Hey Kurt, don't you have a spare r31 auto box??? Your best bet would be to send the spare auto box away to get built up (more clutchs, bigger bands, shift kit etc) to handle the extra power... That way it will swap straight in without any buggering around... to put a 33gts-t auto in would be alot of stuffing around.. and it won't last as long as a properly build box anyway.
Cheers
Justin
I do have a spare one. Have no idea on what condition its in, not that that matters if i build it. Whats the cost in getting one rebuilt tough? The reason for wanting a 33 auto is because there dirt cheap, and should handle what i've got for the time being. Money is gonna be a little tight for a bit, and from what i know its fairly easy to put in the 33 auto. In the long run i'll get an auto rebuilt, but for the time being i want something that can handle the power i've got. Also have heard that the 33 box launches and changes gears alot better then i 31 box. Which i can understand when its 10 years newer.
  • Replies 206
My VL turbo was around 1100 to get built up fairly well... but that was 8 years ago. Unless the 33 box slides right in, then the cost for the conversion might be 300-800 bucks depending on wiring... I doubt that the box will handle the torque though- dunno, ask marty.
Definately use redline auto trans oil whatever you do.
Turn the boost down, save some money and build a box... The cost of a box will be about the cost of a good clutch!
Cheers
Justin
Cheers
Justin
I'll talk to Martin and see what he thinks would be best. Even if i can get an R33 Auto in there for the time being and then get that built later down the track, surely a built 33 box will be better then a bulit 31 box.
Dunno. We shall see.
Cheers
  • 4 months later...
just found you on there and the links in your sig on that site dont work either and i went back through your posts to may 9th and it dosnt show any posts from you in that thread alf!
Has it been deleted or in a section you need to be a special member to access?
Not much has changed really. I did put S13 coilovers in the rear and we also found an exhuast blockage that had been there from day one. So throttle responce is a bit sharper and she spools up a bit sooner. Also fuel economy increased a fair bit too. It really needs a new transmission and a retune though. It's current tune is holding it back so much.
Should have it in the body shop to get the entire front end tidied up depending on how tax time goes. And then later this year i'll have martin putting my new gearbox in it followed by a tune. Other then a few mild hiccups we seem to have ironed out all the creases and its running really reliably.
Alrighty, thought it was about time i put up some stuff about my car. I will update this post as time goes on. And i will add pictures as soon as i get around to trying.
Firstly my car is a Blue 1986 GXE Sedan. I got the car off a family friend as a car to loan when i first arrived in Tas so i had something to get around in and to/from uni. It didn't take long for me to get attached to the car and after some browsing through these forums i soon decided i had to make it mine. I asked if i could buy the car and sure enough it was mine in no time.
Here it is:
In the early days the beast was a bit tired and and the first thing i did when i started driving it was running in on BP Ultimate (now running on Vortex 98). This made a noticable difference. Only a few other things were replaced/installed over the next few months including things like a Bosch AFM and a few other minor things i can't think of.
Early last year, around may, my car was stolen by two 16yo's and a 13yo where they took it for about a 15km thrash, which ended when they blew the exhaust off! At the time they stole the car it was still running like a pig and i hadn't really spent any money on it. The little pricks were caught later on that day in a Subaru Liberty after stealing about 4 cars. (The 16yo driving was pursued by police in december after another string of car thefts and was run over by the police, which resulted in 2 broken legs. I was quite happy to hear that.)
I took the car around to the mechanic who i had been talking to for quiet some time and we had a full custom exhaust (Stock extractors) an oil cooler for the auto transmision and a few other minor things that i can't recall.
After some TLC the car ran better then she had before but as always these things never really last and soon i had a failing fuel pump so that was replaced with a Bosch 040. The next thing to cause trouble was the crank angle sensor which was replaced and made the car run like never before.
Now, onto the more serious stuff, i had finally got some money together to start some performance work on my car. I first purchased a new motor off a bloke who had it partially rebuilt with forged parts and had the valves polished. It also has a 292degree cam in the sucker. Along with the engine i purchased a Garret GT3082 with the housing brought out a bit. I dropped the car in to get the engine installed along with the sts turbo setup. Now for my turbo setup we have it mounted where the muffler normally would be with a straight tail pipe coming out of the turbo, it's got an external Sard wastegate and a lot of pipework up to the inlet. At the moment i don't have an intercooler yet but it seams to be doing fine, i can take it out and thrash it, hop out while she's still running and hold onto the intake directly above the engine with out burning my hands off.
