to park trackside. Depending on space availability we will try put a small shade tent and a few of the cars on top of the hill inside turn 3, this is an easy to get to parking area with views of Turn 2, Turn 3, Turn 4 and Turn 5 and limited other pieces of the view around the track. IMPORTANT NOTE! One consideration from previous years is from memory the trackside parking sells out before the admission tickets, for that reason I encourage anyone planning on coming to buy tickets for parking now via the official website; https://www.worldtimeattack.com/ The type of parking you are looking for is 2 Day Park & View (Access Around Venue) Vehicle Pass Only Please note this does not include admission to the event itself, remember to grab that also, and kids under 12 get in for free!
    • This is going to be a mid week evening cruise. Come along and join us for a drive out to Palm Beach. This is a change of event plans after talking to some of the older members of the club. SAU NSW is planning on hitting Old Pac again shortly, stay tuned for details. When: Thursday 26th of June Time: 7:30pm meet/8:00pm departure/10:00pm finish Meet: Spit West Car Park / Spit Rd Mosman NSW 2088 Destination: Palm Beach Public Parking / 16 Ocean Rd Palm Beach NSW 2108 Up to date information as always can be found on the events page of our website, the link for this event is https://www.saunsw.com.au/events/palm-beach-cruise There will be a lead and follow car so no one should get lost. If you would like to attend or bring others along please put your name down and a +1 as numbers will be needed prior! This is NOT a race and we will all be adhering to all road rules. If this is what you want please come to one of our track days. This is an official SAUNSW event and will be run under a Motorsport Australia permit. One of the things that really sets our club apart is our commitment to being true enthusiasts. When on normal roads we strive to maintain good relations with the authorities as well as the public in general. When attending one of Skylines Australia NSW events please try to: • Be aware of surrounding environment and act accordingly. • Drive courteously on the state’s roads as a true enthusiast should. • Understand how important it is to maintain the good name of SAU:NSW and thus, treat others accordingly. • Any misbehavior will not be tolerated and you will be asked to leave. Thanks guys and hope to see you there!
