hey all, just trying to wonder what the awd system of the stage is based on? (s2) so r33 setup
is it a mechanical diff or electrical diff?
torsen, viscose etc setup???
from what i know and have been told, it stays in rwd until it feels that the rear is exceeding its torque output and to stop it from slipping it will engage the front.
or is it just clutch driven??? clutch is disengaged until it feels slippage etc and then presses clutch together to connect the front wheels??
Jean
https://www.sau.com.au/forums/topic/340964-c34-stagea-awd-system/
  • Replies 49
at the rear of the gearbox is a 4 or 5 row chain that wraps around the exit shaft
the chain runs into the transfer box where it meets the front drive shaft
between the shaft and the chain is a series of clutch packs which are designed to slip al little (a bit like an auto box) when some power is needed up front, the pump adds pressure to the clutch packs and some of the torque/power is transfered to the front wheels
the max power to the rear is 100% and when the clutch packs are fully engaged the torque split is 50:50
Thanks for posting this info up. I was also wondering how the drive system works.
Dunno what you'd have to be doing to get 100% driveto the front wheels or 50:50 as you also called it. Even "popping" the clutch at 4000rpm while rolling in 1st gear with my brass button exeedy clutch makes the gauge for the front drive move a lil bit.
aaaah, this is pretty cool. sounds interesting, may google more
I ran it through Google as well (on between load 200ton trucks at work) and found some great info on it on Wikipedia. There was even a video on it! I will be having an indepth look as soon as I get home.
Its a bloody awesome drivetrain. The Japanese are bloody Clever!
Max power while the system is operating normally is 95% to the rear. This is why you can't just pull the fuse to go in to 2WD mode, there is a procedure and it works, 100% RWD.
The system is pretty much based on the R33 GTS4 system, runs 5% preload to the front and splits more torque as it feels it's needed.
Another truck driver or a loader driver at a mine? I drive container trucks - mere 45 tonne max!
Yup. I work in a coal mine. I operate the smallest Digger there which weighs 300ton. Most of the others are 600tonners and the largest 2 are 1200tonners... Those babys can dump 100tons of dirt on a truck in one scoop! :D
anyone got the link to that rwd procedure (the one that you can leave the front driveshaft in)
I have posted it up a number of times...
But here goes again..
Locate the "air bleed" wire behind the drivers kick panel, it's a plug with a single wire either side (usually green socket, white plug).
Disconnect it.
Start car. As key comes back to the ON position, within 10 seconds, depress brake pedal 5 times, 4WD light will start flashing to indicate you are in 2WD mode.
To go back to 4WD mode, turn car off, reconnect plug and off you go.
I have hooked mine to a switch in the centre console.
    • Sounds like you've got an interesting adventure ahead here with local support if you have trouble! My guess is that, unboosted, you will be OK with a small upgrade like -9. What will happen is that once the stock ECU sees more airflow than it expects it will add a heap of fuel and pull a heap of timing to be safe because it can't understand how it could get that much air without there being an issue. You will see clouds of black smoke and it won't pull hard through the midrange and top end. So, overall it will be a bit frustrating but should be OK. If you are still nervous set the base timing back 2o through the CAS, but it will be even more sluggish everywhere. As said above through...this is not my guarantee your engine won't be blown into a million pieces, leaving you looking for very hard to find parts A better idea is get a computer with logging ASAP, wire in a wide band O2 sensor and a use remote tuner. I've done multiple cars this way and while it is not as good as a specific tune on a dyno they can get it 90% right. I'd suggest if you can afford an R33 GTR these days you can afford an ECU and tune. And if you can't afford that you sure won't be able to afford the rebuild if it goes bad in the meantime,.
    • Yeah it would be nice if someone took the time to put that sort of information together, but there are a lot of variations in looms. I think you are making this way hard for yourself if you just want to get it running....sourcing an SR20 with the right wiring will be a billion times easier than matching the RB loom to an S15 chassis. If you do end up going this way, you just need to trace every wire in the loom with a multimeter, 95% of them will go to a location you can confirm at the ECU.....and then post it up for the next person who needs it
    • Just top it up with water, and keep a general idea of how much you added. It is normal for water to be pushed into and pulled out of the reservoir through the cap, and it should not be more than half full or it will be likely to overflow when hot. Any decent mechanic can do a pressure test of the cooling system to confirm if you have a leak. Keep in mind if it is only leaking a little and when hot it may well evaporate before you see it hit the ground
    • I'd ask the shop what they used and use that. Mixing coolants is sometimes OK, sometimes not, and you have know the details of each coolant to know whether it's a good idea or not.
    • Is it alright to top up with just another green coolant?