Along with the engine i got bigger injectors, Nistune, a stall convertor and i've drawn a mental blank. Will update this when i get home.
The results,
Stock: 66rwkw and 193Nm Torque.
Modifided: 163rwkw, 434Nm Torque on about .8Bar
At this point i'll mention that we were making 175rwkw on the dyno with a few more pounds of boost to go, but the auto was slipping so we tuned it back to 165rwkw for the time being so the box doesn't shit it self too soon.
When i get home i will update this and include install pics and dyno results along with a more detailed list of mods to date.
Home now:
Will get back to ya's soon.
Cheers
Kurt
Here's a link to the thread in SAU: http://www.skylinesaustralia.com/forums/topic/340173-sts-turbo-setup/
And here's some dyno results, before and after. Just keep in mind the auto is rooted!
Got another picture here for ya's.
Just a picture of the setup sitting in the boot.
Wasn't completely put together though but gives you an idea.
Been a bit slack, i don't think much has changed on the car.
Bought some rims yesterday, 17X7, unsure on the offset. Here they are:
Unsure if i'm going to put them on or not. Will see what they look like, if they stand out to much i might not bother. Bought them cheap (The four rims with tyres in the pic plus 4 hald decent tyres for $150).
If i decide i don't want them my brother in law wants them for his s13 so we shall wait and see.
Haven't got a picture of the boot spoiler yet, but will do this arvo hopefully. It has a nice crack along it but i'll get that fixed eventually.
Now for those of you who don't already know, early march i had some scum smash my windscreen and scratch the bonnet. Was due for a new windscreen any way, so i'm not really out of pocket. Plus when they get charged (we know who they are) my insurance will refund my my excess. Here's a picture for ya's:
Any who, within the month she'll be fixed (already replaced the windscreen). I'm getting some more work done at the same time. The whole bonnet will be fixed (a few stone chips) and resprayed along with the two gaurds fixed up, resprayed and the inner lips rolled a little for when i get rota rims. Also the lip along the top of the bumper done along with my brand new standard front bumper installed and resprayed. Will also be getting the rest of the car cut and polished to make matching the paint easier and to make her look a bit nicer. So pretty much everything infront of the doors will look as new. Unfortunatly thats all i could afford at the moment. I will get before and after pictures for ya's of course.
Need some input though. Should i have the little silver badge (the one that says ultra) on the front of the bonnet removed and smoothed over or keep it? I think i want to keep it. unsure. Also, do i need the plastic on the inside of the gaurds? If not i'll rip them out when i get home cause i'm healthy of them rubbing (front suspension need replacing) plus they'll need to be cut when they roll the gaurds i assume. Ah and one last thing, is there any need got the sound deadning under the bonnet? Or should i turf that too.
Cheer fulla's.
Will get some pics of the boot for ya's soon.
    • Wow, thanks for your help guys 🙏. I really appreciate it. Thanks @Rezz, if i fail finding any new or used, full or partial set of original Stage carpets i will come back to you for sure 😉 Explenation is right there, i just missed it 🤦‍♂️. Thanks for pointing out. @soviet_merlin in the meantime, I received a reply from nengun, and i quote: "Thanks for your message and interest in Nengun. KG4900 is for the full set of floor mats, while KG4911 is only the Driver's Floor Mat. FR, RH means Front Right Hand Side. All the Full Set options are now discontinued. However, the Driver's Floor Mat options are still available according to the latest information available to us. We do not know what the differences would be, but if you only want the one mat, we can certainly see what we can find out for you". Interesting. It seems they still have some "new old stock" that Duncan mentioned 🤔. I wonder if they can provide any photos......And i also just realized that amayama have G4900 sets. I'm tempted too.
