600hp R32 GTR 4 SALE (GM45TR)
ENGINE:
RB26DETT, TWIN HKS25/30 TURBOS, R34 GTR intercooler, Intercooler water spray,
TOMEI metal head gasket and oil restrictor, JJR coilpacks, NISMO oil filler cap,
DRIFT stainless air filters, RB20 Air Flow Meters,
GATES racing timing belt, oil catch can with drain, ARP head studs
JJR radiator hoses, 3 CORE KYOTO aluminium radiator, NISMO radiator cap,
HKS oil cooler kit with thermo fan, NISMO fuel filler cap,
PROFEC B spec 2 electronic boost controller (low boost 320rwkw, high 380rwkw)
twin downpipes 3" exhaust, APEXI power fc with handset,
2 x walbro fuel pumps, 850cc injectors, sard adjustable fuel reg with gauge
ENGINEERS CERTIFICATE FOR ALL MODIFICATIONS
quiet smooth healthy engine with great oil pressure.
_______________________________________________________________________
DRIVETRAIN:
hicas lock bar all lines removed, NISMO twin plate clutch, JJR rear cradle mounts
RWD/AWD SWITCH, REDLINE gearbox and diff oils. Rear LSD tightened up.
INTERIOR:
leather gear boot, leather handbrake boot, staged shift light,
gear knob, MINES 320 speedo, CD MP3 player,
GAUGES: Greddy boost; water temp; oil temp; oil pressure; exhaust temp;
EXTERIOR:
original SILVER respray, CARBON FIBRE VENTED BONNET, N1 VENTS, tinted windows,
WHEELS&TYRES:
17" WEDS SPORTS light weight RIMS, GTR valve caps,
Nankang NS2 235/45/17 front and rear tyres, D1 spec light weight wheel nuts _______________________________________________________________________
BRAKES&SUSPENSION:
DBA GOLD cross drilled and slotted rotors, FERRODO pads all around,
motul brake fluid, Adjustable JIC COILOVERS
FRONT and REAR strut braces, ENGINE DAMPNER KIT
AFTER MARKET SWAY BARS FRONT AND REAR
PERFORMANCE:
Dyno tuned on E85 by JEM (Just Engine Management)
OVER 500rwhp AND 950nm OF TORQUE at wheels
PB 11.05@128MPH(205kmh) 1/4 mile at WSID in full street trim with street tyres.
SYDNEY POWERCRUISE 2010 OFF STREET DRAGS FINALIST, STREET MACHINE MAY2010
MOTIVE DVD 2010 GTR CHALLENGE COMPETITOR (UPCOMING ISSUES OF MOTIVE DVD, MOTIVE TV, ZOOM mag, HIGH PERFORMANCE IMPORTS mag & FAST FOURS mag)
YOUTUBE: "GM45TR" FOR VIDEO FOOTAGE OF CAR
$29,500 negotiable*
*Negotiable items by reducing the following:
-$500 remove custom number plates (GM45TR)
-$500 remove r34 intercooler & replace with r32 intercooler
-$500 replace weds sport rims with sparco 17x9 rims (drivable tyres) or
-$1000 remove weds sport rims with d1 wheel nuts and buyer to provide own rims
-$500 remove carbon fibre bonnet and replace with factory bonnet (unpainted)
-$2000 remove power fc and replace with stock computer
remove 1x walbro fuel pump
remove sard fuel reg & injectors (replace with standard items)
reomve profec b boost control and replace with HDI unit
retune for 98 octane fuel
$25,000 with out all of the above gear
$29,500 with the lot
CALL AHMAD PH# 0421674311
https://www.sau.com.au/forums/topic/341710-600hp-r32-gtr-4-sale/
Extremely clean and quick GTR. One of the better examples i have seen!
Good luck with the sale mate, the new owner will be getting a great car.
Yeah thanx Dave, Reliablity and power dont usually come together but this beast has the best of both !
Someone looking for a 10sec GTR that drives like a stock GTR this is it !
    • Yes I can see how that would put you off HFM, especially with the price of good quality brake fluid. From what I understand it as you say the BM50 is the standard BMC for a R32 GTR, I must admit I would like to go far a Genuine Nissan BM57, but lack of cash prevents that at present. With the price being so close between the genuine BM50 and BM57 a BM57 New it seems a better choice as you gain that 1/16 bore size with the BM57, I would be interested in how much difference you feel with the BM57 fitted. I am going to take SteveL's advice in the short term and see how much actually comes out of that proportioning valve vent and save up for the Genuine Nissan part. Thanks for clarifying the HFM failure
    • Thanks mate. I just got the post inspection 1/2 done from state roads when the starter motor packed up, either that or the car alarm system is having trouble.  OEM part number 23300-AA112.
    • Hi, I though I was coming to an end in finding a replacement starter motor for a rb25de neo. I came across a starter motor from Taarks and a message below stating: Direct fit. 11 Tooth count. All below part numbers have been superseded to 11 teeth. Can some body shed some light on going from 8 teeth to 11 teeth apart from 36-month / 25,000 km warranty for passenger vehicles to 12 Month Warranty. Compatible with the following Nissan part numbers: 23300-20P00 23300-20P01 23300-20P05 23300-20P10 23300-20P11 23300-AA111 23300-AA112 23300-AA300 23300-08U10 23300-08U11 23300-08U15
    • Low battery? Maybe check capacity? I know first-hand, on BMWs if your battery drops below 80% capacity, it starts causing strange issues.
    • 8.5 +37 = should fit rear, but I think it'll hit on front. What you want is low 30s/high 20's front, mid 30's rear. That 17" screenshot you posted looks good, I'd run it on my R32 (but that's long dead now). For tyre sizes, my rule of thumb is: 8': 235, 9": 255. But that's just my opinion. Nismo sizes: 18x8.5+35/18x9.5+38 is a good starting point.
