the info I read ages ago that I cant find again you eather use standard 2jz bearings or off the shelf over sized ones
Simple more compression and a bit stronger bottem end for half the price if you can get a good set of standard ones
yeah well Im only after 310-320rwkw but I think that just gona be a bit to far for a standard na internals and not enough power to justify spending $2500 or so on internals so Thought I may aswell ask the question to see if it is easy or its to much hassle for the money saved
it'll cost you more to get 2jz bits in, than it will to just buy a set of pistons and rod bolts mate.
i mean that is if its even possible.
given what complete 2jz motors sell for, i wouldn't think a bottom end would be all that cheap also?
Was more thinking ring gas motor sports or somthing and see if they had a good set they had pulled out of a motor they had rebuilt.
While you keep saying it would be cheaper and less hassale to forge build it. I was thinkig the same but unless I asked I would never no what was involved
I had no intentions of doing it unless I could find people who had done it and wasnt much involved and could get the 2jz bits for a good price. Im not stupid that I would just go waste money and try in with out info to back it up
So all you are doing is backing up what I suspected so theres no piont posting unless you have tryed or know of some one who has that has succeed or failed
spose, i just usually build somethign to last, and i would never use a standard bottom end. bearings ect are a few hundred, machining, balancing, crank collar, all the other extra's. hell i even clearanced my own bearings and all. 25gearbox to hold it up, theres another 2grand.
but if we are talking about a "budget" build, im still convinced of buying a 2jz halfcut with a box and with left over money throw it at some add-ons.
a 2jz halfcut with a 6 speed is over 5k isn't it?
Well to buy a V160 with a clutch etc is around 5-6k depending on what else comes with it....So I would say a Manual 2JZGTE halfcut would be bloody expensive
The cheapest way would be a 1JZ manual half cut ($3500) with a 2JZ NA bottom end ($1000).
Yet of coarse you run into the barrier of, who's gonna do your work and at what cost?
My 2c
    • I'm not normally one for posting random videos, but I thought we'd all appreciate the honesty about how broken our cars tend to be lol. Genuine skyline life here.
    • New CAS just turned up from NZ Wiring. Looks like a nice bit of gear.  So, yeah. Triggered, bro. Realised I may as well do the cam belt while mucking about with it so will order one of them.