    • Any update on this one? did you manage to get it fixed?    i'm having the same issue with my r34 and i believe its to do with the smart entry (keyless) control module but cant be sure without forking out to get a replacement
    • So this being my first contribution to the SAU forums, I'd like to present and show how I had to solve probably one of the most annoying fixes on any car I've owned: replacing a speedometer (or "speedo") sensor on my newly acquired Series 1 Stagea 260RS Autech Version. I'm simply documenting how I went about to fix this issue, and as I understand it is relatively rare to happen to this generation of cars, it is a gigantic PITA so I hope this helps serve as reference to anyone else who may encounter this issue. NOTE: Although I say this is meant for the 260RS, because the gearbox/drivetrain is shared with the R33 GTR with the 5-speed manual, the application should be exactly the same. Background So after driving my new-to-me Stagea for about 1500km, one night while driving home the speedometer and odometer suddenly stopped working. No clunking noise, no indication something was broken, the speedometer would just stop reading anything and the odometer stopped going up. This is a huge worry for me, because my car is relatively low mileage (only 45k km when purchased) so although I plan to own the car for a long time, a mismatched odometer reading would be hugely detrimental to resale should the day come to sell the car. Thankfully this only occurred a mile or two from home so it wasn't extremely significant. Also, the OCD part of me would be extremely irked if the numbers that showed on my dash doesn't match the actual ageing of the car. Diagnosing I had been in communication with the well renown GTR shop in the USA, U.P.garage up near University Point in Washington state. After some back and forth they said it could be one of two things: 1) The speedometer sensor that goes into the transfer case is broken 2) The actual cluster has a component that went kaput. They said this is common in older Nissan gauge clusters and that would indicate a rebuild is necessary. As I tried to figure out if it was problem #1, I resolved problem #2 by sending my cluster over to Relentless Motorsports in Dallas, TX, whom is local to me and does cluster and ECU rebuilds. He is a one man operation who meticulously replaces every chip, resistor, capacitor, and electronic component on the PCB's on a wide variety of classic and modern cars. His specialty is Lexus and Toyota, but he came highly recommended by Erik of U.P.garage since he does the rebuilds for them on GTR clusters.  For those that don't know, on R32 and R33 GTR gearboxes, the speedometer sensor is mounted in the transfer case and is purely an analog mini "generator" (opposite of an alternator essentially). Based on the speed the sensor spins it generates an AC sine wave voltage up to 5V, and sends that via two wires up to the cluster which then interprets it via the speedometer dial. The signal does NOT go to the ECU first, the wiring goes to the cluster first then the ECU after (or so I'm told).  Problems/Roadblocks I first removed the part from the car on the underside of the transfer case (drain your transfer case fluid/ATF first, guess who found out that the hard way?), and noted the transfer case fluid was EXTREMELY black, most likely never changed on my car. When attempting to turn the gears it felt extremely gritty, as if something was binding the shaft from rotating properly. I got absolutely no voltage reading out of the sensor no matter how fast I turned the shaft. After having to reflow the solder on my AFM sensors based on another SAU guide here, I attempted to disassemble the silicone seal on the back of the sensor to see what happened inside the sensor; turns out, it basically disintegrated itself. Wonderful. Not only had the electrical components destroyed themselves, the magnetic portion on what I thought was on the shaft also chipped and was broken. Solution So solution: find a spare part right? Wrong. Nissan has long discontinued the proper sensor part number 32702-21U19, and it is no longer obtainable either through Nissan NSA or Nissan Japan. I was SOL without proper speed or mileage readings unless I figured out a way to replace this sensor. After tons of Googling and searching on SAU, I found that there IS however a sensor that looks almost exactly like the R33/260RS one: a sensor meant for the R33/R34 GTT and GTS-T with the 5 speed manual. The part number was 25010-21U00, and the body, plug, and shaft all looked exactly the same. The gear was different at the end, but knowing the sensor's gear is held on with a circlip, I figured I could just order the part and swap the gears. Cue me ordering a new part from JustJap down in Kirrawee, NSW, then waiting almost 3 weeks for shipping and customs clearing. The part finally arrives and what did I find? The freaking shaft lengths don't match. $&%* I discussed with Erik how to proceed, and figuring that I basically destroyed