My Stagea is featured in Japanese performance magazine this month.
The guy that wrote the article did seem to quite like the car - although he did seem to lose the plot a bit during a full lauch :P (I did tell him to put on the harness earlier :O )
Maybe he still was a bit mixed later up cos he seems to have got a fair bit of the spec wrong as well as some other details . Still never mind a features a feature.
Anyway I am now able to post some of the photoshoot pictures as I am allowed to use them once the magazine is out.
The static shots were taken at abbey who were kind enough to lend us the back car park (thanks tony )
Ive got a complete CD of pics but will only bore you guys with these
The obligatory engine pic
Th drive home
the rolling shots are awesome!
but, i dont know anything about photography - but it seems like the static shots in the carpark, the lighting is a bit out of whack. the light is hitting in all the place you don't want, and making the car look quite dirty and scratched up - which obviously isn't the case based on the rolling shots.
Looks really nice mate!
Is it actually a Tomei engine?
No but has a fair few tomei parts
Block is early N1 and bored out to max
Bearings acl bolts arp
but the following are Tomei
pistons, rods cams lifters adj pulleys c/belt oil pump h/gasket, probably missed a few bits.
turbos 2860-5s
hks v pro gold ecu
runs just over 500bhp at the hubs (whatever that is in KW)
    • I refreshed the OEM injectors with the kit and connected it up. It now ideals okay even with the IACV removed. Driving still has the same cutoff issue like the 550cc injectors so the issue is somewhere else. I bought FPG's Fuel Pump Hanger. I will be installing it next, but it is not as straightforward as I thought it was with my limited wiring knowledge and no instruction on the specific model I purchased (FPG-089). I also got the incorrect billet clamp as I could not find info on the OEM sizing.
    • Stop looking at the garage floor, and turn the radio up a bit louder if there's any strange noises...
    • No. Turbo shuffle and surge/flutter are not the same thing. Specifically, on a GTR, turbo shuffle has a definite meaning. On a GTR, the twin turbos are assumed to be the same thing and to operate the same way, exactly. In reality, they do not. Their exhaust sides are fed and exhaust a little differently, to each other. Their inlet sides are fed and exhausted a little differently, to each other. Consequently, when they are "working" they are often at slightly different points on the compressor map compared to each other. What this means, particularly when coming on boost, is that one of them will spool up and start producing extra flow compared to the other, which will put back pressure on that other compressor, which will push the operating point on that other compressor up (vertically). This will generally result in it bumping up against the surge line on the map, but even if it doesn't, it upsets the compressor and you get this surging shuffle back and forth between them That is "turbo shuffle" on a GTR. It is related to other flutter effects heard on other turbo systems, but it is a particular feature of the somewhat crappy outlet piping arrangement on RB26s. There are plenty of mods that have been attempted with varying levels of success. People have ground out and/or welded more material into the twin turbo pipe to try to prevent it. Extending the divider inside it works, removing material doesn't. There are aftermarket replacement twin turbo pipes available, and these exist pretty mush purely because of this shuffle problem.
    • You can temporarily* use lock collars to keep it in place until you can do the bushes, back the nuts off, slide them in, snug back up. *temporarily is often for ever
    • Thanks for the quick reply. To be clear, when you say turbo shuffle do you mean turbo flutter "stustustu" or referring to something else? I had thought they were the same thing. When I wrote the post my intention was to say it wasn't a flutter/compression surge sound. My understanding was that a flutter sound would be occurring when throttle is released, whereas I can keep the throttle in the same position for this noise
