What an event - I had an awesome time - Should be on Speedweek soon and now I understand what Michele means when she says that somehow IQ drops to -10 once a camera and microphone is stuck in your face.
The picture in picture is incar footage from the EVO car number 455 which you catch a glimpse of at around turn three (orange wheels)
Words cannot describe the fun I had :P:wave::D
My best time on the day was 1.44, so starting to sort the car out.
https://www.sau.com.au/forums/topic/341517-iracenetau/
thats awesome mark! what class are you in?
what was the understeering from that the car had when you got it, did you fix it ?
thats the sort of race i wanna watch, so many different cars!
i messed myself..
https://www.sau.com.au/forums/topic/341517-iracenetau/#findComment-5511377
Japanese Turbo
The problem was with the 4wd, there wasn't any... fixed now, but still needs a lot of tweaking as to how/when the 4wd comes in. A company I wont mention on here, who NO LONGER has stickers on my car because they REFUSED to tell us how THEY had 'changed' the way 4wd was working on this car, unless I took it to their friend in Sydney and got their friend to phone them when it was on the dyno. Fortunately, his friend in Sydney is better than that and it didn't need to get on the dyno to fix the problem. I eventually found the main problem after wasting a lot of unnessessary time... it needed a fuse in the bastardised system they had put into it to run 4wd. So I intend to upgrade the system that is running the 4wd so its 1) not constant 2) varies to degree of cornering and pressures. At the moment, its like having a switch on your dash, either ON or OFF, not the best setup at all, but fixable.
i messed myself..
You think you messed yourself now? Wait until you do it... and this is one event you could do, come around and see me for more details on how you enter and see the footage of when I pulled into the garage, then you will know how much fun it was lmao
https://www.sau.com.au/forums/topic/341517-iracenetau/#findComment-5511751
Looks like great fun. 1st in class?? who didn't you overtake.
I didn't overtake the Mosler MT900RGT3... but then... he didn't overtake me either in the handicap, he was right behind me for over a lap, I thought for sure he would take me LOL I was pretty chuffed when he didn't get me.
Click here to see it
http://www.btphoto.com.au/gallerypages/ira...s/DSC_5141.html
https://www.sau.com.au/forums/topic/341517-iracenetau/#findComment-5511779
That's not a car behind you, it a space fighter :P
I don't want to do the bonnet pins look for my car, but I'd love to get into a race like this. Upgrades are approved, so in a few months I'll be getting some track based suspension. Still will need the real engine upgrades to keep it 100% safe for the motor.
Guess I could already buy a car with suspension and engine work.
https://www.sau.com.au/forums/topic/341517-iracenetau/#findComment-5512041
Japanese Turbo
why would they have it setup for RWD?
well my cage from bonds should be here today and apart from some small things (tow points, new harness etc) i should be getting it log booked soon :(
i'll pop by today if thats ok, i want to talk to Michelle about BLCC sprint in dec.
https://www.sau.com.au/forums/topic/341517-iracenetau/#findComment-5513941
well my cage from bonds should be here today and apart from some small things (tow points, new harness etc) i should be getting it log booked soon :P
They didn't set it up for rwd, the fuse went in the system they put in to manage 4wd, just took me a while to find it.
Give Michele a call, I know she was trying to get you to let you know it was open. We are camping at Mcphilamy Park again.
https://www.sau.com.au/forums/topic/341517-iracenetau/#findComment-5515442
    • I'm confirming the "2 way" Nismos can be converted to 1.5's very easily as you already described. It's well detailed in the manual. I can scan mine if you need, I think I still have it laying around somewhere.
    • Well, its worth noting that 450+ is probably enough to get you to church on time each Sunday already..... You mentioned cams, did you upgrade the valve springs as well? Factory ones will be well past their use case by now. And yes, the hydraulic lifters are likely to limit your usable rpms and AFAIK you need a (now rare and expensive) head swap to rb26 or even better rb25neo for that (to retain VCT) I don't think 4"/3.5" should be a restriction. What about the intake, do you have an upsized intercooler and what is the throttle body?
    • I also second realdash. I have it on my head unit as a secondary cluster talking canbus with my ecu. Works great.
    • Something like this -  You can buy the arms in different lengths too. The suction cup goes to the windscreen.
    • I do have an adjustable exhaust cam gear but I always presumed these only lead to minor changes. I'll play around with it next week and report back. Also wouldn't advancing, not retarding shift that power down lower?  We played around with VCT last year and it made more power with it on until redline. I had read somewhere that this is often the case with short runner intakes like I'm running but I'll revisit this after adjusting my exhaust cam.  I have a 4" downpipe and 3.5" line with two open dumps. I'm thinking back pressure would only start to be an issue at 35+ psi. I often hear people state things like "oh my turbo really only wakes up past 30psi" which goes against everything I know about centrifugal compressors. Is there any actual logic to this?  Thanks for the help dose.