the sensor trying to get the shaft out of the damaged sensor from my car. we deemed it too dangerous to try and attempt to swap shafts to the correct length. I had to find a local CNC machinist to help me cut and notch down the shaft. After tons of frantic calling on a Friday afternoon, I managed to get hold of someone and he said he'd be able to do it over half a week. I sent him photos and had him take measurements to match not only the correct length and notch fitment, but also a groove to machine out to hold the retentive circlip. And the end result? *chef's kiss* Perfect. Since I didn't have pliers with me when I picked up the items, I tested the old gear and circlip on. Perfect fit. After that it was simply swapping out the plug bracket to the new sensor, mount it on the transfer case, refill with ATF/Nissan Matic Fluid D, then test out function. Thankfully with the rebuilt cluster and the new sensor, both the speedometer and odometer and now working properly!   And there you have it. About 5-6 weeks of headaches wrapped up in a 15 minute photo essay. As I was told it is rare for sensors of this generation to die so dramatically, but you never know what could go wrong with a 25+ year old car. I HOPE that no one else has to go through this problem like I did, so with my take on a solution I hope it helps others who may encounter this issue in the future. For the TL;DR: 1) Sensor breaks. 2) Find a replacement GTT/GTS-T sensor. 3) Find a CNC machinist to have you cut it down to proper specs. 4) Reinstall then pray to the JDM gods.   Hope this guide/story helps anyone else encountering this problem!
    • So this being my first contribution to the SAU forums, I'd like to present and show how I had to solve probably one of the most annoying fixes on any car I've owned: replacing a speedometer (or "speedo") sensor on my newly acquired Series 1 Stagea 260RS Autech Version. I'm simply documenting how I went about to fix this issue, and as I understand it is relatively rare to happen to this generation of cars, it is a gigantic PITA so I hope this helps serve as reference to anyone else who may encounter this issue. NOTE: Although I say this is meant for the 260RS, because the gearbox/drivetrain is shared with the R33 GTR with the 5-speed manual, the application should be exactly the same. Background So after driving my new-to-me Stagea for about 1500km, one night while driving home the speedometer and odometer suddenly stopped working. No clunking noise, no indication something was broken, the speedometer would just stop reading anything and the odometer stopped going up. This is a huge worry for me, because my car is relatively low mileage (only 45k km when purchased) so although I plan to own the car for a long time, a mismatched odometer reading would be hugely detrimental to resale should the day come to sell the car. Thankfully this only occurred a mile or two from home so it wasn't extremely significant. Also, the OCD part of me would be extremely irked if the numbers that showed on my dash doesn't match the actual ageing of the car. Diagnosing I had been in communication with the well renown GTR shop in the USA, U.P.garage up near University Point in Washington state. After some back and forth they said it could be one of two things: 1) The speedometer sensor that goes into the transfer case is broken 2) The actual cluster has a component that went kaput. They said this is common in older Nissan gauge clusters and that would indicate a rebuild is necessary. As I tried to figure out if it was problem #1, I resolved problem #2 by sending my cluster over to Relentless Motorsports in Dallas, TX, whom is local to me and does cluster and ECU rebuilds. He is a one man operation who meticulously replaces every chip, resistor, capacitor, and electronic component on the PCB's on a wide variety of classic and modern cars. His specialty is Lexus and Toyota, but he came highly recommended by Erik of U.P.garage since he does the rebuilds for them on GTR clusters.  For those that don't know, on R32 and R33 GTR gearboxes, the speedometer sensor is mounted in the transfer case and is purely an analog mini "generator" (opposite of an alternator essentially). Based on the speed the sensor spins it generates an AC sine wave voltage up to 5V, and sends that via two wires up to the cluster which then interprets it via the speedometer dial. The signal does NOT go to the ECU first, the wiring goes to the cluster first then the ECU after (or so I'm told).  