So when i want to "DECC" in campbelltown to noice test what is that called
Did you go to an inspection station, or the actual DECC?
I've had noise tests at exhaust shops, blue slippers, etc etc.
It all depends on what you've been sent where for. But the order, normally either comes from:
The RTA.
The DECC.
The Police.
Each of them can send you for a noise test at various places.
Just wanted to know if anyone knows much about exhaust...
if i put two cats on a stock exhaust would that pass EPA not DECC..
Thanks for all your help
Putting 2 cats on a stock exhaust will do virtually nothing to noise output of a stock exhaust. Should help bring the emissions down although 1 cat should be sufficient.
the onyl EPA places are penrith and botany. these two places run the IM240 tests which test emissions.
the place you went to was just to check that your emissions gear was in and in working order (pretty much all of your stock gear is on). they also do a noise test.
Edited by SECURITY
Just passed EPA...need to find out something i have a pinging noise in fuel line i cant hear it but the guy at EPA said i do... any help
lol wat?
Pinging noice in the fuel line???
no idea what he could be on about,
  • 4 weeks later...
  • 1 month later...
Sent you a message tonight mate,,,I would like my loaned parts back please. It's rather annoying,,,other peeps need to clear their defects as well and as I told you I need some of those bits for my own car.
Cheers
Neil.
    • Yeah, it's getting like that, my daughter is coming over on Thursday to help me remove the bonnet so I can install the Carbuilders underbonnet stuff,  I might get her to give me a hand and remove the hardtop, maybe, because on really hot days the detachable hardtop helps the aircon keep the interior cool, the heat just punches straight through to rag top I also don't have enough hair for the "wind in the hair" experience, so there is that....LOL
    • Could be falling edge/rising edge is set wrong. Are you getting sync errors?
    • On BMWs what I do because I'm more confident that I can't instantly crush the pinch welds and do thousands of USD in chassis damage is use a set of rubber jacking pads designed to protect the chassis/plastic adapter and raise a corner of the car, place the aforementioned 2x12 inch wooden planks under a tire, drop the car, then this normally gives me enough clearance to get to the front central jack point. If you don't need it to be a ramp it only needs to be 1-1.5 feet long. On my R33 I do not trust the pinch welds to tolerate any of this so I drive up on the ramps. Before then when I had to get a new floor jack that no longer cleared the front lip I removed it to get enough clearance to put the jack under it. Once you're on the ramps once you simply never let the car down to the ground. It lives on the ramps or on jack stands.
