Ok so i lost traction went up a gutter on an angle so wasnt as bad as head on but i ripped out a no standing pole out of the ground (Soil) NOT CEMMENT.
Anyways i definatley bent my lower control arm BUT nothing else seems to look bent, I was told if i bent the lower control arm 98% means i have bent the alloy hub. I cannot seem to find any sign of it being bent. And i also have brought a freind who works with cars to have a look at it, he says its not bent. My other freind who works with GTR's and also has a R32 GTR didnt even have a thorrow look at it and just claimed that the alloy hub would also be bent and i should just change it for safety. Im really confused on what i should do. I dont want to throw money at something that isnt broken and also how do i know that the alloy hub that i buy from a wrecker has not been in an impact just like mine. Is there a way i can tell if its bent or not? Where should i go to make sure nothing else is bent? Because If it is bent its not visible at all.
I have not got a wheel alignment done yet because i do not want the people to adjust the settings around the bent parts, i would rather change it thats IF its bent.
What should i do?
https://www.sau.com.au/forums/topic/341566-minor-accident-r32-gtr-help/
depends on how bad or hard you hit, i did something similar 3 weeks after i got mine bent lower control arm and snapped rear steering arm changed them not hub and 8 years later still no problems
well not sure how fast i was going i didnt really feel much impact but it was enough to bend the control arm. I think i just wasted money buying that hub F***K
put it on a wheelaligner. if the hub is bent it will have abnormal negative or positive camber compaired to the other wheel. replace the control arm first but. i do alot of wheel alignments for smash repairers and this is the best way.
Keep in mind that the GTR hub assy's are cast aluminum, and don't tend to bend, they fracture or get micro fractures. One way of checking is to use a dye penetrant to check for damage.
I'd rather change, and have changed hubs that have taken a big hit, than take a chance and have it let go doing 110km down the highway or around a corner etc and be up for thousands or write off the car.
^^^ good point.
...especially since 18 year old aluminium will have become more brittle.
* For instance, there was a time when they made golf club shafts out of aluminium, until over 3 years, the shafts wouldn't flex like before.
* Aluminium masts on boats also need to flex a great deal as pressure builds in the mainsail. But over time, they become more brittle & snap.
It wasnt such a big hit, nothing actually touched the Hub it self but because the bottom arm is connected thats what worries me, But the thing that makes me think that its fine is that where the bottom control arm is connected to the bottom part of the hub there is Le-way and a flexible joint, The bottom control arm did not bend past that bit where the joint cant flex.. And lets say i got a HUB from a wrecker whos to say that has never been hit?
Edited by GTRAAH
    • Have a vb in honour of the car comming back
    • It was a great, but typical track day, and some VB was ingested at the night time debrief 🤪
    • And so, to round this out, I couldn't be happier to confirm @MBS206 has decided to buy the car. He drove down from sunny QLD with a trailer last week and it is off to its new home today. I'll let Matt confirm on next steps but I understand broadly that the plan is to leave it pretty much as is, and just get some quality wheel time with a nicely balanced car that is pretty much track ready. There are a few a jobs still to be done first but nothing too major and I think its a very smart buy Dinner last night at the Paragon with a round of VBs (mostly) for Neil
    • Well, 50 pages and the end of a chapter for this car. We took it out for a shakedown at Wakie yesterday, and everything went well. There were a couple of niggles: - Oil cooler fitting leak - tightened, cleaned, stopped leaking - Radiator cap overflow fitting was leaking....Mark called it, the overflow fitting was threaded in and not tight....tightened, tested and held pressure - Small oil leak at the rear of the block, probably the turbo oil feed - too hot to get at it comfortably but probably just needs to be nipped up - leak at the driver's side rear brake line where it meets the hardline. Fitting wasn't loose, so Matt backed it off and back on, no further leaks - there's also a leak somewhere on the top of the fuel tank, maybe that cross over fuel line - that was has been left to fix when its on a hoist Otherwise than those niggles the car went great, turned great and stopped great so it was a very successful day out. I'm always really nervous when a car first hits the track after a long break, especially with a brand new engine as well but it was great. VID-20251011-WA0007.mp4  Big thanks to @The Bogan who dropped by and helped out, @MBS206 and my nephew Lachlan the apprentice.  Neil's wife Mel also surprised the hell out of all of us by dropping by; she's up in Tamworth these days but was travelling to Melbourne so had plausible deniability for turning up at the garage, it was great to see her but also obviously a bit sad all round.
    • Skyline R33 Series 2 sedan tail lights in excellent condition. These are becoming harder to find, especially in this state.    BOTH SETS ARE IN FANTASTIC CONDITION (REFER TO PHOTOS)    ✅ No broken covers or cracks ✅ Lenses are in flawless condition ✅ All rear mounting lugs intact ✅ Comes complete as pictured ✅ Perfect for restoration, replacement, or upgrade   These lights are ready to go, no surprises just quality OEM parts.   These are definitely one of the better sets we have seen in a while. With minimal wear and tear they will come as you see. Bear in mind they are not brand new they are almost 30 years old now. To find them in this condition isn’t easy they can only be obtained on the second hand market.   Australia Wide Postage Available At Buyers Expense. Silver Set:$850 Grey Set:$850 PM Me for purchase or any other questions  IMG_2166.dng IMG_2165.dng IMG_2172.dng IMG_2173.dng IMG_2174.dng IMG_2179.dng IMG_2180.dng IMG_2260.dng IMG_2258.dng IMG_2259.dng IMG_2261.dng IMG_2266.dng IMG_2273.dng IMG_2274.dng IMG_2276.dng