Problems/Roadblocks I first removed the part from the car on the underside of the transfer case (drain your transfer case fluid/ATF first, guess who found out that the hard way?), and noted the transfer case fluid was EXTREMELY black, most likely never changed on my car. When attempting to turn the gears it felt extremely gritty, as if shttps://imgur.com/6TQCG3xomething was binding the shaft from rotating properly. After having to reflow the solder on my AFM sensors based on another SAU guide here, I attempted to disassemble the silicone seal on the back of the sensor to see what happened inside the sensor; turns out, it basically disintegrated itself. Wonderful. Not only had the electrical components destroyed themselves, the magnetic portion on what I thought was on the shaft also chipped and was broken. Solution So solution: find a spare part right? Wrong. Nissan has long discontinued the proper sensor part number 32702-21U19, and it is no longer obtainable either through Nissan NSA or Nissan Japan. I was SOL without proper speed or mileage readings unless I figured out a way to replace this sensor. After tons of Googling and searching on SAU, I found that there IS however a sensor that looks almost exactly like the R33/260RS one: a sensor meant for the R33/R34 GTT and GTS-T with the 5 speed manual. The part number was 25010-21U00, and the body, plug, and shaft all looked exactly the same. The gear was different at the end, but knowing the sensor's gear is held on with a circlip, I figured I could just order the part and swap the gears. Cue me ordering a new part from JustJap down in Kirrawee, NSW, then waiting almost 3 weeks for shipping and customs clearing. The part finally arrives and what did I find? The freaking shaft lengths don't match. $&%* I discussed with Erik how to proceed, and figuring that I basically destroyed the sensor trying to get the shaft out of the damaged sensor from my car. we deemed it too dangerous to try and attempt to swap shafts to the correct length. I had to find a local CNC machinist to help me cut and notch down the shaft. After tons of frantic calling on a Friday afternoon, I managed to get hold of someone and he said he'd be able to do it over half a week. I sent him photos and had him take measurements to match not only the correct length and notch fitment, but also a groove to machine out to hold the retentive circlip. And the end result? *chef's kiss* Perfect. Since I didn't have pliers with me when I picked up the items, I tested the old gear and circlip on. Perfect fit. After that it was simply swapping out the plug bracket to the new sensor, mount it on the transfer case, refill with ATF/Nissan Matic Fluid D, then test out function. Thankfully with the rebuilt cluster and the new sensor, both the speedometer and odometer and now working properly!   And there you have it. About 5-6 weeks of headaches wrapped up in a 15 minute photo essay. As I was told it is rare for sensors of this generation to die so dramatically, but you never know what could go wrong with a 25+ year old car. I HOPE that no one else has to go through this problem like I did, so with my take on a solution I hope it helps others who may encounter this issue in the future. For the TL;DR: 1) Sensor breaks. 2) Find a replacement GTT/GTS-T sensor. 3) Find a CNC machinist to have you cut it down to proper specs. 4) Reinstall then pray to the JDM gods.   Hope this guide/story helps anyone else encountering this problem!
    • perhaps i should have mentioned, I plugged the unit in before i handed over to the electronics repair shop to see what damaged had been caused and the unit worked (ac controls, rear demister etc) bar the lights behind the lcd. i would assume that the diode was only to control lighting and didnt harm anything else i got the unit back from the electronics repair shop and all is well (to a point). The lights are back on and ac controls are working. im still paranoid as i beleive the repairer just put in any zener diode he could find and admitted asking chatgpt if its compatible   i do however have another issue... sometimes when i turn the ignition on, the climate control unit now goes through a diagnostics procedure which normally occurs when you disconnect and reconnect but this may be due to the below   to top everything off, and feel free to shoot me as im just about to do it myself anyway, while i was checking the newly repaired board by plugging in the climate control unit bare without the housing, i believe i may have shorted it on the headunit surround. Climate control unit still works but now the keyless entry doesnt work along with the dome light not turning on when you open the door. to add to this tricky situation, when you start the car and remove the key ( i have a turbo timer so car remains on) the keyless entry works. the dome light also works when you switch to the on position. fuses were checked and all ok ive deduced that the short somehow has messed with the smart entry control module as that is what controls the keyless entry and dome light on door opening   you guys wouldnt happen to have any experience with that topic lmao... im only laughing as its all i can do right now my self diagnosed adhd always gets me in a situation as i have no patience and want to get everything done in shortest amount of time as possible often ignoring crucial steps such as disconnecting battery when stuffing around with electronics or even placing a simple rag over the metallic headunit surround when placing a live pcb board on top of it   FML
