Hi all. Got some stuffs to let go as below. They are all in superb condition. Do let me know if you require more details/pics. All prices are excluding delivery. Some nego might be possible if you are keen. Of course that depends on the item posted.
I will update this thread regularly as and when there are new items to let go. Thanks.
AFTERMARKET PARTS
1) Used ER34 HKS Intercooler Type S - AUD1,000
Immaculate condition. Kit set for the ER34. Will fit the ECR33 also. It comes complete with the intercooler, piping set, silicone hoses, jubilee clips, brackets, screws, washers and also the user and installation manual.
2) ECR33 & ER34 Nismo Tension Rods - AUD150
Immaculate condition. Improves the steering of your vehicle. They use strengthened rubber bush to reduce flex and in turn make the car more predictable during cornering. The body of the Nismo Tension Rods offer twist and fatigue resistance while still is very light weight; and high rigidity compared to the stock factory unit. Will also fit S14 and S15 Silvia.
3) Brand new ER34 HKS Super Dragger Exhaust System - AUD640
Features a seamless muffler shell. The exhaust system bears a 5" diameter muffler tip with 3.5" mandrel bent piping. It sounds great and brings out the RB engine note beautifully.
4) Used BNR34/ECR33 Series 2 Splitfire Super Direct DI Ignition System - AUD490
Immaculate condition. Splitfire Super Direct DI Ignition System for the Nissan Skyline R34 GT-R (BNR34) and Nissan Skyline ECR33 Series 2 (Part No. SF-DIS-005). Even comes with the manual!
5) Brand new R32 GT-R & GT-S Cusco Oil Catch Tank - AUD190
ORIGINAL Cusco Oil Catch Tank for the Nissan Skyline R32 GT-R and GT-S. This is a kit set thus will be supplied with all necessary mounting and fittings for a perfect fitment. Very rare indeed as most on the market are universal models.
6) Used R33 HKS Kansai Service Floor Mats - AUD280
Immaculate condition. With HKS Kansai Service logo on the mats and fits perfectly like the original items. These are a rarity and will definitely spruce up your interior of your R33 Skyline like no other.
7) Used HKS Circle Earth - AUD210
Immaculate condition HKS Circle Earth Grounding System. The kit comes with 8 grounding lines. All the lines are run from the 24 karat gold plated distribution block.
8) Brand new SARD Cooling Spray (SCS) - AUD250
The kit contains a 2.2 litre water tank and a pump that is controlled by an electronic system. It allows water to be sprayed onto cooling system components. During spirited drives or track excursions, you can see intake and engine temperatures rise significantly. Adding water to the core of your intercooler can aid the cooling process.
9) Used Sard R2D2 Blow Off Valve - AUD130
Immaculate condition. This is a kit set for the the Nissan Skyline R34 GTT (ER34). As the pictures will show, it's immaculate and comes complete with all the fittings required for a plug and play fit onto the RB25DET engine. It even comes with the manual and box.
10) Used Tomei Fuel Pump Relay Harness - BNR34 - AUD70
Immaculate condition. Tomei Fuel Pump Relay Harness for the Nissan Skyline R34 GT-R (BNR34). This wire harness is complete kit set for the RB26DETT. From the factory, the BNR34 fluctuates the amount of electric current to a fuel pump by fuel pump modulator in order to reduce noise and power consumption. However once the engine has been tuned for more power this will prevent a stable fuel pressure. The Tomei fuel pump relay harness is made to obtain a stabilized fuel pressure by taking voltage directly from a battery, and makes it possible to extract the full 100% performance potential from the BNR34.
11) Used NISMO G-Max Twin Plate Clutch Kit (3002B-RSR45) - BNR34 - AUD 390
Immaculate condition. Nismo G-Max Twin Plate Clutch Kit (Part No. 3002B-RSR45) for the Nissan Skyline R34 GT-R (BNR34). This set comprises of:-
Clutch Cover (3021B-RS061)
Clutch Plate Set (30125-RS020)
Flywheel (1231C-RSR45)
3X M6 Cap Bolts (30131-RS020)
9X M9 Hex Bolts (30132-RS020)
6X Flywheel Bolts (12315-42L11)
You'll need to purchase the Nismo Clutch Disc (3010C-RS040) if you would like to use the clutch. With that, this clutch set will be essentially as good as new at a fraction of the price.
STOCK ITEM
1) R34 Skyline Xenon Headlights - AUD1,350
Immaculate condition. Comes complete with wirings, HID ballast, bulbs, mounting brackets intact, etc...
2) R34 Rear Lights - AUD370
Immaculate condition. Comes complete with bulbs and wirings.
3) BNCR33 Front Grille with Emblem - AUD220
Immaculate condition. Nissan Skyline R33 GT-R grille with the GT-R logo. It is in excellent condition, there are no scratches, all brackets are intact and the plastic mesh is perfect.
4) R34 Crank Angle Sensor - AUD150
Crank Angle Sensor off a R34 Nissan Skyline. This will fit the BNR34 and ER34 model.
5) BNR34 Skyline GTR Oil Sump and Differential - offer me
Perfect for an extended oil sump project.
6) R34 Driver & Passenger Airbag - Offer me
In perfect working order.
7) BNR34 Stock Turbo Outlet Pipe (with heat shields) - AUD200
Excellent upgrade for earlier RB26DETT.
8)BNR34 Stock Manifold (with heat shields) - AUD200
9) BNR34 Skyline GTR Throttle Bodies - AUD300
10) ER34 Stock side mount intercooler with air guide - AUD 190
Excellent upgrade for earlier ECR33.
11) BNR34 Stock Fuel Rail + Fuel Regulator - AUD60
firstly would u separate the sump baffles/windage traysand how much for the sard cooling spray thingy
Re: Location...
From memory hes in Kuala Lumpar...
Now, Ill offer you $200 for STD Manifolds, Dumps & Heat Shields for Both...
Depending on frieght costs.
hay mate, ill take the nismo tension rods.
can u get me a price delivered to 3032 then send me ur bank details via pm that would be awesome
cheers
julz
XKLABA, the exhaust is for the ER34. With some modifications on mountings I guess it should be able to fit. It's not going to be 100% tho.
Yes the massive GReddy intercooler is still up for sale.
SOLD:-
2) BNR34 Stock Turbo Outlet Pipe (with heat shields)
4) ER34 HKS Intercooler Type S
5) NISMO G-Max Twin Plate Clutch Kit
  • 3 weeks later...
SOLD:-
6) HKS Super Dragger Exhaust System
7) Sard R2D2 Blow Off Valve
Edited by 8110
SOLD:-
8) Brand new ER34 HKS Super Dragger Exhaust System
SOLD:-
9) ECR33 & ER34 Nismo Tension Rods
10) R33 HKS Kansai Service Floor Mats
11) R34 Rear Lights
  • 3 weeks later...
SOLD:-
11) R34 Rear Lights
12) Used HKS Circle Earth
    • Have a vb in honour of the car comming back
    • It was a great, but typical track day, and some VB was ingested at the night time debrief 🤪
    • And so, to round this out, I couldn't be happier to confirm @MBS206 has decided to buy the car. He drove down from sunny QLD with a trailer last week and it is off to its new home today. I'll let Matt confirm on next steps but I understand broadly that the plan is to leave it pretty much as is, and just get some quality wheel time with a nicely balanced car that is pretty much track ready. There are a few a jobs still to be done first but nothing too major and I think its a very smart buy Dinner last night at the Paragon with a round of VBs (mostly) for Neil
    • Well, 50 pages and the end of a chapter for this car. We took it out for a shakedown at Wakie yesterday, and everything went well. There were a couple of niggles: - Oil cooler fitting leak - tightened, cleaned, stopped leaking - Radiator cap overflow fitting was leaking....Mark called it, the overflow fitting was threaded in and not tight....tightened, tested and held pressure - Small oil leak at the rear of the block, probably the turbo oil feed - too hot to get at it comfortably but probably just needs to be nipped up - leak at the driver's side rear brake line where it meets the hardline. Fitting wasn't loose, so Matt backed it off and back on, no further leaks - there's also a leak somewhere on the top of the fuel tank, maybe that cross over fuel line - that was has been left to fix when its on a hoist Otherwise than those niggles the car went great, turned great and stopped great so it was a very successful day out. I'm always really nervous when a car first hits the track after a long break, especially with a brand new engine as well but it was great. VID-20251011-WA0007.mp4  Big thanks to @The Bogan who dropped by and helped out, @MBS206 and my nephew Lachlan the apprentice.  Neil's wife Mel also surprised the hell out of all of us by dropping by; she's up in Tamworth these days but was travelling to Melbourne so had plausible deniability for turning up at the garage, it was great to see her but also obviously a bit sad all round.
    • Skyline R33 Series 2 sedan tail lights in excellent condition. These are becoming harder to find, especially in this state.    BOTH SETS ARE IN FANTASTIC CONDITION (REFER TO PHOTOS)    ✅ No broken covers or cracks ✅ Lenses are in flawless condition ✅ All rear mounting lugs intact ✅ Comes complete as pictured ✅ Perfect for restoration, replacement, or upgrade   These lights are ready to go, no surprises just quality OEM parts.   These are definitely one of the better sets we have seen in a while. With minimal wear and tear they will come as you see. Bear in mind they are not brand new they are almost 30 years old now. To find them in this condition isn’t easy they can only be obtained on the second hand market.   Australia Wide Postage Available At Buyers Expense. Silver Set:$850 Grey Set:$850 PM Me for purchase or any other questions  IMG_2166.dng IMG_2165.dng IMG_2172.dng IMG_2173.dng IMG_2174.dng IMG_2179.dng IMG_2180.dng IMG_2260.dng IMG_2258.dng IMG_2259.dng IMG_2261.dng IMG_2266.dng IMG_2273.dng IMG_2274.dng IMG_2276.dng
